08-14-2007, 01:09 PM
#1 |
Mad Scientist
Oddometer: 3,173
350 Dollars For That? (A New Mad Scientist Project)
$309 actually, plus shipping. So I'm a bad guesser of shipping charges and a lousy mathematician...
Nope, won't do it. Not when I can build one. Ladies and Germs, the Stretchatec Skid Plate... Since I don't have access to metal-stamping machines and presses, I had to weld it all together from flat sheet. Each facet is a piece of 1/8-inch sheet aluminum, individually fitted and welded front and back. The skidplate itself was welded with .030 3034 aluminum wire in a MIG machine with 100% argon shielding gas. The thickness of the welds gave me enough material at the edges and corners to grind and sand until each corner was nicely rounded. Then I sanded it with 80-grit paper on a dual-action air sander. The frame is 3/4-inch steel square tubing. Welding was done with the MIG welder using .023 solid steel wire and 75/25 Argon/CO2. The rear mount sandwiches the centerstand mounts between the skidplate frame mounts and the bike frame. Come winter I'll take it apart and have it powder-coated. ![]() Detail showing the modified Touratec crash bars. I lengthened the crossbar mounting tabs so that I could use two bolts per side, instead of just one. This keeps the crossbar from rotating up and down. Then I welded a skidplate mounting tab onto the Touratec crossbar. It has paid for itself already. I hadn't done any trails at all on this bike, knowing from my Alaska ride (on a rental) how much damage loose rocks can cause. The skidplate on the Alaska rental saved the exhaust and cases numerous times, so I knew I would need a skidplate on the Tigger before I did any serious off-roading. I met WIDGIN and TigerRider for some trail riding this past weekend, and I lost count of the number of times I heard big rocks ricocheting off my new skid plate. There are a couple good gouges visible in the above photos.
Stretch67 screwed with this post 08-14-2007 at 03:24 PM |
08-14-2007, 02:56 PM
#2 |
Reformed Kneedragger
Oddometer: 4,383
Nice fab work. Looks great. I agree, they are charging way too much for a farking skid plate.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides "A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad |
08-14-2007, 03:03 PM
#3 |
Oddometer: 106
Nice job! I didn't know that you can use steel wire to weld aluminum? I have a MIG with Argon/Co2 too but I neve welded aluminum...
08-14-2007, 03:15 PM
#4 |
Mad Scientist
Oddometer: 3,173
Point taken. I edited the post to indicate the different MIG setups for each metal.
Thanks. Stretch67 screwed with this post 08-14-2007 at 03:23 PM |
08-14-2007, 03:34 PM
#5 |
Knees in the Breeze
Oddometer: 4,758
Very nice indeed.
I am still a little star-struck by those Jesse bags, but that skidplate is fantastic!
And all you are left with is a vast featureless blancmange de merde. - Bongolia 2003 XR650R (plated) For Sale |
08-14-2007, 03:55 PM
#6 |
Cunning Linguist
Oddometer: 1,805
Very nice work!! Looks better than the pricey Motech plate on my wee strom!
"It was exciting, and funny later, but nerve-racking at the time -- adventures suck when you're having them" - Neil Peart, Roadshow. |
08-14-2007, 08:51 PM
#7 |
Dirty again
Oddometer: 480
I like it! What's your Paypal address?
It is better to burn out than to rust out.--Richard Cumberland The farkling quest continues...
08-14-2007, 09:17 PM
#8 | |
Mad Scientist
Oddometer: 3,173
Models for commercial sale will look curiously like Touratec's. The above comment was a joke. Don't send me money, because I'll just send you a $310 Touratec and pocket the change. |
08-16-2007, 11:54 AM
#9 | |
finding my own way
Oddometer: 1,462
If you wish to travel far & fast, travel light. Take off all your envies, jealousies, unforgiveness, selfishness, and fears. -- Glenn Clark Let the morning bring me word of your unfailing love, for I have put my trust in you. Show me the way I should go, for to you I lift up my soul. Psalm 143:8 |
