Old 08-26-2007, 03:09 AM   #1
hapbob OP
hapbob's Avatar
Oddometer: 633
Tire Repair
Tire Repair along the side of the road??? What do you think of this E-BAy Item? Anyone have it? Will it work with CAnBUs? Thansk for replys
http://cgi.ebay.com/ebaymotors/MOTOR...QQcmdZViewItem
2014 triglide twin cooled
2007 CN250
sold2009 FLHR Road King
Hap
Retired USAF
hapbob is offline   Reply With Quote
Old 08-26-2007, 03:27 AM   #2
Andrejs2112
ihatecars
Andrejs2112's Avatar
Oddometer: 666
I have one. Great deal for all the stuff you get. Yes, it looks to be made in China, but it will get you out of a jam. I have actually used the pump to pump a few tires. I added a tire reamer to the kit because mine didn't come with one. Go for it. It would be nice to keep one in the glovebox also.
2006 Buell Ulysses
2006 KTM 950 Adventure
Andrejs2112 is offline   Reply With Quote
Old 08-26-2007, 03:32 AM   #3
RevJonG
Christi crux est mea lux
Oddometer: 12
I don't know but look here First...
I have no experience with the pump and I am also interested in any comments from someone who has used it. Before you buy it from ebay look here: http://motopumps.com/
it is less expensive
Blessings
RevJonG is offline   Reply With Quote
Old 08-26-2007, 05:42 AM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,351
It is the guts removed from the $10 CH pump from Walmart. Add a couple of cheep tools and a $4 tire plug kit from Walmart, and you have it,
I kept my complete unit, and have used it several times. The motor gets very hot, and the exposed gears would hurt if you touched them while it was moving.
Jim
Old 08-26-2007, 07:34 AM   #5
iridefar
iridefar's Avatar
Oddometer: 367
Jim
+1
Just go buy the pump from WalMart and all of the accessories/tools. Everything shown in that pick can be purchased at Wal-Mart. Or better yet, what I did was buy the small pump and tire patch kit, but carry much better tools. I also carry a BMW plug to standard plug so that I can plug in whatever I need to the bike (I have a battery tester that I also plug in). I would also pick up a better air guage than that cheap one.
Steve A
IBA #16681
2005 R1200GS
2005 F650GS
2005 GL1800 Gold Wing
1998 ST1100
2002 KLX300R
www.iridefar.com
iridefar is offline   Reply With Quote
Old 08-26-2007, 08:26 AM   #6
panzerphil
Freelance Adventurer
panzerphil's Avatar
Oddometer: 244
Jim
This thread has just prompted me to dig out an old pump I have.
I'm gonna solder some wire to supply power & I recon I'll fuse it as well.
I'd like an answer to the original poster's question - Will this be OK to use with the CANbus?
I wouldn't like to immobilise my bike when the time comes to use the pump.
Mine's got a pressure gauge as well!
Name:  Old One (Small).jpg
Funkier than James Brown's pants.
panzerphil screwed with this post 08-26-2007 at 08:46 AM
panzerphil is offline   Reply With Quote
Old 08-26-2007, 08:35 AM   #7
Dogscout
Been there done that
Dogscout's Avatar
Oddometer: 1,449
Tire Plugging on the Dempster
Slime pump plugged into BMW accessory socket and a tire plugging kit.
Be aware that a steel belted tire will cut through a rubber plug, so get a vulcanized patch as soon as possible.
Originally Posted by matteeanne
You sir are now denoobified and an honorary member of the secret order of the wtf thread. Well done sir, well done.
Dogscout screwed with this post 08-26-2007 at 10:01 AM
Dogscout is offline   Reply With Quote
Old 08-26-2007, 08:48 AM   #8
FrisbeeR1200GS
FrisbeeR1200GS's Avatar
Oddometer: 195
Slime Tire Inflator Kit
I have this product, nicely packaged, reasonably small, and perfect for bikes with luggage, etc. Retail price is around $40.00 US. Here's what they say: High-Power 12 Volt 300 PSI Air Compressor
Main Harness Wire with Fuse 8/240cm
Alligator Clip Cord for Any Battery 18/45cm
Power Cord with A/C Adapter 18/45cm
Pre-Wire Cord Direct to Battery 18/45cm
Air Hose with Quick-Clip - 18/45cm
Valve Core Removal Tool & Filler Tube
Tire Pressure Pencil Gauge
Tools and Adapters for tires, balls, beach toys, air mattresses, inflatables
Rugged Carrying Case 6X6 15X15cm
FrisbeeR1200GS is offline   Reply With Quote
Old 08-26-2007, 01:35 PM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 53,351
Attachment 130718
Sure, as long as you plug it directly into the battery. I use the Gerbing plug for mine, run off my fused and relayed fusebox, but you could use a Gerbing plug that goes directly to the battery.
The BMW plug limit is 5 amps, and the compressor is over 10, so it wont work off the BMW plug unless you have it direct to the battery or a fuse box.
Jim
Old 08-26-2007, 05:13 PM   #10
Flyboy08
Flyboy08's Avatar
Oddometer: 771
Me gots one too...I have only used it on the road helping out cages and trailer tires so far...Works like a champ, but it gets very hot..too hot to place right back in the bag
I never ride without it. Use it off of my battery plug...Canbus will NOT power it.
About women, I say... "Never trust anything that bleeds for a week and doesn't die."
07GSA....Holy Cow!
06 K1200R "Der Naked"....SOLD...too damn fast
05 R1200GS "Das Boot" ....SOLD...already miss her!
01 K1200RSFL "Das Pig"
Flyboy08 is offline   Reply With Quote
Old 08-27-2007, 03:13 AM   #11
hapbob OP
hapbob's Avatar
Oddometer: 633
Ok
OK sounds like again great advice here....I already have the Walmart mini pump...I can take off the plastic to make it smaller and I can buy the other stuff and have a kit...I will have to look for a nice carry box/bag for it all. I need to but a connector on the battery for this and trickle charger ...Good Advice people!
2007 CN250
Hap
Retired USAF
Old 08-27-2007, 11:56 AM   #12
Mitchel
Moron in the aggregate
Oddometer: 186
+1 on the slime pump. Got mine from Pep Boys for $25ish bucks. I've used it a couple times with good results.
Mitchel is offline   Reply With Quote
Old 08-27-2007, 12:23 PM   #13
leahyz
Gigantic Tool
leahyz's Avatar
Oddometer: 471
+ one on the walmart pump. I use mine occasionally. I simply cut the socket on and crimped on some alligators. I then clip it to the battery of any vehicle.
I just used it the other day as my house compressor died out and I needed to air up a tire. It took a few minutes and I was back on track.
I used it on my wifes car when we were on our honeymoon out west. I removed the wheel, plugged the tire, and pumped it up with the little walmart pump. All the work took under 30 minutes which included digging out the jack.
Zach
Ft Wayne IN - Where the roads suck.
2006 Pacific Northwest Trip - Gone Wanderin...
2008 Trans-Am Trail Ride - TN & MS
leahyz is offline   Reply With Quote
Old 08-27-2007, 12:45 PM   #14
longtallsally
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 4,466
Yeah the Canbus is weak sauce- I even had a cell phone charger kick it off.
I think Treadless has the funk for a setup in that he fabricated a small aluminum box that fits under the seat in the open space there. He hard mounted a $10 pump to the box and just runs it there. At some point when I get a little time, I'd like to fab something like that for myself.
longtallsally is offline   Reply With Quote
Old 08-27-2007, 01:15 PM   #15
FXRocket
Phoneticide Squad
FXRocket's Avatar
Oddometer: 5,315
Linky?
FXRocket is offline   Reply With Quote
Times are GMT -7.   It's 07:07 PM.
