Old 10-03-2009, 09:11 AM   #601
krehmkej
krehmkej's Avatar
Oddometer: 243
Ummm. Good point. Redesign time..
My $0.03, YMMV.
Expect the worst - you'll never be disappointed.
-jwk-
krehmkej is offline   Reply With Quote
Old 10-03-2009, 10:15 PM   #602
trasko
trasko's Avatar
Oddometer: 283
FWIW I'll add that my trickle-charger uses an SAE cable by default and comes with an SAE to clamp adapter / dongle. That dongle has a 75 amp fuse build in. I don't know exactly for what but... it does.
Right now I have an SAE plug dangling for the electric jacket and charger... I think its the 16/18 gauge one instead of 10 gauge unfortunately.
trasko is offline   Reply With Quote
Old 10-04-2009, 09:39 AM   #603
markjenn
Oddometer: 10,483
Yes, you can charge through these dongles, but you can't jumper/start a bike. Most folks think you need 10awg for jumping, perhaps you can get away with 12awg.
That 75 amp fuse on the clamps to SAE is what the wire is rated at, not what the typical charging current is.
- Mark
Old 10-05-2009, 06:43 AM   #604
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,043
Take a closer look at the fuse.... more than likely it's a 7.5 amp fuse, not 75.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 10-05-2009, 12:53 PM   #605
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
Originally Posted by Pete O Static
Hi Mark
Interestingly, I am fussing over that exact situation. I am thinking of an inline fuse but it would need to be pretty hefty to allow boosting. Not sure of the initial amperage during a boost but I would imagine it is north of 50 amps.
Mine used a 40 amp inline fuse about an inch from the battery.
HaChayalBoded is offline   Reply With Quote
Old 10-05-2009, 12:54 PM   #606
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
Originally Posted by krehmkej
After reading all this, I made up a 6-foot jumper set using 10-ga speaker wire. Looked at all kinds of clips, but settled on simple ring terminals. Any bike I have ever seen has the same 6mm battery bolts so they should be toe smallest and have the maximum ampacity.
Instead of ring terminals, use spade connectors. Those are the ones that are U shaped. 1\4 turn of the battery bolt and slide it right on. This helps often because lots of times battery bolts are short and the little nut falls to the bottom and it takes a helluva lot of patience and balancing a small oothpick to raise it enough to catch the bolt.
Old 10-05-2009, 01:27 PM   #607
East Coast Rider
Just Me...
East Coast Rider's Avatar
Oddometer: 4,022
Originally Posted by Foot dragger
Those tool tubes shatter on contact with rocks or flying debris,Ive seen em do it. Mounting them in front of the engine is not a good idea, Suppose you ride through a rut? Kinda like making your bike into a bulldozer. Doesnt work well off road.
Did 10,000 mile round trip to AK last summer, and my 3" pvc tube mounted on the front of the frame down tube did just fine. LONG portions of gravel/rocks--Top of the World Highway is all gavel and portions of the Alaska Highway are pretty rough. Huge frost heaves...Not a problem. But for hardcore offroad, though, I am sure you're right.
Txt msg with Dan right after he was paralyzed:
Me: Hey Dan-O. Just wanted to say howdy and Love ya!
Dan: Howdy and Love you too. Doin' good and feeling good.
Me: Give 'em hell, little Bro!
Dan: Roger that.
East Coast Rider is offline   Reply With Quote
Old 10-05-2009, 01:41 PM   #608
RandyB
Oddometer: 5,072
Schedule 40 PVC and JB Weld made a great fly rod holder for my GS.
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Old 10-05-2009, 07:40 PM   #609
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Tool Tube
Somewhere in the woods of Quebec is my buddy Joe's complete KLR toolkit. He laid it down on a rocky section and didn't notice till it was too late that the tube had shattered on one end...
I snapped the big hose clamps that held mine on a few times and then gave up on the idea. Might be alright for on-road.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 10-05-2009, 07:57 PM   #610
trasko
trasko's Avatar
Oddometer: 283
Mine have survived quite a few jaunts off-road but all my sockets/allen wrenches have rusted to shit. I didn't think moisture got in there but it did. Ever since I put the tool tubes on the front I've been wanting something else -- something "cleaner" -- as if that somehow applies to KLR. That said, for a couple of years now I've had all my heavy tools down low and always with me which is way better than before. I'm going to leave them there till I have something better.
Old 10-07-2009, 08:25 PM   #611
xroad
Oddometer: 774
Originally Posted by jesusgatos
As I scan through all the post and pictures, I notice some have this long nose Vise-Grip and some have the 5" regular nose Vise-Grip. I cannot decide.
If in an emergency, the regular nose can be better as a make shift lever for a broken clutch, brake, or shift lever. I already have a mini long nose in my micro multi-tool from Walmart.
Somehow, I don't feel the long nose Vise-Grip can be much beyond being just a long nose plier.
Any inputs from you guys?
Carpe diem quam minimum credula postero.
xroad is offline   Reply With Quote
Old 10-07-2009, 08:47 PM   #612
xroad
Oddometer: 774
I am carrying this now, Vise-Grip 4LW. Just in case I have a slightly rounded nut. The "beak" can also be use to grab stuff like the regular nose Vise-Grip.
So now I have three options on Vise-Grips ..... decisions, decisions .....
xroad screwed with this post 10-07-2009 at 09:09 PM
Old 10-07-2009, 09:03 PM   #613
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
(Someone tell me how to attach a picture, I have it on my PC desktop)
Here ya go.
to attach pictures, click reply or quote, when the box appears that you type into look below it, under options you'll see a button that says "Add Attachments" click it, find the file you want to upload and click upload.
Old 10-07-2009, 09:04 PM   #614
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Put IMG tags around the image url.
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 10-07-2009, 09:10 PM   #615
xroad
Oddometer: 774
I'm a bit slow, figured it out. Thanks guys.
Times are GMT -7.   It's 02:10 PM.
