Old 05-22-2013, 08:17 PM   #2701
majorpayne
majorpayne's Avatar
Oddometer: 255
Found a 00 model locally with 6k on the clock for around $1300. Supposedly it's been meticulously cared for. Assuming everything is order I might be a SS owner in a couple days.
Any big issues that I'll be able to check out with a fairly quick glance?
I'm just getting into riding, so "just do a test ride" probably help me much.
majorpayne is offline   Reply With Quote
Old 05-22-2013, 09:32 PM   #2702
ssmschulz
Sherpa Rider
ssmschulz's Avatar
Oddometer: 149
If it starts and runs smoothly, buy it. That is a great deal and you will love it as you learn to ride. I rode my wife's 2000 all last summer and it really changed the way I now ride a 400. I still ride the SS all over town as it is super fun on the street as well.
MS
ssmschulz is offline   Reply With Quote
Old 05-22-2013, 09:40 PM   #2703
majorpayne
majorpayne's Avatar
Oddometer: 255
Awesome, thanks.
Old 05-23-2013, 05:10 PM   #2704
ssmschulz
Sherpa Rider
ssmschulz's Avatar
Oddometer: 149
Awesome, thanks.
The worst that can happen is you hate it and for $1200 invested, you can always turn it over.
The most expensive repair / mod I made was handle bar risers and bark busters. Tires are cheap, no radiators to break. Change the oil and change the air filter often ( I clean and re-oil the stock one and have two on hand - one in the bike and one clean and oiled one in a bag).
Cold start issues are a problem, but do not let that stray you. I start mine up and let it idle while I gear up. When ready, so is the bike.
MS
Old 05-23-2013, 06:13 PM   #2705
Hawk62cj5
2 Cheap 4 a KLR
Hawk62cj5's Avatar
Oddometer: 593
I was riding last night and my sherpa started to get a hard metallic clunk when stopping . I pulled off the first chance I got and looked it over . It sounded like it was coming from the rear . I checked the rear wheel over , the swing arm and then the shock , every thing all right . Filled up on spaghetti at a dinner then went home , looked it over again and sprayed the mud of every thing . This morning I went out around 5:30 and checked it out and was the front bolt was missing out of rear caliber bracket . So when I hit the brake the caliber was smacking the rotor .Well at lest it was an easy fix , I guess I need to take the bike apart and reassemble it with lock tight . at lest I have a nice long weekend for it lol
09 Super Sherpa KL250
62 CJ-5
Trailering a bike is like hiring a prostitute just to jerk off in front of her .
Hawk62cj5 is offline   Reply With Quote
Old 05-23-2013, 06:23 PM   #2706
majorpayne
majorpayne's Avatar
Oddometer: 255
I went and looked at it today. Very clean. Has 6700mi on it. Meticulous records kept on all oil/filter changes. Older guy owns it and all of the things in his garage appeared to be very well taken care of....which is a good sign. It was cold (I checked) and it fired right up. I'm not too concerned about cold start issues. But I will need some bar risers.
Any way to raise the seat height a smidge?
Old 05-23-2013, 08:25 PM   #2707
ssmschulz
Sherpa Rider
ssmschulz's Avatar
Oddometer: 149
Any way to raise the seat height a smidge?[/QUOTE]
Add a ATV seat pad from Walmart.
Did you buy it?
Here is the Bar riser info
http://klrworld.com/forums/your-klkl...429/#msg243429
MS
Old 05-23-2013, 08:28 PM   #2708
majorpayne
majorpayne's Avatar
Oddometer: 255
Did you buy it?
Not yet. Still trying to get the proposal past the chairman of the board...if you know what I mean.
Old 05-24-2013, 03:27 AM   #2709
Turborob
Minimalist.
Turborob's Avatar
Oddometer: 636
Originally Posted by eepeqez View Post
Given you've changed tank, check you've actually got fuel flow and that you've got fuel in the carby bowl.
Turned carb bowl allen screw and fuel went on the garage floor, as planned.
Then, tried to start, again with no luck. Pushed bike to a down-hill and it fired up when bump-starting. Runs fine whilst on.
Wish the XR650 tap had a 'prime' option on the tap.....that's how I've always started the sherp in the morning, few seconds on prime before pressing the go button.
Anything else to check?
Latest ride report: Nongs ride the Americas
All RRs
The best rider is the one who enjoys it most.
Turborob is offline   Reply With Quote
Old 05-24-2013, 09:46 AM   #2710
jon_l
jon_l's Avatar
Oddometer: 3,299
IBut I will need some bar risers.
Tusk 1-1/4" aluminum risers are $20 from Rocky Mountain ATV
http://www.rockymountainatvmc.com/p/...r+super+sherpa
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 05-25-2013, 07:20 PM   #2711
12Bong13
12Bong13's Avatar
Oddometer: 199
Just got my 2001 yesterday. Here is a pic.
Today, I fitted Rox 2'' risers and Zeta Handguards. I will hit the trails tomorrow!
12Bong13 is offline   Reply With Quote
Old 05-26-2013, 03:09 PM   #2712
majorpayne
majorpayne's Avatar
Oddometer: 255
Here's the SS...looks pretty much like the rest of them. I take delivery on Friday. Really excited.
Old 05-27-2013, 05:38 PM   #2713
12Bong13
12Bong13's Avatar
Oddometer: 199
Nice info here. Lots to read.
I also created a Facebook group for the Sherpa, since there was none. Here is the link
https://www.facebook.com/groups/463667027034745/
Old 05-28-2013, 09:54 PM   #2714
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,883
I have a 09 that I got from a dealer with 285 miles on it . Did the carb rejetting , started great. At 420 miles the head ate itself . Seems the dealer did the recall to day before he transferred it to the dealer I got it from . Kawasaki covered a new head but now it is a cold blooded beast again.
Checked and cleaned the carb, jets , float level ,slide , checked for air leakes , checked valves- they are on the loose side of spec ,cleaned air filter ,checked timing . Anything else I need to look at ?
Temp high 70's start full choke , let run while putting on gear app 5 minutes . Will not take throttle, bogs ,dies, restart full choke . Finally after 15 minutes of this it will run. Kept in a heated shop , will do it on 10% or pure gas .
Also get a whif of oil smell after riding and it will turn the oil black in 250 miles .
Cotton says : This is as screwed up as a rope with 3 ends
flyinfuzz is offline   Reply With Quote
Old 05-29-2013, 11:47 AM   #2715
goathead
grunt and push
goathead's Avatar
Oddometer: 43
Super Sherpa
My new to me Super Sherpa
goathead is offline   Reply With Quote
Times are GMT -7.   It's 02:51 AM.
