Old 06-12-2009, 11:01 PM   #46
Phreaky Phil
Oddometer: 1,806
Thats a bugger if they've become unavailable. I have been contemplating what I will do with my front end but have been busy with my rear disc conversion. I think the inserts were something like $2000 through BMW. Will have to check again.
Phreaky Phil is offline   Reply With Quote
Old 06-14-2009, 11:35 PM   #47
Phreaky Phil
Oddometer: 1,806
I emailed Q-tech and got a reply of no they are not available. I was ordering some bits from BMW so I got him to price the left and right inserts. NZ $912+gst(12.5%) each side.!!!!!!!!!!!!!!!!!!!!!!!!!!! Thats US$653 or EUR$468 each side.
The part # are 31422317539 Left and 31422317540 Right. Has anyone else priced these through BMW ?
Old 06-15-2009, 12:31 AM   #48
igormortis
igormortis's Avatar
Oddometer: 1,353
Ouch. Not surprisingly, ridiculous numbers from BMW. Would you consider going with another front end entirely?
igormortis is offline   Reply With Quote
Old 06-15-2009, 01:57 AM   #49
Phreaky Phil
Oddometer: 1,806
Yes, I built a WP fork setup for it a few years ago, but in a moment of madness was going to sell my Airhead so I sold the WP front end. Then I came to my senses and kept my Airhead. ! The triple clamps are probably the most expensive item, depending of course on what forks you buy. I could do the Cartridge Emulator thing, although they are not as good as a good set of cartridge forks. This is the setup I sold.
Old 06-15-2009, 12:17 PM   #50
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
Originally Posted by AliBaba
I have a bike with the inserts and tuning works through the entire stroke..
See # 25?
I think that is the adjustable portion, that is pushed down through a seperate tube... I am told that this is the piece that doens't have measureable effect until the end of the stroke.... is this different on the magnum inserts?
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 06-15-2009 at 12:34 PM
Solo Lobo is offline   Reply With Quote
Old 06-15-2009, 05:53 PM   #51
Beemerboff OP
Oddometer: 2,310
One advantage of these things is that you can fine tune them on the move, and I can assure you that the adjusters make a difference no matter what range the suspension is running in.
It isnt large , and on bitumen you would be hard pressed to notice it till you hit major bumps, but when you hit the dirt, or in my case gravel roads, a couple of clicks can make a big difference.
They are sensitive to oil grade too - a fill with fresh oil makes a noticable improvement , particulearly if the old stuff has done 50,000 k s --------.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 06-15-2009, 07:23 PM   #52
batoutoflahonda
Oddometer: 1,383
Hard to see in that. But the smaller diameter rod above#25 I think is attached to 25, then it's attached to the clicker on top of the fork. by turning the clicker you change the opening in 25, which is what does the adjustments. By having that low in the fork, it allows adjustments through the whole stroke.
I might be wrong tho.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 06-16-2009, 04:41 AM   #53
Beemerboff OP
Oddometer: 2,310
What is confusing is the drawn length of the rod, but if you look carefully you will see a squiggle in the centre of the rod - that squiggle indicates that there is a bit of the drawing missing, in this case the extra length needed to get it up to the top cap.
Old 06-16-2009, 03:07 PM   #54
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 827
Inserts
Hallo John,
at the moment we have no parts in stock. We are trying to get a production arranged again, but we are not sure if and when it works.
Please contact us again within abt 4 weeks.
Best regards
Klaus Pepperl
HPN Motorradtechnik GmbH
Hofmarkstr.1, D-8475 Seibersdorf
Tel.:+49-(0)8571-5300; Fax.:+49-(0)8571-1081
e-Mail: info@hpn.de; Internet: www.hpn.de
Geschäftsführer:A.Halbfeld; K.Pepperl; Amtsgericht Landshut HRB1822
If we all contact them perhaps they will get some more made?
Bulldust
Bulldust is offline   Reply With Quote
Old 06-16-2009, 05:01 PM   #55
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
Bulldust
The about the cost of these inserts I would choose the buy the triple clamps from a German company that allows the use of WP Extreme 50mm conventionals and a KTM front wheel (or BMW)...
R65LazaruS
Old 06-17-2009, 12:04 AM   #56
Phreaky Phil
Oddometer: 1,806
Hallo John,
Best regards
Klaus Pepperl
Bulldust
At this point in time I would be interested in a set if they could get some more. Can you update this thread if you hear anything more ?
Old 06-17-2009, 05:46 AM   #57
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 827
Sure but why not send them an email, the more demand the more likely they are to make them.
Bulldust
Old 06-17-2009, 04:12 PM   #58
igormortis
igormortis's Avatar
Oddometer: 1,353
Is it worth getting definite numbers? ie. a list of people ready to come up with the cash that we can forward to HPN with a promise of a deposit.
How many sets would make such a thing viable? Perhaps a phone call is in order.
Old 06-17-2009, 05:51 PM   #59
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,806
Looks like Ohlins is just starting to produce cartridge kits for motocross bikes.... perhaps they would cobble together a set for G/S's
link
R65LazaruS
Old 06-17-2009, 06:18 PM   #60
Phreaky Phil
Oddometer: 1,806
link
Unlikely and have you priced them ?
Times are GMT -7.   It's 06:50 PM.
