Old 06-17-2009, 07:03 PM   #61
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
Originally Posted by Phreaky Phil
Unlikely and have you priced them ?
Nope, but provided someone (other than ohlins perpahs) makes a cartridge that has the correct OD, the rest is just parts and know-how... perhaps the limiting factor is the small OD of the G/S forks?
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 06-17-2009, 07:07 PM   #62
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
Bitubo makes 'em, granted they are for the F800GS and USD forks... don't know if they make kits for conventionals...
R65LazaruS
Old 06-17-2009, 08:38 PM   #63
Beemerboff OP
Oddometer: 2,310
YSS are probably a better option - they do valve kits for the other airheads which dont have the Marzocci forks so small runs dont seem to be a problem for them.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 06-18-2009, 12:17 AM   #64
Phreaky Phil
Oddometer: 1,803
Sorry, I didnt have time for a proper reply earlier. I spend a bit of time on occasions at our Ohlins dealer and while there an awesome bit of kit theyre pricey. I think about NZ$3000. The complete Ohlins Forks were over $5000 so the kit is a cheaper option. I think a list of who would be interested in a kit is a good idea. I guess knowing a price is a consideration. Am I right in saying HPN were selling theres for 585euros ?
Phreaky Phil is offline   Reply With Quote
Old 06-18-2009, 01:28 AM   #65
Beemerboff OP
Oddometer: 2,310
I landed a pair in Oz for around $A570 - they dont charge the 18% sales tax and post was reasonable.
Old 06-18-2009, 02:46 AM   #66
igormortis
igormortis's Avatar
Oddometer: 1,348
Well, I'm currently deciding what's right for my bike - GS or another front end. I'm gonna convert a road model, and if the HPN inserts can be "resurrected" I'll definitely go with the GS forks.
igormortis is online now   Reply With Quote
Old 06-24-2009, 10:38 AM   #67
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
Just caught this note over on UKGSer...
Originally Posted by Beemerboff View Post
YSS make inserts for the mono forks.
Munich Motorcycles in Perth , Australia is the only place I have seen them..
and sent an email to Munich to ask if they do indeed make mono inserts and how much they may be!
R65LazaruS
Old 06-24-2009, 11:31 AM   #68
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Fill me in: mono forks/inserts? 36mm forks as used on monolever? The ones for the monolever street bikes are shorter than the G/S, no?
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 06-24-2009, 11:34 AM   #69
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
what do you get if you cross an elephant with a rino...
elephrino
Anyway, the comment I posted came from a G/S rider... draw your own conclusions until I hear back from these guys.
R65LazaruS
Old 06-24-2009, 11:44 AM   #70
StephenB
StephenB's Avatar
Oddometer: 2,044
So ... G/S fork inserts? You're dreaming again of how fast you can spend another bundle without moving the bike
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 06-24-2009, 11:55 AM   #71
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
Too true, just shopping if anything... my fork changes from last weekend did a real difference and I may not need to do anything drastic... but if the replacement internals are priced OK, why not do it?
R65LazaruS
Old 06-24-2009, 12:03 PM   #72
StephenB
StephenB's Avatar
Oddometer: 2,044
Absolutely. I have still to tune my front (GS) forks but I first like to see how they perform under load. Single and unloaded, I don't have enough sag so they are a bit stiff, but not bad. I will have to take maybe 1/2in pre-load off to make it right for solo riding, but maybe it would be too soft then loaded. Do you have experience for the front forks from your GS days?
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 06-24-2009, 12:48 PM   #73
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
Mine worked very well.. I had a racetech emulator (1.25 turns of preload), stock springs, stick spacer cut down for the height of the racetech cartridge, and 10wt fork oil
R65LazaruS
Old 06-24-2009, 12:51 PM   #74
StephenB
StephenB's Avatar
Oddometer: 2,044
Ah, mine's still on 2 turns (factory) with stock springs and spacer cut to length per instructions ... you couldn't have any sag, you're lighter than me if I recall (I am about about 210 give or take). I am running 7.5wt ... IIRC.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 06-24-2009, 01:44 PM   #75
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,800
Remember the 2 turns in the instruction for the bike the 'valve was designed for... and in the case of the the ones used in the GS that would be a Harley or Metric Cruiser...
That means the 2 turns is for a heavier bike with much less suspension travel (as least I think that is what it means).... and that leads me to conclude less pre-load(and/or a softer spring) would make the 'valve work better on a GS
R65LazaruS
Times are GMT -7.   It's 10:53 AM.
