Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 12-05-2012, 03:02 PM   #6016
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,723
Originally Posted by RallycarJon View Post
I am proficient at the last move for sure..... This video is the reason I went with SW Motech crash bars over the competition. They certainly seem to stand up to quite a bit of abuse and offer good protection. Too bad I got them just after I had dropped the bike for the first time.
Don't feel bad. I took mine swimming when it was naked with 150 miles on it. It seems no worse for the wear.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 12-05-2012, 03:28 PM   #6017
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Originally Posted by edhead View Post
Here it is. You can see where I got off center attempting to drill the hole for the ez out.
Got a dremel and freezer space? If so, cut that hole straight across so you can get a flat head on it. Hose it with penatrant. If it gives then, great. If not, freeze it,heat the alum around the bolt and try again.
Or dremel a centerline in it and use a punch to bend the bolt in the holes.
Danjal screwed with this post 12-05-2012 at 03:36 PM
Danjal is offline   Reply With Quote
Old 12-05-2012, 03:40 PM   #6018
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,847
Did you start with a hammer and a drift to center the hole before drilling?
Locktite has a product out for stuck bolts that super cools the offender to shrink it and break the bond. I've had successful results with it.
muddyrabbit is offline   Reply With Quote
Old 12-05-2012, 04:15 PM   #6019
Mikey Ray
Mikey Ray's Avatar
Oddometer: 6
Originally Posted by hateithere View Post
that xl600r is nice, miss mine
My brain says thanks, my right leg does not agree.
Mikey Ray is offline   Reply With Quote
Old 12-05-2012, 04:21 PM   #6020
hateithere
anytime now
hateithere's Avatar
Oddometer: 2,496
mine either, you did'nt hurt yourself on that thing did you?
hateithere is offline   Reply With Quote
Old 12-05-2012, 04:51 PM   #6021
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,403
He didn't hurt himself but he may have a heart attack as the choke lever is broken and it takes about 322 kicks to get it going on a cold day.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 12-05-2012, 05:04 PM   #6022
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,231
Lay it over until it dribbles gas a few seconds then try.
Bing carbs didn't have chokes, just tickle (flood) buttons to hold the float open to flood the motor
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 12-05-2012, 05:10 PM   #6023
ScienceOfDirt
U-Boat Rider
Oddometer: 1,723
What kind of penetrant have you got to work with aluminum? I've never had kroil, pb-blaster, or anything else I've tried work when anything non ferrous was involved.
Old 12-05-2012, 05:17 PM   #6024
Mikey Ray
Mikey Ray's Avatar
Oddometer: 6
I can try that. I didn't hurt myself and its not that bad to start. It just seems like any throttle input kills it and it does take a few (dozen) kicks to start. After the first start of the day though its fine, one or two kicks and its running. I always hold the kicker all the way down after a kick till it either starts or stops turning though. I don't know if It's true or not but my dad told me this will help prevent being kicked back.
Old 12-05-2012, 06:03 PM   #6025
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
All of the above and a 20 pound sledge for backup. The bolt is ferrous.
Old 12-05-2012, 06:38 PM   #6026
hateithere
anytime now
hateithere's Avatar
Oddometer: 2,496
When I had mine the starting procedure was De-comp to the top of the stroke, no gas choke, one nice kick and it would usually fire right up, any gas an I just let it sit for 10 minutes.I'm not sure i'd hold it all the way down, that's a lot of force coming back up.A good running xl should start fairly easily
Old 12-05-2012, 07:11 PM   #6027
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,231
Without the choke in this weather it's had to tell but there is a chance that it is lean on the bottom, most XR's are. Maybe next time see you, we can adjust the fuel screw/idle.
Michael
Old 12-06-2012, 03:38 AM   #6028
Mikey Ray
Mikey Ray's Avatar
Oddometer: 6
Mucho Gracias.
Old 12-06-2012, 03:42 AM   #6029
Mikey Ray
Mikey Ray's Avatar
Oddometer: 6
Pretty much this but the choke lever is busted. The kid I bought it from Got it from his uncle and probably didn't put a single cent back in to it. Both tires were trash oil was black ect. I have new tires,oil,handgaurds and bar risers on it. One thing at a time. Oh yeah and I guess if you give a firm kick and hold er down that reduces kickback? Just advice from dad, he used to ride quite a bit but did have a Triumph kick his knee out requiring surgery so who knows.
Old 12-06-2012, 04:41 AM   #6030
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,231
Just remember, if your knee is locked out at the bottom of the stroke and it kicks back, the force has to go somewhere and if your knee is straight, oops. At least if it is bent a little you'll either smash your knee on the handlebar or your chin.
Michael
Times are GMT -7.   It's 04:42 AM.
