01-16-2013, 06:39 AM
#6406 |
Random Hero
Oddometer: 1,701
Forgot the $12 ebay cafe rear fender.
Never turn your back on Fear. It should always be in front of you, like a thing that might have to be killed. |
01-16-2013, 10:11 AM
#6407 | |
anytime now
Oddometer: 2,356
Not to sound like a jerk cause, I really do like most of the people that come into the shop, but I have some pretty funny stories, about people and thier bobberchoppercafe projects. |
01-16-2013, 01:40 PM
#6408 |
New Old Stock
Oddometer: 3,999
Genuine real authentic imitation carbon fiber barkbusters.
3x3 mod, jet kit, manual cam chain tensioner. ![]()
KLR 650- BMW K75- DRZ400S- 75 XS 650 Every bike an adventure bike... Every ride an adventure. |
01-16-2013, 02:15 PM
#6409 | |
Oddometer: 567
Pretty clean garage you got there Gorman! |
01-16-2013, 05:07 PM
#6410 |
U-Boat Rider
Oddometer: 1,493
Of course it is. All those old retired guys just putter around in them all day long.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost. |
01-16-2013, 06:22 PM
#6411 |
Insert wit here.
Oddometer: 1,275
I see Dr Gorman got her done. How did the carb turn out? Anything done exhaust wise? She's lookin good Tom. Anything else planned?
I checked the tires you recommended Mike. The m59s seem to be kaput. Only size was 110/90-21. Front only. Luckily that fits the klx. The tracmaster looks like the mx51s I was looking at off recommendations too. They're about $15 cheaper too. The 51 is intermediate,the 59s are intermediate to soft rated. They cost $3 more too. I'll do some more looking when I get time. Good news for today. That spill I had back in Nov. I'm fairly certain my shoulder was separated. The collar bone seemed too high at my shoulder,had a nice hard spot too. Well, today driving home from work I had my elbow resting on the door of the fj,hit a pothole,and my shoulder made a nice loud pop. My teeth half gritted from the upcoming sensation only to feel like everything was all right finally. Bump is gone now. It doesn't feel awkward in certain positions anymore either. Woo hoo! |
01-16-2013, 06:29 PM
#6412 |
New Old Stock
Oddometer: 3,999
That's crazy Dan. I whacked my shoulder hard on the ice and it took three weeks to get it feeling better. Dan, answer this one. The stock main jet in the DRZ is a 142.5. The ones that came in the kit are listed as DJ128-DJ136. How does that work?
01-16-2013, 06:39 PM
#6413 | |
Insert wit here.
Oddometer: 1,275
http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm Now also keep in mind needle diameter too. If you swap needles throw away all jet comparisons unless the original needle is maintained. Different needle tapers will flow fuel at diff rates,so if needle a is slimmer then needle b it'll need smaller jets to flow the same fuel. That answer it? My advice. Buy an fcr-mx 39 and never be unhappy again. They're flat out awesome. You still need to ride this beast of mine. You'll see what it does. Danjal screwed with this post 01-16-2013 at 06:47 PM |
01-16-2013, 06:55 PM
#6414 |
Insert wit here.
Oddometer: 1,275
Also it's a cv carb too. Most kits mess with the vac operation of the slide to change needle timing. Making them lift faster to suck more fuel in is a usual mod. Did you have to drill the slide it change the weight on it? Keep that in mind too.
Cv carbs 101- Your slide is on a diaphragm, needle goes through the slide. That sits in the main bore of the carb. Behind the diaphragm is a hole in that bore or its somewhere the slide and intake that goes from the main bore to above the slide. This uses vac from the engine intaking air to raise the slide. Also behind the slide is the butterfly valve. This is controlled by the throttle cable. Open or closed fast it wouldn't matter since the vac operation of the main slide controls air and fuel in. It's also slower since vac needs to build to lift it. Slide style carbs use a cable on the slide instead of a diaphragm. Raising one too fast causes a lean condition known as "4 stroke bog". Some carbs like the tm-40 and fcr-mx added an accelerator pump to fight being lean. No vac operation. You open the throttle fast and she goes right now or dies without the pump. Non pumped carbs are ran rich or you learn to not wfo the throttle fast. No fluctuation of the throttle on a bouncy road due to a bouncy vac operating slide either. They're a smidge less fuel efficient,but a sorted one won't show it since your afr needs to be the same to run the same machine anyway. Cv carbs are normally easier to pass epa and tamer so most makers use them for on road bikes. EPA compliance due to slower moving slides and not a fast rich spike from improperly jetting to stop bog,or an ap pump for a sudden enrichment. My Dr only did one wheelie before the fcr on an accident when I throttled high and accidentally lost grip on the clutch. And it wasn't big. Now, I'll loop my big ass if I open it wfo from a stop. Much peppier and no feathering needed. Won't make me a better rider,it'll help log crossings though or at low end speeds or revs. It's much less picky in gears in town too. I know you'll get the sudden accel vs the mickey carb, top end wont differ on one to the other though. Slides effect low-mid only vs cv. After your peak powerband is strung out they both just idle up to that last little bit left. If it's lacking there, this is the way to go,if you're happy,save the money and ride on. Danjal screwed with this post 01-16-2013 at 07:23 PM |
01-16-2013, 07:31 PM
#6415 |
Crashing since 1964
Oddometer: 4,288
He decided to quit school, drop out of the Army, knock up his GF, skip out on her for a life of crime. Haven't seen him in about 5 years when we told him to come back when he didn't need any money
Michael |
01-16-2013, 07:43 PM
#6416 | |
Crashing since 1964
Oddometer: 4,288
You haven't seen the side where Tom was standing. The cacant are is where the F150 and Fusion sit. What you don't see are 10 bicycles, Transalp, 950, Ascot, 3 work benches covered in junk and a whole bunch more! I guess I never noticed the jets were from another brand of bike but upon inspection the jets were smaller bore. A narrower needle will flow more fuel but, the main jet still restricts the maximum flow at full throttle no matter how far the jet needle comes out. However the needle jet that the jet needle slides through can wear out and cause issues down the road. Or are we talking about something else? His new needle is much richer (thinner). What surprised me was they kept the stock pilot and turned the fuel screw out 3.5 turns? Looks like we'll have time to play with the jetting, I broke one of the tabs off that holds the needle retainer clip. I have it fixed good enough to test the jetting while the new one is being shipped. I don't get it close, I have to take it back apart anyhow when the new one comes in.
Michael |
01-16-2013, 07:47 PM
#6417 |
Crashing since 1964
Oddometer: 4,288
And....
I was surprised they didn't want the slide drilled. At this stage, I don't think a twitchy throttle is what he needs right now anyhow. They did give him a second spring which feels to have a lighter rate. The instructions just said it was a spare in case the other was lost That this is pretty big to get lost.
Michael |
01-17-2013, 12:55 AM
#6418 |
Insert wit here.
Oddometer: 1,275
They aren't bad on the throttle unless you really grab some go. A pressure valve shuts the accel pump off for slow throttle and med throttle rolls. Only when it needs a bunch of fuel to fight bog is when it closes the bypass and sends fuel into the carb. Pretty neat setup.
I'll read and answer the rest later. This 2am crap makes my brain have the dumb. |
01-17-2013, 03:42 AM
#6419 | |
Oddometer: 153
edhead screwed with this post 01-17-2013 at 05:45 AM Reason: edited to abide by ADV venacular |
01-17-2013, 03:47 AM
#6420 |
New Old Stock
Oddometer: 3,999
I am pretty sure the term used on this forum is fucking carnie.
At least he's not Manti Teou.
