Go Back   ADVrider > Riding > Regional forums > Central – From Da Nort Woods to the Plane States
Old 02-13-2014, 07:03 PM   #10066
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,245
Originally Posted by OhioPT View Post
Some people will just drill and tap the existing valve hole for a schrader...
I did that to the stepsons YZ250 and used air since his skill level was "severe noob"
I know you have the adapter at work, but what if you blow the shock in BFE, where there is no adapter available?
I doubt BFE would have ANY KTM parts so it probably wouldn't matter. The nice thing about the piston, it won't blow out like a bladder and it takes a while for a leaking shock to go down. I have no clue how long my shock had been seeping but the seal had quite a bit of dirt lodged in it. The bushing and the pistons seemed to be ok after all that time.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 02-13-2014, 07:12 PM   #10067
S2P
S2P's Avatar
Oddometer: 720
When I had my first couple of Yamaha DT's that were converted to dirt track race bikes.We took the springs out of the front forks, drilled and tapped the caps and installed schraders for air shocks.
My Uncle even did the mod on his 650 twin, but he tied them together with a common fill point.
"In wine there is Wisdom, in beer there is Freedom, in water there is Bacteria"...Benjamin Franklin
WR 426
TTR 125
S2P is offline   Reply With Quote
Old 02-15-2014, 03:34 PM   #10068
Mgbgt89
Mgbgt89's Avatar
Oddometer: 1,710
Ever seen a lower control arm snap in half?
The poor focus let me down last night, took out the axle too when it broke. I'm glad I had AMA roadside assistance, I was all the way down in Mansfield when it happened. Would have been an expensive tow. Looks like i'll be riding to work for a while .
Pretty cheesy design by ford, two stamped steel pieces riveted together. Trapped salt and rust inside it and broke in half. The part still attached to the ball joint is just packed full of wet rusty flakes. I'll be doing the other side as a preventive measure.
Mgbgt89 screwed with this post 02-15-2014 at 03:41 PM
Mgbgt89 is offline   Reply With Quote
Old 02-15-2014, 04:49 PM   #10069
Sp4Mike
Sp4Mike's Avatar
Oddometer: 224
Originally Posted by Mgbgt89 View Post
[IMG]
Ouch! What year is the focus?
Sp4Mike is offline   Reply With Quote
Old 02-15-2014, 04:57 PM   #10070
Mgbgt89
Mgbgt89's Avatar
Oddometer: 1,710
2001. After doing some research its a notoriously weak part. Ford upgraded it at some point, and the SVT's always had a stronger LCA.
Old 02-16-2014, 05:01 PM   #10071
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,872
Had it happen on the subaru. Turned out there was a recall, but I was glad Mala B. was only backing out of the drive when it happened.
muddyrabbit is offline   Reply With Quote
Old 02-16-2014, 05:01 PM   #10072
coolbluedab
The Frosted Ferret
coolbluedab's Avatar
Oddometer: 105
Subaru had an issue like that on similar years, the bugeye WRXs ... 2001-3 I think? Same issue. I wonder if the parts were made by the same plant?
coolbluedab is offline   Reply With Quote
Old 02-16-2014, 05:02 PM   #10073
coolbluedab
The Frosted Ferret
Oddometer: 105
Edit... for anyone with a scooby of that era... it is a limitless warranty replacement for free. Check yours.
Old 02-16-2014, 05:10 PM   #10074
muddyrabbit
Lost Boy
Oddometer: 3,872
Not the WRXs, those had aluminum control arms. All the rest though, due to faulty coating that allowed them to rust. Not just the control arm either, they did subframes on ours as well, and any part that was not in good enough condition to reuse. On ours it included the hydralic suspension bushings, and totaled up to a whopping $1600 in parts.
Old 02-17-2014, 04:36 AM   #10075
Mgbgt89
Mgbgt89's Avatar
Oddometer: 1,710
I wish i was just backing out when it happened. I was on the ramp from 71 to 30 doing 45 or 50 when it happened. Got pretty hairy for a minute.
Old 02-17-2014, 07:35 AM   #10076
muddyrabbit
Lost Boy
Oddometer: 3,872
Dayum, glad you are OK. Imagine if it had happened while you were on I71 at full speed with cars next to you.
The only reason I found out about the Suby recall was I asked someone I know who works at a dealer if I could swap in the aluminum control arms from a WRX since they are dirt cheap on Ebay. The amount of stuff they ended up replacing under the recall was ridiculous, especially for a 200,000 mile car. SO now I'm investigating good rust proofing for our vehicles. Seems like the most sensible solution is to move south.
Old 02-17-2014, 09:12 AM   #10077
SlipChip OP
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,412
Same thing happened to me at about 70 in my old microbus... Fun Times!
Chip
`92 Yamaha TDM 850
“Discoveries are often made by not following instructions, by going off the main road, by trying the untried.” - Frank Tyger
"Life begins at the end of your comfort zone." - Neale Donald Walsch
SlipChip is online now   Reply With Quote
Old 02-17-2014, 09:40 AM   #10078
muddyrabbit
Lost Boy
Oddometer: 3,872
Did you poo? I bet you pooed! I've never driven a microbus but I imagine them having some body roll as they are tall and skinny. I would have pooed.
Old 02-17-2014, 11:46 AM   #10079
SlipChip OP
Adventure Commuter
SlipChip's Avatar
Oddometer: 3,412
No need to poo when you have an angel riding on your shoulder! Otherwise I would have been swimming in the Chagrin River. The right front suspension collapsed as I was driving down Route 2 where it crosses the river, I got thrown into the passenger seat as the bus was bouncing along the guardrail over looking the river.
Chip
`92 Yamaha TDM 850
Old 02-17-2014, 02:18 PM   #10080
Mgbgt89
Mgbgt89's Avatar
Oddometer: 1,710
Best thing I've found is to get it sprayed with bar and chain oil. It kept the rust at bay on my truck decently. The truck is currently retired until i move south though. I like it too much to see it destroyed.
I'd get this car sprayed too but the lift points don't exist anymore, so i don't think my guy would feel very safe underneath it on the lift.
Times are GMT -7.   It's 11:53 AM.
