Old 09-12-2007, 09:28 PM   #1
cyborg OP
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,203
Rekluse Auto-clutch on KTM990S!
Rekluse z-Start Pro 101
Installing a Rekluse www.rekluse.com zStart Pro auto-clutch in my 2007 KTM990S!
Here are a few pictures of my recent installation of a very new Rekluse z-Start Pro for the big twin KTM (will work on any KTM 950/990 v-twin, SE, SM, SD). I did the work myself and this report is by no means a complete technical document, and is being supplied just for your curiosity. Accurate technical docs are supplied with the Rekluse kit and the KTM engine shop manual was my other reference.
First, remove skidplate then place the bike on it's left side. I didn't drain any fluids and nothing leaked out of the bike even after a few hours sitting that way. I've done the canisterectomy and proper tank venting so no problems with fuel dripping. I put a few shop towels on the floor and put the bike on it’s crash guards and rear luggage rack, nothing else touched.
Remove clutch cover
Remove pressure plate screws and springs
Remove friction plates and steel plates, paying particular attention to the last special metal friction plate and 2-part Belleville clutch boss spring – those will be going back in later per Rekluse instructions. Then remove the clutch nut remove the center hub
Here is the clutch basket empty but still in place
Note this spacer ring, do not remove it.
Install the Rekluse center hub
Rekluse says to use the stock washer and clutch nut to attach the hub
but I didn’t think the nut threaded down far enough
so I removed the washer and put the nut straight down on the steel hub with Blue Loctite. I didn’t see any problem with doing that. This was a very early kit and I’m sure Rekluse will address the issue with production kits.
Next place the first Rekluse steel plate and then the re-used special thin steel plate (blue arrow) and inner 2-piece Belleville clutch boss spring (red arrow), detailed in Rekluse instructions.
Then load the clutch pack per Rekluse instructions, steel, friction, steel friction, etc. Stock friction plates are re-used in this kit.
After all the frictions and steel plates are inserted, install the Rekluse middle hub assembly. This supports the top pressure plate assembly.
It’s important to make sure to install the thrust bearing correctly per Rekluse instructions
Here it is installed.
Next install the engagement RPM wave spring. Engagement RPM can be set using various strength springs here. Rekluse can supply various tension springs and provide a proper spring in the kit based on the average idle speed of the KTM 990/950 engine.
The ball plate
All loaded up with steel balls. A few tungsten balls can be substituted for firmer engagement action but I’ve been happy with just steel balls in a variety of riding conditions.
And finally the top of the pressure plate is fastened down with 10 screws and Blue Loctite.
All done with auto clutch assembly! There are a few steps to measure the pressure plate/friction gap for proper setting, and can be adjusted with several thickness steel plates Rekluse provides. The Rekluse instructions explain this procedure and I found it very easy to check and adjust.
Remove middle rubber damper from the clutch cover plate since it will not fit with the new auto-clutch installed.
Then put the cover back on and have fun! Oh, you will need to follow a very simple Rekluse break-in procedure that takes all of 30 minutes, cycling up and down through various RPM ranges. This is detailed in the Rekluse instructions.
Rekluse inside!
How does it work? Well, I just came back from a 3600 mile 9-day 5-state (WA, OR, ID, NV, CA) ride with it that ranged from cold mountain passes to blazing hot 6-bar days, Bonneville Salt Flats speed runs, Blackrock Desert playa running, long IronButt days at spirited highway speeds, part of the trip 2 up with full luggage on super-tight twisty mountain roads. Off-road on rough 2-track trails, whooped out roads with deep sand washes, silt beds, sharp rocks, steep rocky hill climbs and slide-downs. Did a little bit of everything except deep water crossings, mostly because I didn’t see any. The Western states are pretty dry right now. Ride report soon...
The Rekluse auto-clutch performed flawlessly! In heavy stop and go traffic having an “automatic” is awesome. On rocky hillclimbs I just popped into 2nd and chugged my way up whatever was in the path. Never touched the clutch, this unit ‘feathers’ the clutch on gnarly terrain far better than I ever could.
This is my second Rekluse zStart-Pro, the other is in my Aprilia RXV550. So far I haven’t had to do any auto-clutch adjustments after thousands of miles on either bike, with especially brutal abuse on the Aprilia RXV. All I can say is the Rekluse folks are great to work with and these auto-clutches ROCK!!
cyborg screwed with this post 06-13-2009 at 01:05 PM
cyborg is offline   Reply With Quote
Old 09-12-2007, 09:44 PM   #2
levity
nano-Adventurer
levity's Avatar
Oddometer: 1,088
Great write up Clif!
I've heard good things about the Rekluse on smaller bikes, but this is the first mention I've seen on such a beast. Looks like quality stuff.
Where'd ya order from? Don't see the 950/990 on their website.
levity is offline   Reply With Quote
Old 09-12-2007, 09:49 PM   #3
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
There are two monumental advancements in offroad technology in the past 25 years, IMHO:
Number one is the disc front brake
Number two is the autoclutch
I am a firm believer. When the going gets tough, it's tough to get going. An autoclutch takes another decision out of the task loading, and makes it more fun.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Old 09-12-2007, 10:02 PM   #4
cyborg OP
cyborg's Avatar
Oddometer: 5,203
Thanks. I got it from Rekluse direct. This was a beta unit, #2 unit built and first tested on an Adventure model. Call them. They should be ready now.
Old 09-12-2007, 10:05 PM   #5
Ignore Amos
bruised, dazed & confused
Ignore Amos's Avatar
Oddometer: 981
I have a Rekluse in my 300 and 525...I could see why it'd make sense in the 950seR as well...shit, need to make more money!
Thanks for sharing!
Ignore Amos
Women love men with big KTMs
07 BMW 1200 GS Adventure
07 KTM 950R Super Enduro
08 KTM 530 XCWR
09 BMW G450X
BITD 066
AMRA 54S
SCORE 22X
Ignore Amos is offline   Reply With Quote
Old 09-12-2007, 10:17 PM   #6
Scootr
Scootr's Avatar
Oddometer: 29
New to auto clutches
Interested to see more opinions on this. Sounds good, but how well doew it really work?
Scootr is offline   Reply With Quote
Old 09-12-2007, 10:50 PM   #7
buzzardair
Shrubbery Adventurer
buzzardair's Avatar
Oddometer: 293
Very good write up. Seems like a great idea especially for commuting in heavy traffic.
I look forward to hearing more about it's manners off road.
buzzardair is offline   Reply With Quote
Old 09-12-2007, 10:59 PM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,967
Great write up. Thanks cyborg for the photomanual.
What was the price you had to pay?
thnx for spreading the info around.
Another question for cyborg is: Did you hav a problem with the OEM clutch system? Did it drag or was it a step towards a better world? Cheers.
gefr screwed with this post 09-12-2007 at 11:22 PM
Old 09-12-2007, 11:04 PM   #9
The Cheat
Tard
The Cheat's Avatar
Oddometer: 300
can you still use the clutch lever? If so do you have any need? I have heard of people taking the clutch lever off and replacing it with a rear brake lever. Do you think this would be applicable to the 950?
I have considered putting an auto on my 450 EXC, but until I ride one I don't think I will take the leap. On a scale of 1 to 10( 1 being "I can barely tell the differance" and 10 being "Holy shit this makes me one fast BA" how would you rate the auto clutch?
BA= Bad Ass
BAMF=Bad Ass Mother Fucker
The Cheat is offline   Reply With Quote
Old 09-12-2007, 11:24 PM   #10
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
One thing i dont trust with them is slipping of the clutch. I want to know when my clutch is cooked so i can let it cool.
With the rekluse you would lose the feel of the clutch and it will slip itself to destruction.
I've experienced this with other rekluse owners, one on a 450exc his clutch plates seized to exist.
In regards to them making you faster? Don't think so. It will make the riding through challenging terrain that much easier, especially hillclimbs.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 09-13-2007, 12:15 AM   #11
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,121
Edit to add: Nice review and install photos!
I love the rekluse concept and would be an owner.
I rely very much on engine braking riding the big bikes. I don't remember there being much, if any, engine braking on the rekluse equipped 450smr that I rode when I chopped the throttle. I would love the auto engagement effect on a nasty take off, but not at the cost of my engine brake. Maybe someday I'll learn enough rear brake skill to not need the engine brake, then I'll be set.
The engagement spring effect reminds me of the one in my snowhawk clutch. The Rekluse spring construction is far more sophisticated than mine, which is just a coil, but they both can be replaced to provide different rates of clutch engagement.
Glad to see them making one for the LC8.
snowhawk jockey is offline   Reply With Quote
Old 09-13-2007, 06:06 AM   #12
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
The rekluse does have normal engine braking until you stop,if you roll forwards there is NO engine braking until you 'blip' the throttle when you will then have engine braking again.
I have rode one(on a 450exc) and i want one,but here in UK they are like twice the price of US prices.(if you get a PM off me asking you to buy me a reklu......)
What i am interested in,is the fact that one cannot get clutch slave failure from this method? Is that correct?
Can someone confirm this?
If so,it's great and i am gonna start looking into one.
Thanks to the origional poster.
In fact,thanks to everyone on Orange crush.
BLUE(UK) is offline   Reply With Quote
Old 09-13-2007, 06:21 AM   #13
GSBrushy
Oddometer: 28
Hopefully all motorcycle manufacturers will start offering automatic transmissions as an option.
Just think of the reduction in skill level required to ride !!
The transformation to scooters will be much easier for riders using an automatic.
GSBrushy is offline   Reply With Quote
Old 09-13-2007, 06:42 AM   #14
apeirce
So I was following Andrew
apeirce's Avatar
Oddometer: 2,722
Thanks for the write-up.
It seems very cool. I think the biggest problem for Rekluse is that people are very skeptical about them, and that at the price, they are not really a whim purchase.
I'd have to ride one before I bought, and I don't know of any opportunitty to do so. If they are that good, I wish them all the success in the world.
I have friends, and I know other motorcyclists. But truly the best are friends who are motorcyclists.
apeirce is offline   Reply With Quote
Old 09-13-2007, 06:48 AM   #15
tn-steve
Addicted
Oddometer: 1,593
Great write up
Great write up and outstanding pictures! Thanks for taking the time to do this.
tn-steve is offline   Reply With Quote
Times are GMT -7.   It's 07:37 PM.
