09-13-2007, 08:18 AM
#1 |
Sven from Road Rash
Oddometer: 223
VIN plate on airhead
I just bought a titled frame, the vin matches the frame on the lower half. however there is no vin plate on the head tube. Is there supose to be on there?
09-13-2007, 09:21 AM
#2 | |
takin' a break, boss
Oddometer: 1,761
airhead aficionado |
09-13-2007, 10:09 AM
#3 |
Sven from Road Rash
Oddometer: 223
I have a 1987 R80. I just have a vin stamped on the bottom of the frame.
09-13-2007, 10:15 AM
#4 |
1:1.618
Oddometer: 4,794
My '71 & 74 have VIN plates on the neck.
I must work, millions of losers are depending my taxes for a check. |
09-13-2007, 12:08 PM
#5 |
Wacky Bongo Boy
Both my 74's have VINs on plates on the neck.
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
09-13-2007, 12:36 PM
#6 |
out there & loving it
Oddometer: 481
According to my manual the VIN moved downworth somewhere around 1980isch
[Sir Mix-a-lot mode] I like big tanks and I cannot lie [\Sir Mix-a-lot mode] |
09-13-2007, 01:11 PM
#7 |
Sven from Road Rash
Oddometer: 223
Cool, thanks for the research, I appreciate it.
09-13-2007, 03:12 PM
#8 |
Middleweightboxer
Yes - the plate was replaced with a perforated aluminum sticker on the right side frame loop under the jug/footrest is my memory serves me.
Bill Tiger 800XC, R1, FZ1, RD400, CB400F R80ST, R90S, Monster S2R, Penton 125 JPS, T25T |
09-13-2007, 03:14 PM
#9 | |
God Bless Texas
Oddometer: 1,469
Todd R. '78 R80/7 '06 FJR1300A "Gentlemen, gentlemen, be of good cheer, for they are out there and we are in here!" - Robert Culp, attributed by Hugh Hefner as the official slogan of the Playboy Mansion |
09-14-2007, 12:55 AM
#10 |
Oddometer: 481
Just had a closer look, the VIN# moved from the neck downworth in 1983,
the alu plate moved at the same time from the front of the neck to the side-plate at the neck. No idea if something changed later on, this is what I can see in the manual and the frames hanging around here. But still, what frame have you got over there, tell us?
09-14-2007, 02:49 AM
#11 | |
Heavyweight Boxer
Oddometer: 4,758
my '92 still has that side plate. |
09-14-2007, 10:25 AM
#12 |
Sven from Road Rash
Oddometer: 223
I have it stamped on the frame so I think I am fine. I am just worried about border crossings.
09-14-2007, 09:54 PM
#13 |
Oddometer: 255
snoop
ON a newer BMW ( I believe 1981 on) there are TWO vin numbers ( one is called by the DMV as teh "secondary Vin" ON these Bmw's they can be stamped on right frame next to brake shifter and they ALSO use a perferated alu stick on stamp some times they are just ahead of the stamped #'s right under the Carb. They can also be on the swing arm on the right side near bearing . Check further where they should be. BMW will order new stick on Vins for you as they finally realized thet having them under the cyl right where your toe hits the frame is not a good idea and they werar out. YMMV Chuck |
09-15-2007, 01:14 AM
#14 |
Friend.
Oddometer: 5,210
that 'alu sticker' you guys keep ref'ing is anything but Alu. It's a plastic/vinyl sticker with dot-matrix perf'd numbers-- that sumbitch proved a sticking point when i had the G/S tagged in FL for the first time. On the right lower frame tube (under the R jug) it had apparently been gouged by rocks, stumps, roots etc and some of the numbers were munged. The tag lady decided it was her duty that day to morph into Super-Fly and get all medieval on my ass-- she just knew i was trying to wreck America by sneaking in a BMW G/S with 2 VIN digits obscured.
I pointed out that the stamped VIN with the 2 little stamped BMW roundels on the right steering head gusset agreed with the munged sticker, but she would'nt have a bit of it. With much super-lifer fanfare she called in her supervisor who said "This is OK. What's the problem?". Back to orig querry: VIN's are all over the map on airheads. I know from personal ownership that up to 77 there was a riveted VIN plate with 'made in Western Germany' fastened to the right side steering head gusset-- the VIN was also stamped into the space above the oil dipstick on these. That all stopped in the late 70's, early 80's when the silver sticker started. Some got the sticker under the right jug on the frame (like my G/S), later ones got the sticker on the swingarm -- the fully faired RS/RT's are the ones i've seen this on, but i've also seen some unfaired monolever R80's with swingarm VINs.
06-07-2010, 07:14 AM
#15 | |
Oddometer: 171
replacement Vin sticker
old thread, new question,
I'm missing the Vin sticker on my '82 R65 and have moved, my new state's DMV wants to see the Vin. Has anyone been able to order a new Vin sticker from BMW? Quote:
