Old 09-14-2007, 10:42 AM   #1
Stretch67 OP
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,626
High-Mount Front Fender For 1999-2006 Tigers
Okay Gents, here we are...
In stock form, there is one brake hose from the front brake master cylinder to the front left caliper, then a short crossover hose from the left caliper to the right. This crossover hose needed to be eliminated in order to properly mount and utilize a high-mounted motocross-type front fender.
First to be dealt with was the removal of the front brakes crossover hose, which links the front left caliper with the front right. I decided to utilize a full-length hose for each caliper, with the hoses stacked at the master cylinder.
All this required was swapping the 31mm double-stack banjo bolt on the left caliper with the single-stack 22mm banjo bolt on the master cylinder.
Then I ran a full-length hose to each caliper, with a hose running along each fork leg.
Like this, but with a bike attached to it.
Before...
And after.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 04-05-2009 at 04:12 PM
Stretch67 is offline   Reply With Quote
Old 09-14-2007, 10:51 AM   #2
EagleFeather
Flyin' High
EagleFeather's Avatar
Oddometer: 2,227
Stretch, you ROCK!
Uhhhh........I'd like to place my order for the fender brace and spacers....
You tell me how much and I'll send it....plus some local Boulder micro-brews!
Where did you get the other full length brake line? Dealer or somewhere else?
Also, did you use the existing threaded holes on the underside of the tripleclamp? What size screws did you need?
That will look awesome with some knobbies! Can't wait!
"You know I've had too much RedBull when my pee smells like gasoline" - Geek
Surf the World
www.couchsurfing.com
Motorcycle Travel Network
www.motorcycle-travel.net
save $5 on your SmugMug subscription - use coupon code RzTdQ4pMyqEuU - www.smugmug.com
EagleFeather is offline   Reply With Quote
Old 09-14-2007, 10:59 AM   #3
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,626
I've put together a kit which includes the fender (black, red, or silver), mount and brace (which is designed and hand-made for this specific fender), the machined-aluminum spacers, another long brake hose, crush washers for the brake hose fittings, and every nut and bolt (in stainless).
Link to "Vendors": http://www.advrider.com/forums/showthread.php?t=267428
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 02-16-2008 at 09:21 PM
Old 09-14-2007, 11:01 AM   #4
Chad M
Custom User Title
Oddometer: 786
It's a good thing you don't have TKC's mounted, my computer isn't drool proof! Nice job Stretch. Now just figure out how to apply a silver film to the windscreen (I've tried, it's tough) and I'll move you into "Tiger hero" status!
Chad M is offline   Reply With Quote
Old 09-14-2007, 11:18 AM   #5
DireWolf
Knees in the Breeze
DireWolf's Avatar
Oddometer: 13,323
Originally Posted by Stretch67
DireWolf is offline   Reply With Quote
Old 09-14-2007, 11:21 AM   #6
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
Originally Posted by DireWolf
Nice...very nice.
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 09-14-2007, 11:22 AM   #7
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
What I'm planning on doing is putting together a kit which would include the fender, mount and brace (which is designed around this specific fender), the machined-aluminum spacers, another long brake hose, crush washers for the brake hose fittings, and every nut and bolt (in stainless).
The kit will run a bit less than $200, and will include everything needed to bolt right on to a Girlie.
Those who would be interested in buying said kit should PM or e-mail me, as I don't want to spam the boards here.
Spam my ass...post it in Vendors along with pictures of what you did...we got your back.
Old 09-14-2007, 05:03 PM   #8
Mudhen
Foul Adventurer
Mudhen's Avatar
Oddometer: 3,250
Just plain awesome.
"Triumph over adversity is good for the soul." -- Packmule
IBA# - 18804
Bikeless
Mudhen is offline   Reply With Quote
Old 09-14-2007, 05:47 PM   #9
mrk00k
Oddometer: 36
I want, I want!!
mrk00k is offline   Reply With Quote
Old 09-14-2007, 06:35 PM   #10
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,626
Originally Posted by Mudhen
Just plain awesome.
Thanks, Bro. Your badass Steamer is partly to blame for all this. Your bike is kickin'!
IBA # 33113
Alaska
XR400 Index
Old 09-14-2007, 07:26 PM   #11
Sock Puppet
Dirty again
Sock Puppet's Avatar
Oddometer: 481
Just great! Another mod I didn't know I needed until I saw it!
Your kit is on my list of things to ad, so please let us know when it's officially available!
It is better to burn out than to rust out.--Richard Cumberland
The farkling quest continues...
Sock Puppet is offline   Reply With Quote
Old 09-14-2007, 09:18 PM   #12
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,626
It is available.
PM sent.
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 09-14-2007 at 09:27 PM
Old 09-15-2007, 08:34 PM   #13
Jet Jaguar
King of the poseurs
Jet Jaguar's Avatar
Oddometer: 349
What fender is that, if you don't mind my asking?
-Jet Jaguar
It's not an adventure unless you need a tent, a passport, and a leather glove for your shooting hand.
'05 Suzuki DL650 V-Strom
Jet Jaguar is offline   Reply With Quote
Old 09-16-2007, 06:52 AM   #14
EagleFeather
Flyin' High
Oddometer: 2,227
I believe its the Acerbis Technic fender.
Surf the World
Old 09-16-2007, 07:21 AM   #15
mudbogdad
mudbogdad's Avatar
Oddometer: 166
DireWolf that is so cool! you the man!
I think I just found my next project.
Running the dual feed on the brakes didn't change the braking?
Thanks for posting up the pics.
Your an inspiration.
mudbogdad is offline   Reply With Quote
Times are GMT -7.   It's 05:48 AM.
