| Welcome, lurker! Even if you don't post, the system can help you find the good stuff faster if you register. |
Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Oddometer: 422
Adventure/camping fold-up Rifle .22/410 scout M6
Enclosed is a walk thru development of the Springfield M6 Scout rifle. The intent of the modifications is to create a survival rifle which can be carried discretely in my pannier box on the KLR650. The rifle shoots both 22LR and .410 shotgun shells. It breaks down into 2 halves quickly and contains ample storage space for a few survival items. The gun barrels are 18.5 inches in length and if scope mounted is a known “tack driver”. These “combo” guns are out of production and hence, no longer available. I have seen them in used condition for sale for $200 to $800.
![]() Rifle ready for modifications ![]() Aimpoint scope at 1x power with 2x adapter if required. Off of E-bay for ~$55. ![]() scope mount ![]() .410 iron sight ![]() transition to .22 sight ![]() .22 bead sight ![]() markings on reciever ![]() trigger guard....Need to remove this item. Notice hammer is release by squeezing the trigger ![]() as removed ![]() butt stock storage cavity 15x .22 shells + 4x .410 shells (up to 3 inch) ![]() .22 barrel diameter ![]() .410 barrel diameter ![]() receiving end ![]() measure circumference of barrel ![]() mark ![]() cut ![]() apply self adhesive backing camo decal ![]() nice and tight finish ![]() repeat for the .410 barrel ![]() like so.... ![]() articulated into storage position ![]() add some of thet bed liner to the bottom of the .410 barrel so, it will not scuff when resting on ground ![]() remove the shell holder ![]() remove stock top lid ![]() pull out and off to the band saw! ![]() need to take advantage of this large cavity ![]() trim away the butt stock ![]() chuck the trimmed part on the left ![]() reinstall butt plate ![]() camo trace ![]() manually trim holes ![]() apply decals ![]() attach scope ![]() went crazy with the decals! ![]() snap cap dummy rounds for trigger practice dry firing ![]() will keep shells here ![]() cut, velcro and attach ![]() on right side 6x shell capacity ![]() looks good so far ![]() back rack of KLR650 ![]() will keep this as fire starter (+waterproof tinder) ![]() won’t fit too wide ![]() off to band saw ![]() that’s better ![]() use laser for scope sighting ![]() down barrels at neighbors house ![]() use as waterproof container ![]() add decal ![]() add fish stuff ![]() .410 options #7.5 shot + # 4 shot + slug options ![]() exposed rounds ![]() .22 options Stinger LR hollows + CB shorts. The CB’s are very quiet ![]() almost done ![]() butt plate stock open ![]() attach button compass to stock ![]() compact stowed position ![]() another view ![]() fit in KLR Happy trails pannier easily ![]() plenty of room ![]() weight of barrel+ scope ![]() weight of reciever full up 6x .410 shells + 30x rounds of .22 ![]() attached compass ![]() velcro’d shell holder + fishing container ![]() close-up of decal work ![]() hammer + hammer safety ![]() pin joint ![]() top latch release button ![]() included survival stuff ![]() when stowed ![]() in sil-net waterproof bag Now I can take this plinker on backwoods excursions and hide in locked panniers without worry. Complements the KLR. Easy to shoot and meets my expectations. Keith |
#2 |
Oddometer: 2,861
Very nice job you've done.
I used to carry an Armalite AR7 .22. In theory, a good survival rifle. In practice, it jams a lot and is not very accurate. Yours is the better choice. |
#3 |
gregg
Oddometer: 159
I did not know it was not made anymore.
I would give a thought to having a 22 Mag reamer run into it. Would not cost much to do and being a single shot its not like you be burning alot of shell thru it. If needed would give you a big power jump. Just a thought OBTW They use to make this little jew in 22 mag and look like it could be the bee's knees for a bike. Stainless steel and 16.5 barrel. and breaks down with one knob that screws out. Only comes in 22 LR now. http://www.taurususa.com/products/gu....cfm?series=C3 ![]() Last edited by gregg : 09-21-2007 at 06:01 AM. |
#4 |
On dry land 4 now.....
Oddometer: 1,507
Wow, Great job.
If you ever want to build another or part with it, let me know! I want one.......
Arggh ya scurvy dogs, thars piratin to be done! ![]() Let's Ride........ 2006 KTM 450 EXC For the dirt 2002 Gas Gas 280 TXT For slow falling 2001 BMW 1150 GS For the twisties and no its not a dirt bike 1989 R 100 GS & Ural sidecar RIP Elvis 10-20-2009 Always in my heart 1971 TS185 Suzuki Project Smething! KE6DYN If it's tourist season, why cant we shoot them?
#5 |
Cheap and Easy
Outstanding!
The Place to find the Center is at the Edge ![]() |
#6 |
drive-by poster
Oddometer: 4,798
nice.
I got my son this matched set, a break-open single shot with three barrels - .22, .243, 20 ga. for Christmas for $267 when he was just old enough to shoot but now he prefers a bigger rifle. I may turn it into my pack rifle. not as light as yours as I'll have to tote two (or more) barrels but it wouldn't seem to be too cumbersome for the bike. http://www.rossiusa.com/products/pro...ory=MATCHEDSET
. "having dreams to look forward to slows time..." -- Freeflow . |
#7 |
Road Captain
Oddometer: 6,755
Great conversion!I always wanted to try something like that with a Savage model 24C "Camper" version, similar to this one but in .30-30/12ga:
FatChance Slim Pain in the Butte Ranch Durango, Colorado - I don't want a pickle, I just wanna ride on my motorsickle... |
#8 | |
Oddometer: 422
Do you know the length and weight of this setup? Seems like a 20 gauge would be a good survival gun choice.
Keithm Quote:
#9 |
Ribs....for her pleasure
Oddometer: 2,476
Nice nice job. I always liked that little M6.
_________________________________________ Well, this oughta be good.......
#10 |
Oddometer: 422
#11 |
Get Out and Ride!!
Oddometer: 2,758
Very nicely done.
Disclaimer
#12 | |
wannabe
Oddometer: 3,758
The YOUTH combo version is what you want, it has the lighter receiver. Still not light. but it comes with a soft case that will fit in a pelican 1550 easy enough. I think the 3 barrel version (22, 20, plus 243) would come in around 12 pounds with 2 scopes. I am up to 3 rossi's in the safe. not a great rifle, but a respectable trigger and a super bargain. I have $500 or less in all three of them including scopes--you can afford to let them get banged around. The one I have wanted for a survival gun would be a 45-70 and 410 combo. 410 is great for rabbits and such. A 20 gauge gets it done, the shells are probably cheaper, but they are so much bigger and heavier to carry.
"I reject your reality and substitute my own" -Adam Savage "random chance is an occurrence of linear time" -Woods Walker "zen-like in it's near perfect balance of imperfection" -me |
#13 |
Earth Bender
Oddometer: 23
KLR4755,
Very nice job! I'd like one. Too bad they don't make them anymore. |
#14 |
Oddometer: 422
Try a gun auction web site such as:
http://www.gunbroker.com Type in m6 scout in the search line. They have 2x M6's (one is the stainless steel model 22 hornet model) up for auction right now for ~$500. Keithm |
#15 | |
drive-by poster
Oddometer: 4,798
