Old 01-09-2011, 08:08 PM   #1786
Psycho18th
Oddometer: 433
Was the stock chain an O-Ring without a master link clip?
I'm selling my '98 and the potential buyer tells me the stock chain was a riveted o-ring chain without the master link and clip. Since my bike has a master link, clip and no O-rings, he's telling me the bike has more miles on it's than showing on the odo...
I thought the stock chains were the little steel 428s with a master link and clip.
Haven't replaced the chain on this bike, but maybe the previous owner did?
Psycho
02 DRZ400E Dualsported in AZ
14 KTM 250 XCW (Plated in AZ)
85 HON XL80S (Wife's ride)
00 and '07 YAM TTR 90s (kids' bikes)
89 Lockheed F-16C (Work vehicle )
Psycho18th is offline   Reply With Quote
Old 01-10-2011, 09:59 AM   #1787
SkidMarx
SkidMarx's Avatar
Oddometer: 2,170
Originally Posted by webmonstro View Post
1 No timming light is needed jut get the T mark on the magneto lined up then the cams then put the chain over the cams
Then slide in the cam guide in (front of the engine) then push the cam tensioner in and recheck the timming marks
there is also a cam chain guin in the middle of the cams
2 it goes in the front of the motor it's held buy the cam cover
3 remember to rechecj the timming after all is installed and kick over one
I did this twice as the brand new OEM base gasket did not last (made one myself out of gasket paper still working fine)
You can save yourself a little trouble by using a screwdriver to push in the rear chain guide to check the marks before installing the tensioner.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 01-10-2011, 10:04 AM   #1788
SkidMarx
SkidMarx's Avatar
Oddometer: 2,170
Psycho
I don't remember ever having to use a chain breaker on my bike.
I'm pretty sure they came with a master link. The OEM Parts diagram shows a master link too.
It was definitely not an o-ring chain.
'90 XT350
'08 WR250R
GLDS
Old 01-10-2011, 11:27 AM   #1789
cjm1219
cjm1219's Avatar
Oddometer: 107
Quick question.
Bike is running like a champ....but.
Getting white smoke at startup. Clears out in a minute or so. Doesn't come back untill the motor has completly cooled.
cjm1219 is offline   Reply With Quote
Old 01-10-2011, 12:34 PM   #1790
SkidMarx
SkidMarx's Avatar
Oddometer: 2,170
Originally Posted by cjm1219 View Post
Quick question.
Valve seals.
When the bike is sitting , the oil leaks down past the seals into the intake or exhaust tract and pools there. It then burns up at start up.
You have to have a valve spring compressor to change them.
If you are comfortable removing and replacing the head, just pull the head and take it to a local shop. It should only cost you 1/2 hr shop rate. It's also a good idea to get the valves lapped.
You will need to reset the valve clearances.
You can ride it like it is, but I wouldn't let it go too long.
'90 XT350
'08 WR250R
GLDS
Old 01-11-2011, 09:24 AM   #1791
cjm1219
cjm1219's Avatar
Oddometer: 107
uh oh.....This sounds like may blow my theme of "cheap" on this bike.
Not sure if i am comfortable removing the head. Haven't done it. Is it hard to do?
I need to buy a manual.
Originally Posted by SkidMarx View Post
Valve seals.
Old 01-11-2011, 11:33 AM   #1792
SkidMarx
SkidMarx's Avatar
Oddometer: 2,170
Now that I think of it, you may want to get a dealer price on replacing the seals. With the right tools, they may be able to do it without removing the head.
Otherwise, removing the head is easy. Putting it back on properly is the hard part.
This is a pretty easy bike to learn on though.
'90 XT350
'08 WR250R
GLDS
Old 01-11-2011, 08:14 PM   #1793
Psycho18th
Oddometer: 433
Removing the head is a pretty easy task. Clymer manual will walk you right through it. Plus, if you have any questions, the guys on this board will hook you up almost instantly.
Psycho
Old 01-11-2011, 08:28 PM   #1794
Psycho18th
Oddometer: 433
No more XT for me (for a while)
Well,
I sold my '98 XT yesterday. Kind of a sad day. My folks bought me my '93 brand new as a high school graduation gift. I rode it all over Colorado, Oklahoma, Texas, Arkansas, Arizona, and Alaska as the Air Force moved me around. I crawled many rocky singletrack miles in CO, through the really tight twisty trees in Eastern Oklahoma, several enduros on the BJEC and TSCEC, on highways, interstates, sand dunes, and the deserts of Arizona. I finally traded up for a low mileage '98 last year, and enjoyed riding that one as well. While the carb was annoying, and the airboots often needed replacing, that bike could go anywhere on dirt or street at any time, absolutely reliable. When miles from nowhere, completely alone, with nothing more than the stock Yamaha toolkit, you were rarely in danger of being stranded with that bike. A quick read of the Clymer manual and a few simple hand tools, you could fix almost anything in an evening or two in the garage.
I'm going to give it a run on my dualsported '02 DRZ400E for a bit. I bought it non-running for a steal, and fixed it up as a decent dualsport bike. Suspension is it's only real advantage. I'll miss that 6th gear and ickstarter the most. So, I'll likely be off on the DRZ thread more often than not, but I may end up back here yet in a couple of years. When I unloaded the XT at it's new home, and it fired in one kick stone cold, and just sat there purring at me, I almost took it back home for good.
Psycho
Old 01-12-2011, 06:56 AM   #1795
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 263
See you around Psycho don't be a stranger.
I got mine going again, no idea what it was. Put everything back together and it started. Thanks for the tips and links though they provide some info for later.
PCK_4xCustoms is offline   Reply With Quote
Old 01-12-2011, 03:15 PM   #1796
Draechon
Draechon's Avatar
Oddometer: 1,315
Put the finishing farkle on my setup today, the ugly, but functional topbox
I wish my motorcycles had real model names for when I get asked what I ride.
Draechon is offline   Reply With Quote
Old 01-15-2011, 05:39 PM   #1797
truck6driver
The Fireman
Oddometer: 7,463
Well fellows it seems that I was the victim of a scam. the XT350 I had picked up and repaired had bogus paperwork. The DMV sent me a letter stating that my title app. was denied and the bike was stolen.
Well I kept every e-mail and peice of paperwork including Phone #s on the deal. The LOE's have all they need to arrest the guy now, but I'm out a bike.
I had picked up some parts for it during my fix up stage and will pass them on to a fellow XT rider for cheap if anyone needs them. Not looking to post up in flea market as they are not hurting anything on the shelf. But if anyone needs what I have I will entertain offers by PM.
rear shock
both cam shafts with gears
front fender (rough shape though)
new brake shoe return springs
new brake line copper washers
Thanks guys.
Ray
When the system fails you, what then?? Do you fight it or just surrender and give up? If all seems doomed what is left to fight for? Is it just me or does the world seem to close in on you when you seem to be making ground? Options are dwindling down, what comes next? And in the words of Pink Floyd "Is there anybody out there". All I know is I WILL SURVIVE.
truck6driver is offline   Reply With Quote
Old 01-15-2011, 05:58 PM   #1798
Caffeinatedcyclist
Oddometer: 9
Alright, since my last post I have cleaned the carbs, installed the timing chain, cams, and set the timing. I also installed the tensioner, new air filter, new oil filter, installed various new gaskets, etc. The only thing I need to figure out is where the lines go on the carbs. I know where the fuel line goes and the placement of the small line at the bottom of the float bowl but I have two more that I don't know the placement of. I can't figure it out from my manual. If anyone has a good pic or describe it please post up thanks.
Caffeinatedcyclist is offline   Reply With Quote
Old 01-16-2011, 02:17 PM   #1799
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 567
Does this help ?
Most likely there vent lines ? THink that there are 3 vent lines, one on the bottom two on the sides (Not near my bike now)
Nuno
webmonstro is online now   Reply With Quote
Old 01-16-2011, 06:04 PM   #1800
Caffeinatedcyclist
Oddometer: 9
Thanks to everyone thats helping me fix this bike. Thanks for the diagram Webmonstro. It does help me understand the carbs better. I actually found a better manual than the one I started the build with and bought it. It's got the same tear down diagram in it. I still cannot tell the routing of the hoses for certain from the manual. Im posting a pic (sorry its a crappy iphone pic, im working on sourcing a better camera) so anyone feel free to shout out if something looks wrong.
Times are GMT -7.   It's 12:37 AM.
