Old 08-06-2011, 01:13 PM   #2476
mharizanov
Oddometer: 12
Thanks, I tried that today. The bike is louder and just slightly more powerful. It is quite hard to judge. I am a fan of stock bikes and would drill holes only if would make a whole lot difference, which I think is not the case.
I will try thinner oil on the filter as I used YAMALUBE 20W50 on it and suppose it is a bit too dense for an air filter.
mharizanov screwed with this post 08-07-2011 at 12:06 PM Reason: wrong oil type
mharizanov is offline   Reply With Quote
Old 08-07-2011, 10:53 AM   #2477
yzergod
yzergod's Avatar
Oddometer: 61
Anybody have any thoughts as to why the tail light/stop lamp quit working? Not the bulb. Hidden fuse I don't know about?
Death to Mendicants! - Groo the Wanderer
yzergod is offline   Reply With Quote
Old 08-08-2011, 04:40 PM   #2478
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 559
no fuse
only two switch one on the front leaver one on the pedal
Nuno
webmonstro is offline   Reply With Quote
Old 08-10-2011, 02:19 AM   #2479
AndreMare
Oddometer: 6
xt350 side covers
Good day sport fans,
Does anybody have a left and right side cover(the plastic covers) for the xt 350 that they would like to let go to a special home?
AndreMare is offline   Reply With Quote
Old 08-10-2011, 07:31 AM   #2480
Grreatdog
Grreatdog's Avatar
Oddometer: 11,059
To each his own. You said you wanted the lost power back. Well, to be frank, a stock XT350 is so restricted it does run like a 250. A rather weak 250 at that. If you want the lost power back then you need to remove the restrictions. The number one restriction is the tiny airbox opening breathing up under a seat with few openings for air.
If you are worried maintaining the original parts of your XT350 then buy another airbox cover and drill that one full of holes. It isn't really louder when you drill a bunch of small holes and put the sdecover back on. You want a stock then you ride a slow bike. You want more power then you modify it. You can't have it both ways with that bike.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 08-10-2011, 07:24 PM   #2481
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
One word of warning concerning the 50 air filter.
It sucks and if you open it up and the rear tire starts tossing crap where it can get to the filter, be prepared for a rebuild.
I changed my seat for an XT225 Corbin seat and the 225 seat pan sits higher and allowed the rear tire to toss mud, gravel, water, and even a stick into the airbox opening.
I would suggest adding a second foam filter of some kind in front of the OEM one to cure this issue if you open it up wrong.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 08-11-2011, 12:15 AM   #2482
mharizanov
Oddometer: 12
That's unpleasant to read , but motivating me to do the drilling :) Probably I will add some kind of metal net/grid to prevent sticks and gravel from going in the box as suggested. My bike is European one, so the supposedly 27hp version (engine 55V2).
Anyway - Thanks for the tip. Any other tips to let the beast out?
Old 08-11-2011, 06:03 AM   #2483
Grreatdog
Grreatdog's Avatar
Oddometer: 11,059
I drilled my airbox cover only so all the holes were under the side cover using several rows of 1/4" holes. It never picked up any crap that way. The filter did get dirty a lot more quickly. But I was pretty diligent in oil changes and filter cleaning. Which might be why the original filter lasted from 1986 until 2003 even with all the extra air flow.
The only issue I ever had was with one creek crossing I used to ride a lot. That thing was too muddy to wheelie into and up to the seat. So your only option was to chug through it tank deep and pray. On that trail I covered the holes with duct tape to keep from drowning the bike. It got drowned there a couple times but not from those holes.
I actually did buy a second airbix cover and never used it. I sold it still in the plastic Yamabag when I parted out the bike. I also bought a second airbox cover for my XT200 back in 1982 because I drilled that airbox too. It is still sitting in my garage unused. Just like the XT200.
Old 08-11-2011, 02:53 PM   #2484
chef larry
Oddometer: 28
Moto Stand
Any suggestions on how to put the bike up on the moto stand with one person or are two people better?
chef larry is offline   Reply With Quote
Old 08-12-2011, 05:49 PM   #2485
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
I do it alone all the time.
I just grab it towards the rear of the seat, and lift it up on the stand leaving the front wheel on the ground so I'm only lifting the rear.
Old 08-13-2011, 04:56 PM   #2486
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
It runs.....
For those that have been curious.......
I finished the shop remodel this morning.
Before: Just a pole barn, no ceiling and tin walls.
Then I got to work on the 350, and got it started.
New timing chain, rings and gaskets.
Started 2nd kick.
I was a little concerned I night be one tooth off on the crank after installing the timing chain tensioner but it wasn't or else I would still be there kicks.
Glad to have my two wheeler back again.
Old 08-13-2011, 05:19 PM   #2487
chef larry
Oddometer: 28
Started 2nd kick.
Your shop looks nice with all the space to work on the bikes in the pictures with plenty of room out of the weather to finish all your projects.
Old 08-14-2011, 09:58 AM   #2488
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Question Rims
I have an idea for my junk, so I am looking for a pair of wheels. Stock rear, and a front laced on an 18" rim is what I want to end up with. Anyone have a pair laying around that they would sell me, super cheap??
Justin Calkins - Iowa Falls, Iowa USA
1973 Yamaha DT3 - 250 - FOR SALE
Boss Framed Yamaha RT3 Flat Tracker - FOR SALE
2007 Triumph Bonneville America - 865
Calkins is offline   Reply With Quote
Old 08-14-2011, 01:55 PM   #2489
George 99
George 99's Avatar
Oddometer: 778
Andre, send me a PM. I have the stock set from my 96(?), mainly blue. Right side is burn damaged at the rear/bottom but is still serviceable. Yours for cost of shipping if ya want them.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 08-14-2011, 05:10 PM   #2490
tclark968
M.O.A.
Oddometer: 2
1998 XT350 Passenger pegs
If someone has a pair of rear passenger pegs let me know. Mine is missing them. thanks
tclark968 is offline   Reply With Quote
Times are GMT -7.   It's 10:23 AM.
