Old 05-13-2013, 01:22 PM   #3361
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Shiny
NordieBoy is offline   Reply With Quote
Old 05-14-2013, 02:36 PM   #3362
Brutus62
Oddometer: 9
XT Rebuild
Any one ever reiforce the rear frame so you could carry a little more cargo out back without getting very expensive after market racks?
Brutus62 is offline   Reply With Quote
Old 05-14-2013, 08:52 PM   #3363
bajashaw
Oddometer: 4
front brake rotor
my '85 needs a new front brake rotor and I am only finding OEM Yamaha (not very cheap) any one have other suggestions?
bajashaw is offline   Reply With Quote
Old 05-15-2013, 12:12 PM   #3364
Erock65
Erock65
Oddometer: 12
Carging problems
Does anyone have any info about the charging system? I am having to put mine on a trickle charger about every 3 or 4 days.
Erock65 is offline   Reply With Quote
Old 05-15-2013, 06:30 PM   #3365
SkidMarx
SkidMarx's Avatar
Oddometer: 2,251
Why? It isn't needed. My battery has been dead for years.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 05-16-2013, 08:55 AM   #3366
Erock65
Erock65
Oddometer: 12
My tail light, brake light and blinkers won't work without the battery charged
Old 05-16-2013, 09:13 AM   #3367
Grreatdog
Grreatdog's Avatar
Oddometer: 11,957
True. But you don't need much more than a big capacitor. I ran a tiny little lawn mower battery in mine.
First question: does your headlight work? If your headlight works then the charging system works. The headlight runs directly off the generator and through the regulator/rectifier. So if it works both of those should be working.
So, if the headlight works, it is likely either a weak or damaged battery or a secondary issue like a corroded ground, bad ignition switch, loose connection, etc. But the XT350 charging system is stone ax simple and pretty robust.
I would suspect the battery first, loose or corroded connections second, regulator/rectifier third. I believe it may be possible for the regulator to fail on the battery charging side independently of the headlight. But that seems unlikely.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 05-16-2013, 02:38 PM   #3368
Erock65
Erock65
Oddometer: 12
I have a brand new battery, I will check connections. Yes the headlight works though
Old 05-17-2013, 04:57 AM   #3369
thumpthumpthump
Thumpthumpthump
Oddometer: 214
Ditch the battery and get a battery eliminator. Its about the size of a d battery and weighs nothing. Ditch the weight and it never goes bad. Accell makes one for about 30 bucks. I have been running one for 4 years. You can even leave your key on all the time, nothing to drain down. thumpthump
thumpthumpthump is offline   Reply With Quote
Old 05-17-2013, 05:35 AM   #3370
MILLENNIUM FALCON
Oddometer: 250
Dies anyone know of a good tank bag that fits the xt350's?
MILLENNIUM FALCON is offline   Reply With Quote
Old 05-17-2013, 08:10 AM   #3371
Grreatdog
Grreatdog's Avatar
Oddometer: 11,957
Those are a big capacitor. I believe the Accel and Mallory battery eliminators are about 8000 F. Not sure what voltage but probably 15v. At least that is what we used back in the day in SC where we didn't need signals. Capacitors can be less than $10 to about $30 from electronics supply shops for a standard can with screws on top.
Once I moved to MD and had to put my turn signals back on the bike I found the capacitor wasn't very consistent at idle with both the brake light and signal on. So I went to a little 1.2ah sealed battery. It weighed less than two pounds and cost less than $20. It lasted for a couple of years in the XT350 and a couple of more in my XL600R.
Old 05-22-2013, 06:58 AM   #3372
llamas
XT350 lover
llamas's Avatar
Oddometer: 10
Question Rear Spring
So after reading this thread over, and wanting to get my xt350 a bit stiffer in the rear end. Am I understanding correctly that a 7.5kg/mm rear spring from a DR650 should fit in place of my stock spring with little to no effort other than changing it out?
'86 XT350
'97 XT350
'01 XT350 (Parts Bike)
llamas is offline   Reply With Quote
Old 05-22-2013, 01:23 PM   #3373
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Possibly.
It does fit on the TT350 shock.
The stock DR spring is 6.5kg/mm and is about right for the TT.
Old 05-22-2013, 01:29 PM   #3374
Grreatdog
Grreatdog's Avatar
Oddometer: 11,957
The problem I see with a higher rate spring on an XT350 is the compete and utter lack of rebound damping in the shock. I used to run my rear spring almost completely sacked out because of that. If I set a normal amount of sag it was like riding a pogo stick. Rebound with any spring preload set was almost completely uncontrolled.
To me, it was better to run it with the spring soft and have it bottom than try to spit me over the bars in whoops. Which it would do if you added preload because it didn't have enough rebound to control the spring. Maybe it was just my bike. But the rear shock rebound sucked from day one. Adding more spring just made it suck worse.
To me, the bike needs a new shock and a stiffer spring. But I never was able to find anything to swap into mine.
Old 05-22-2013, 02:13 PM   #3375
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
I went to the DR spring and 10w oil in the TT shock.
Times are GMT -7.   It's 04:01 AM.
