Old 11-02-2013, 11:38 AM   #3616
whittrated03
Steady Rollin' Man
whittrated03's Avatar
Oddometer: 221
Fork size?
What size forks r on my 89 xt 350?
Smooth is fast.
whittrated03 is offline   Reply With Quote
Old 11-02-2013, 06:47 PM   #3617
gearheadE30
gearheadE30's Avatar
Oddometer: 845
All xt350s are the same. 36mm iirc.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 11-03-2013, 06:40 PM   #3618
sjc56
Oddometer: 1,309
small end bearings
I wanted to put the cylinder and piston on today, I checked the new piston pin on the contacting rod and there is lateral play, up and down. Yamaha doesn't seem to list a small end bearing or show one.
http://www.partspitstop.com/oemparts...nkshaft-piston
So do I have to replace the connecting rod?
Steve
sjc56 is offline   Reply With Quote
Old 11-03-2013, 10:19 PM   #3619
gearheadE30
Oddometer: 845
Yeah, you do. No small end bearings. The wrist pin could also be the culprit - pull it out and check it with a mic or calipers or something to see if it is still round. If you can find the spec for the small end, you can do the same to the con rod. Any of the interface surfaces could cause that play.
Old 11-04-2013, 06:33 AM   #3620
sjc56
Oddometer: 1,309
Thats with new wrist pin. Rats, not sure what to do now. I already paid to much for the bike. Do I dig deeper or just put it back together and ride it it till it blows.
Steve
Old 11-04-2013, 03:38 PM   #3621
gearheadE30
Oddometer: 845
How bad is the play? Mine has a small amount and it still runs fine. Hasn't gotten worse in 2k miles, really.
Old 11-05-2013, 06:11 AM   #3622
sjc56
Oddometer: 1,309
There is about .010 play. You can see scoring on the bearing.
A friend of mine a very well respected motorcycle mechanic thinks he can fit a new bushing, thing is if there is a bushing it's not bronze, a magnet sticks to it, there is a lip but maybe only a couple of thousands. So I'm not sure if there is a bearing there.
Steve
Old 11-05-2013, 11:23 AM   #3623
Pring7
Oddometer: 3
Hi this is my first post. I just got a 1997 XT350 the other week and have been cleaning it up and making it road ready. I was noticing when I ride it that the neutral light doesn't come on when it clicks into neutral. I'm wondering what this could be. Any ideas?
Pring7 is offline   Reply With Quote
Old 11-05-2013, 11:37 AM   #3624
gearheadE30
Oddometer: 845
wow, 10 thou is quite a bit. Rod bearings are typically some sort of alloy, not bronze. Also, I believe the rod is ferrous, so that would affect magnetism. you'd probably have to bore out the rod, press in a bearing of some sort of hardened metal, and then reassemble, at which point you may as well put a new rod in. If he's got a way to try it, it probly wouldn't hurt, though.
Article on engine bearings:
http://www.turbomagazine.com/tech/08...s_garage_tech/
Burned out bulb, bad wiring, or the switch is damaged or worn out. It's not a complicated circuit. A little quality time with a multimeter should find the problem in no time if it's not the bulb.
Old 11-05-2013, 11:49 AM   #3625
Pring7
Oddometer: 3
Decent advice I appreciate it. The previous owner had some brushguards installed and then he wired in extra turn signals (no clue why) and I'm guessing during all that he probably knocked something loose. I'll post a picture of the bike here in a few.
Old 11-06-2013, 11:13 AM   #3626
JensEskildsen
Oddometer: 1,012
See if you can have it bored out and install a bushing. Might cost ya a bit, as the machinest would most likely have to press the crank apart to line up the rod.
I had some small play in mine, with a new wristpin. I assemled and nothing has happened in 1500km.
A new crank with rod can be had here, doesnt seem to expensive for what it is, if they really stock it, the partno seems discontinued:
http://www.ronayers.com/55V-11400-02-00-P3989878.aspx
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 11-06-2013, 12:01 PM   #3627
sjc56
Oddometer: 1,309
Well if I go through the trouble of removing the rod I may as well get a new one.
http://www.boats.net/parts/search/Ya...TON/parts.html
I'm just nerves about what i'll find in there.
My two mechanic friends said with a loss wrist pin you will hammer the motor to deaf. The wrist is pounding on the crank may take awhile but it can't be good.
Steve
Old 11-07-2013, 04:21 AM   #3628
whittrated03
Steady Rollin' Man
Oddometer: 221
I have a 1989 xt350 that I'm parting out. Everything is there EXCEPT front wheel and forks. You may email or text me for pics ......whittrated@yahoo.com. OR 254_708_4860,Phillip
Smooth is fast.
Old 11-07-2013, 06:20 AM   #3629
sjc56
Oddometer: 1,309
email sent. I'm interested in the motor and tank.
Steve
Old 11-08-2013, 03:59 PM   #3630
Jaunty
Oddometer: 18
hey guys i havent taken apart my motor seized up yet, but i did remove the valve cover and checked the tension of the timing chain and its SUPER tight. Is it possible that a component broke down below and seized the engine up near the chain rather than the piston?
I will dig deeper i just haven't had the time lately.
Jaunty is offline   Reply With Quote
Times are GMT -7.   It's 11:51 PM.
