Old 08-10-2010, 04:34 PM   #1441
raptortrail
raptortrail's Avatar
Oddometer: 240
1994 Yamaha Xt350
Up for sale is a 1994 Yamaha Xt350. 4200 original miles.Engine has been completely rebuilt with new piston and rings (.5mm)and new clutch.Engine has all new seals and gaskets.Has new carb intake boots and all carb gaskets,o-rings hoses etc.Has new front and rear brakes(new caliper seal kit in front)new chain,new air filter,new fork seals and fluid,new battery,new ignition coil.runs and shifts great.All lights,horn,turn signals work.Tires in good cond.$1500 Bike is located in Washington,IL(peoria)
raptortrail is offline   Reply With Quote
Old 08-10-2010, 05:32 PM   #1442
Psycho18th
Oddometer: 440
Originally Posted by nails1
I've gotten a lot of use from Clymer, a 1985 service manual, and a parts manual. Found all in webistan. I doubt if any are 100% right.
I have a CLymer manual, and it's great for describing step-by-step how to take stuff apart, inspect it, and put it back together without making things worse. I would highly recommend it. My scanner is broken at the moment, else I could scan and send a couple of pages.
Psycho
02 DRZ400E Dualsported in AZ
14 KTM 250 XCW (Plated in AZ)
85 HON XL80S (Wife's ride)
00 and '07 YAM TTR 90s (kids' bikes)
89 Lockheed F-16C (Work vehicle )
Psycho18th is offline   Reply With Quote
Old 08-10-2010, 05:33 PM   #1443
Psycho18th
Oddometer: 440
Or you all could buy my '98. You can read it's history right here in these pages. It currently resides in my garage here in Phoenix...
Psycho
Old 08-10-2010, 06:24 PM   #1444
back2tx
Oddometer: 25
j-ball
sounds good. if i can ever get down that way. my brother was supposed to come get me but that fell through. i was hoping to get him to pull my dodge with his diesel can't afford an 1100 mile trip at 9miles per gallon. i graduated from college and the job market sucks.
back2tx is offline   Reply With Quote
Old 08-10-2010, 11:18 PM   #1445
xt4ever
xt4ever's Avatar
Oddometer: 80
Originally Posted by Aivasovsky
Thanks Skid!
Two of them were missing when i first bought this bike.
I made same plugs from white plastic.
They are not easily visible in the photo.
Thanks a lot for reminding anyway
SKY
I also realized this, but I don't like too much the white ones you made. Please, be aware that the valve cover should rest on these caps to avoid the caps being moved because the oil presure, to serve as top when tighten the cover screws, and to help to mitigate vibrations. I believe you can make better ones with instant gasket and a cast, for example.
Just a suggestion
-JL
xt4ever is offline   Reply With Quote
Old 08-10-2010, 11:30 PM   #1446
xt4ever
xt4ever's Avatar
Oddometer: 80
Hi There!
Anyone using repair manuals?
There are CLYMER Repair Manual for XT350
http://cgi.ebay.com/ebaymotors/CLYME...als_Literature
I have found some technical service manuals from the internet which has 30-40 pages of brief explanation of almost every part of the bike.
I wonder if CLYMER Repair Manual has more information.
Anyone has it and can send me some example pages from it?
Thanks,
SKY
If you're refering to the "XT350 Service Guide, YAMAHA technical training", it's good, but the Clymer manual has a lot of more information. I recomend you to invest some money buying one because in the PDF file that is flying over there the images have no good resolution. I have the original at home to keep it clean, and a printed greasy copy of the PDF in the shop
There is also over there a PDF Service Guide for the TT350S very very good, very useful for all engine parts.
HTH
-JL
Old 08-11-2010, 12:24 AM   #1447
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Hi Mates!
I have found this manual on the net:
http://207.134.169.32/~guigui/XT350/XT350.rar
which was mentioned on this page:
http://www.thumpertalk.com/forum/arc.../t-494963.html
The title is:
Yamaha XT350,TT350 85-00 Clymer Service Manual ENG By Mosue.pdf
I guess its the PDF form of the original Clymer.
The pictures were ok but the original printed book would be better.
The information inside is great.
I wish i had it before all the work i've made on my bike.
I will order a copy of the original Clymer Manual.
Thank you all for help!
PS: does this links cause problems about copyright issues?
if possible, i can remove the links. We should respect the rights.
SKY
2003 KTM 640 LC4e 18000km (High Flow top)
1993 Yamaha XT350 40000km
Rebuilding XT350 project pics:
http://s263.photobucket.com/albums/i...350/?start=all
Aivasovsky is offline   Reply With Quote
Old 08-11-2010, 12:50 AM   #1448
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Thank you Mate!
I will check them again, i made them to plug the hole tightly but didn't bother about the height.
At cold starts the oil pressure goes up to 1 bar (14psi)
which is around 100mbars when hot.
This pressure may cause plugs to pop out or leak oil around them.
The same pressure had the clogged oil filter to tear as well.
The temp. was around freezing point at that time.
Thanks for reminding,
SKY
Just a suggestion
-JL
Old 08-11-2010, 04:38 AM   #1449
endurokids
Oddometer: 11
Re...
Thanks for the replies to all that did.
I'm probably going to leave the jetting alone for now since it starts on the first kick and runs great. I may change stuff if I get a Suppertrap for it.
For all I know, its been jetted already since it starsts so well.
I'm fixing the forks and adding an 1 1/2" to 2" spacre as described previously, and adding 330cc's of 15 weight oil to start.
I'll check the shock as to where the clip is while Im at it.
Any other suggestions will be welcome.
Thanks again.
5 Husky's, 2 Yamahas and 1 Suzuki.
endurokids is offline   Reply With Quote
Old 08-11-2010, 11:33 AM   #1450
SkidMarx
SkidMarx's Avatar
Oddometer: 2,204
Originally Posted by J-Ball
Back2TX
-Welcome back, if ya ever wanna bring your XT to the hill country and ride lemme know. Camping and great riding all around!
XT4Ever
+ 1 on the Supertrapp
-1 on removing the snorkel. My bike never seemed to like that. I'm running a UNI filter with the door off + Supertrapp w/ 8 disks, proper (?) jetting. My bike-y likes, and so do I.
Skid, someone stole your muffler?!? Damn, that sucks.
At least they left me the rest of the bike and I still had the stocker.
'90 XT350
'08 WR250R
GLDS
SkidMarx is online now   Reply With Quote
Old 08-11-2010, 11:38 AM   #1451
SkidMarx
SkidMarx's Avatar
Oddometer: 2,204
Thank you Mate!
SKY
Pure speculation, bu tI have a feeling the plugs are supposed to leak a little oil out. I know mine are pretty loose. Kind of a low tech relief valve.
'90 XT350
'08 WR250R
GLDS
Old 08-11-2010, 11:42 AM   #1452
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,896
OMG I have left my XT out to die. That frickin carb I just cant seem to figure out whats wrong with it. Acts just like an idle circuit blockage, but HOLY SHIT I have had it off and on about 59,000,00000000 times and it still coughs and spits back through the carb, dying as it does. I want to kill it.
IS there a full carb rebuild kit? I have been stuck with some hinky O-rings and the like, but I feel the only option other than NEW carb is to yank that bitch down to its smallest components and replace ALL the consumables.
I'm ready to cry, if I didnt have another bike to sooth my tattered feelings.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 08-11-2010, 01:56 PM   #1453
SkidMarx
SkidMarx's Avatar
Oddometer: 2,204
No rebuild kit that I know of, but I haven't had any problem getting the bits and pieces from the dealer(mostly o-rings).
Maybe find someone with an ultrasonic cleaner you can soak it in for a bit.
The tiny passage between the Pilot jet hole and the Pilot screw hole is a really hard to clean if there is something in there.
Also, make sure the tip of the pilot screw didn't break off and plug the hole.
Is the float level OK, maybe you bumped it one of the times you took it apart.
'90 XT350
'08 WR250R
GLDS
Old 08-11-2010, 02:03 PM   #1454
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,896
tanks man. Its driving me bonkers. I'll check those out, though.
Old 08-11-2010, 02:47 PM   #1455
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 568
Check the timing, Did you touched the cams? or cam chain? mine did the same after i refit the cams. I had to jump a thooth on the timing chain, it would start and work well but on idle it just die out suddenly and back fire also.
How's yor intake boots?
webmonstro is online now   Reply With Quote
Times are GMT -7.   It's 09:41 AM.
