Old 12-15-2010, 05:56 AM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Thumb Beware of old-style nut on rear calipper (1150)
On the left the old-style nut that holds the bleed nipple on the rear caliper. As you can see,
it has a flange around the edge. This ensures that the nipple will stand in water at all times.
The result is obvious.
The new-style nut is flat on top and no water remains.
Problem is: The nut is not for sale. You must purchase a full caliper. The price seems to be in the 400-euro range "Over Here".
If you have the old-style nut you might want to look into it, and replace it, well before the nipple breaks off.
At least, you want to examine the nipple carefully!
There is, however, a small problem. The new nut has (space for) an O-ring at the bottom. The old one
does not have that. Thus, you need to remove the O-ring (as the old caliper does not have space for it)
and replace it with a larger copper washer than the one you find on the old nut.
Also: On the old nut you will find (traces) of Locktite 243 (the one that does not need heating to let go).
Apply it also on the new nut.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 12-15-2010, 07:20 AM   #2
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,148
Another solution may be to clean off any surface corrosion present and put a little bead of silicone around the base of the nipple to prevent water from standing there. It shouldn't cause any problems with bleeding the caliper.
I'll make a note to myself to look at mine when I do my Spring inspection in a couple months.
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Old 12-15-2010, 07:46 AM   #3
Railbender
Oddometer: 1,039
You expect spring in Buffalo in only a couple of months?
The shortest distance between two points is boring.
Railbender is offline   Reply With Quote
Old 12-15-2010, 08:26 AM   #4
CrustyAPO
CrustyAPO's Avatar
Oddometer: 439
32 degrees or above in Buffalo IS considered springlike.....
Yeah, and maybe I'm a Chinese jet pilot.
CrustyAPO is offline   Reply With Quote
Old 12-15-2010, 09:45 AM   #5
99p38a
99p38a's Avatar
Oddometer: 291
nipple nuts
I had to buy a nut replacement, speedbleeder sells them here in the US for under $7 or something. I cranked on my speedbleeder too hard and snapped it in the stock one so I was in search as you are.
Speed Bleeder Products, Inc
13140 Apakesha Rd. Newark, IL 60541 USA
Tel: 815 736 6296 Fax: 815 736 6297
Toll Free Number 1 888 879 7016
http://www.speedbleeder.com/
Brian
Mid-Michigan, USA
2001 BMW r1150GS
99p38a is offline   Reply With Quote
Old 12-15-2010, 11:09 AM   #6
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,148
I've contacted some "connected" Italian friends and Phil will be taken care of this year.
Regards,
Mark
Old 12-15-2010, 12:47 PM   #7
Railbender
Oddometer: 1,039
Phil only covers PA. I think your area is covered by Dunkirk Dave. Memorial Day is my guess for spring in Buffalo. I know the lake stays cold well into June.
Just go to Ted's and get a hot dog.
Old 12-15-2010, 01:12 PM   #8
Dan Căta
Dan Căta's Avatar
Oddometer: 1,676
@Task, where is the new nut coming from? A car or something?
Dan.
Dan Căta is offline   Reply With Quote
Old 12-15-2010, 02:04 PM   #9
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Thumb
Dan.
A friend happens to work as at a BMW dealer nearby. He took an old caliper out of a drawer and
gave me the nut. The nut is original BMW (read: Bremo).
[TaSK]
PS: I have not forgotten about the thing you asked - I will add it Very Soon Now.
IBA: 33616
Old 12-15-2010, 03:01 PM   #10
Beezer
Oddometer: 5,856
drill out the broken bit, tap it for a new zerk fitting thing, epoxy to fill the space
EDIT... what I ment is tap/clean the threads & install a new bleed screw (helicoil if need be). use the epoxy to fill in where the water lays.... didn't mean to imply it would be good to epoxy the screw into the fitting. since it is apparent that a new replacement can be had cheap there is on point in trying to fix the old one.
Beezer screwed with this post 12-16-2010 at 11:59 AM
Beezer is offline   Reply With Quote
Old 12-15-2010, 03:31 PM   #11
mike54
You don't get me
mike54's Avatar
Oddometer: 13,274
Cripes!
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 12-15-2010, 06:41 PM   #12
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,974
He's talking about the big nut the bleeder threads in to. I have read at least three threads here of folk looking for them as you have to buy the whole caliper otherwise. Doesn't speed bleeder just sell bleeders?
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 12-15-2010, 06:45 PM   #13
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,974
There used to be saying in England when I was a lad:
"oily rag clean"
You go over your bike with an oily rag in those nasty places to keep rust at bay. I've been dabbing oil on offending BMW fasteners for years, and wiping my spokes with an oily rag.
Old 12-16-2010, 02:31 AM   #14
Oilybimmer
Oilybimmer's Avatar
Oddometer: 1,424
Mine was snapped when I bought the bike, I think I got the whole thing in stainless from motorworks for around Ł10, cheap easy fix.
Stewart
1998 GS 1100, TT hard parts, Zega panniers, MRA screen, WP rear shock, HID, keeps getting better.
PM me for drawings and dimensions to make your own Canbus fluid adapter
Oilybimmer is offline   Reply With Quote
Old 12-16-2010, 03:17 AM   #15
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,636
You need a stainless steel rear nipple AND holder plus it has a space for the "O" ring
www.gsshop.biz
Steptoe is offline   Reply With Quote
Times are GMT -7.   It's 01:24 PM.
