Old 09-30-2007, 10:16 PM   #1
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
Motomaster 320mm single front disk
For those who are thinking about fitting a single disk
It's simple
Grab some small bearings from a bearing supplier to space the disk, and the caliper (from the calliper carrier)
2 bearings X 5mm wide M8 axle
6 bearings X 5mm wide M6 axle
6 X 5mm longer KTM bolts (they trigger the speedo signal {hall effect}and must be steel)
[IMG][/IMG]
[IMG][/IMG]
You will also have to relocate your speedo drive
[IMG][/IMG]
you will have to remove 1.5mm from the inside of the calliper carrier. I used an angle grinder with a flap disk. A bit of trial and error
This side
[IMG][/IMG]
But now for the best bit____
On the box which no one reads
[IMG][/IMG]
is advice relating to the master cylinder, so I got ..........a
[IMG][/IMG]
off the Super enduro ($180AU) which works PERFECT with this 4 pot caliper.
You can do anything with this combination...... Simply Perfect.
If you are worried about twisting forks then don't do it!
Thanks to those who went before me, and gave advice...... Flanny, Gregore, Ricardo, Stephen and evilkymevil and many more.........
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m screwed with this post 10-20-2010 at 01:40 PM
K2m is offline   Reply With Quote
Old 09-30-2007, 11:25 PM   #2
Lewy
Minus the LC8
Lewy's Avatar
Oddometer: 1,829
Nice one Rory.
Why do you have to worry about twisting forks?
As far as I can tell the forks are the same as the ones I had on my 640SM.
It had 320mm disc and 4 piston caliper and never twisted anything
Lewy is offline   Reply With Quote
Old 09-30-2007, 11:38 PM   #3
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
Maybe I should rephrase that.
"If you think that going to a single disk will cause the forks to twist then don't do it."
The last time this was discussed it turned into a safety argument. Ended the very good idea's that were flowing freely.
Old 09-30-2007, 11:47 PM   #4
Lewy
Minus the LC8
Lewy's Avatar
Oddometer: 1,829
Ok so it was just people who hadn't done it before saying it wouldn't work
Old 10-01-2007, 12:34 AM   #5
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
Well said Lewy.
Old 10-01-2007, 12:49 AM   #6
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,341
Why bearings instead of plain spacers? Were they just convenient?
uk_mouse is offline   Reply With Quote
Old 10-01-2007, 01:21 AM   #7
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
It was all I could find with that accuracy. you could have an engineering shop make them, but it would cost a fortune. They work well as there are 2 surfaces to sit on, and the load is spread, Life can be a bit tough down here in the antipodes, as there are so many things you cannot get, that are freely available in Europe and the States. If we can get it it will be at a Rip-off price.
We do a lot of shopping on the Internet
I got the Motomaster from motostrano http://www.motostrano.com/cosubrsy.html
$550 on special Less than a week to get here.
K2m screwed with this post 10-01-2007 at 02:43 PM
Old 10-01-2007, 01:43 AM   #8
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
This brake is much stronger than the standard twin disks. There is excellent feedback through the SE master cylinder. I have had it on for a month, but have not been on the dirt yet.
Old 10-01-2007, 04:58 AM   #9
evilkymevil
The Modifier
evilkymevil's Avatar
Oddometer: 57
single disc
On ya Rory,
You have seen the light the lightening of 3 kg off the front end will transform the way you can now powerslide out of turns without the front pushing. On dirt that is.
Not to mention the feel and control at the lever.
Now you just need a set of 17" wheels to go with that set up to really put it to the test .
I have the motomaster off my kx450 supermoto i am yet to try on my 17" rims.
I'm using the se master cylinder with the standed caliper for serious dirt work, and i'm extremely happy with the power and feel.
I'm keen to get feedback on how the motomaster feels on the dirt.
I know on my kx450 the front brake lacks feel on the dirt sections and too much power. This bike only weighs 100 kg though so i suspect it will feel different to the 950.
My plan was to swap the standard caliper,brake line and se master cylinder
when i'm swapping from standard wheels to 17" wheels, and put on my motomaster ,line and a suitable master cylinder to obtain the best brakes for road riding and the occasional track day.
But Rory you say that that your set up using the se master cylinder is stronger than the twin disc set up.
Maybe thats all i need is to just use the motomaster for both wheels.
evilkymevil is offline   Reply With Quote
Old 10-01-2007, 06:33 AM   #10
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by evilkymevil
On ya Rory,
Maybe that's all i need is to just use the motomaster for both wheels.
I followed you after you picked up your SE pump I picked up mine, and ran a single floating(990) disk for a few weeks, but was disappointed with its lack of power for an emergency stop. I'm sure it would work well on the dirt.
We need some testing of the SE pump and Motomaster caliper on the dirt. I tried emergency stopping in the wet and was most impressed.
I have a new set of scorpions to ware out so I have time to consider what to do with my original rims. I have a set of spare wheels with a 21 X 1.85 front and a 18 X 3.5 rear with excellent German dual sport tires. The rear, pictured here is a 140 X18.
[IMG][/IMG]
Old 10-01-2007, 06:56 AM   #11
mookymoo
Mookish Mook
Oddometer: 4,286
Whats the motivation behind having a single disc?
mookymoo is offline   Reply With Quote
Old 10-01-2007, 06:58 AM   #12
mookymoo
Mookish Mook
Oddometer: 4,286
I dont want to hijack the thread-but what are those rear tanks?
Old 10-01-2007, 07:09 AM   #13
K2m OP
....58....
K2m's Avatar
Oddometer: 2,238
"the lightening of 3 kg off the front end will transform the way you can now powerslide out of turns without the front pushing. On dirt that is.
Not to mention the feel and control at the lever." = evilkymevil
I think that that sums it up quit well.
It's all-right it's my thread
I did some fiberglass work on my bike. Sort of "make the things that you cannot buy."
Here's another shot from the front
[IMG][/IMG]
K2m screwed with this post 10-01-2007 at 07:14 AM
Old 10-01-2007, 07:24 AM   #14
mookymoo
Mookish Mook
Oddometer: 4,286
Ok. I forgot about the calipers when considering the weight. It had been suggested that single disk gives you more options when it comes to buying hubs - and that the gentler braking in the dirt is better.
As for the tanks, looks good.
Post some pics of your tanks on the "Show us your pics" thread.
Old 10-01-2007, 08:22 AM   #15
Bannisdale
....snowing now!
Bannisdale's Avatar
Oddometer: 207
Unsprung weight!
A lot less of it is always a good thing....3 Kg is a lot!
Bannisdale is offline   Reply With Quote
Times are GMT -7.   It's 07:39 PM.
