Old 10-01-2007, 04:24 PM   #16
Stephen
Stephen's Avatar
Oddometer: 3,194
Three kg is a lot, indeed.
Way to go, Rory. What would we do without you?
I really like this.
So, now the bracket comes with the brake -- Gregor had to make his own.
Stephen is offline   Reply With Quote
Old 10-01-2007, 04:34 PM   #17
K2m OP
....58....
K2m's Avatar
Oddometer: 2,239
Thank you Stephen for your kind words
A big thanks to Mateo (Barbasma) on his advice
I ordered the brake kit for the 620/625/640 KTM
Molto bene!
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m screwed with this post 10-01-2007 at 05:10 PM
K2m is offline   Reply With Quote
Old 10-01-2007, 07:20 PM   #18
MvZee
MvZee's Avatar
Oddometer: 120
Originally Posted by LC8Lewy
Ok so it was just people who hadn't done it before saying it wouldn't work
So.... who was it that said it couldn't be done??? Been there... done that.... years ago!
MvZee is offline   Reply With Quote
Old 10-01-2007, 07:23 PM   #19
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 639
Howza bouta...
could you mount up two of the 320's? or is the caliper only set up for one side (that is a brake line port on one end)
Wow, two 320s would be cool.
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is online now   Reply With Quote
Old 10-02-2007, 09:34 AM   #20
K2m OP
....58....
K2m's Avatar
Oddometer: 2,239
It will not mount on the other side How much is to much?
Old 10-02-2007, 09:55 AM   #21
K2m OP
....58....
K2m's Avatar
Oddometer: 2,239
Don't stop there! http://www.advrider.com/forums/showt...ht=single+disk
The thing is that no one finished the job off, there was always something left to do....... or try. The reason your rotor failed, I think ,is because the brake was not mounted properly. This story had never been finished.
"Quote =Mvzee
What do you mean... never completed -- did you read the whole thread? Specifically this post where I commented about it's performance on an 8000 mile trip around Mexico?
Now for an update... I recently had to replace the Motomaster rotor as it got really sloppy. I replaced it with a 320mm Galfer rotor which will hopefully last a bit longer. I also think that this conversion truly needs a different master cylinder for the Motomaster caliper. I think a 16mm radial master cylinder might be the ticket. It takes considerably more pressure on the lever to stop than with the stock brakes.
Would I do it again? Probably not -- I think that the new 300 mm rotors now available from Galfer are probably a more cost effective and easier solution, although the weight savings would probably be less. With a 4 piston caliper and 320 mm rotor, clearance between the caliper and the spokes is close. In fact, it may not even be possible with some calipers... the Motomaster is one of the narrowest and my clearance is on the (very) tight side even with the rotor spaced out from the hub about 0.100". I think the solution for the clearance problem is re-lacing the wheel with some "dish" (like a rear bicycle wheel) and then recentering it with new axle bushings -- but that's a project for another day....
Octamog -- The Worlds Most Extreme R.V.
Blame John™
MvZee
View Public Profile
Send a private message to MvZee
Send email to MvZee
Visit MvZee's homepage!
Find More Posts by MvZee
Add MvZee to Your Buddy List
K2m screwed with this post 10-02-2007 at 05:15 PM
Old 10-04-2007, 09:21 PM   #22
MvZee
MvZee's Avatar
Oddometer: 120
"Quote =Mvzee
Blame John™
MvZee
View Public Profile
Send email to MvZee
Sure... get back to me when you have over 8k miles on your Motomaster rotor!
Old 12-03-2007, 05:26 PM   #23
K2m OP
....58....
K2m's Avatar
Oddometer: 2,239
This brake is much stronger than the standard twin disks. There is excellent feedback through the SE master cylinder. I have had it on for a month, but have not been on the dirt yet.
I've done about 1200km on the dirt, fully loaded, now with this brake, and simply love it. Full control on the loos-es of surfaces. Simply brilliant
Old 12-03-2007, 08:44 PM   #24
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,354
Nice job Rory.
When I was in this dilemma on a different (but similar project), I got a KTM factory SM rotor spacer and milled it to fit to work with the 21" wheel and the standard caliper hanger offset.
This should work to adapt a SM brake to most any 4860 forked KTM to a 21" wheel. The big headache is the caliper to spoke clearance for those that haven't tried this.
gaspipe [the original]
Hair of the dog that bit me, Lloyd...
gaspipe is offline   Reply With Quote
Old 01-31-2008, 02:14 PM   #25
K2m OP
....58....
K2m's Avatar
Oddometer: 2,239
Gaspipe.... sorry it took so long to reply...... I was so impressed by your photos that i went out and bought a small mill. I didn't even know what a mill was!!!
Man!!! what a useful machine!!!!
I had to make some "leak jet" circuits for the FCR's fuel pumps. Didn't have a clue what the fuck I was doing
Fucked it up, of course could not get the threads to seal so I epoxied them in........ Any body want to buy some unused leak jets various sizes?
Lucky, as it turns out, I chose the right size.
Of course you learn by your mistakes, the trick is to drill and complete one hole in one operation including using the mill to tap the thread. Just turn it by hand
Forget useless bench drills..... A mill is the way to go
[IMG][/IMG]
Old 04-21-2008, 05:03 PM   #26
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,935
is it all worth it
the brake kit and having to change brake master cyclinder sound expensive..
I get the benifits, but how much is the conversion?
I am in Australia also.
Joe
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 06-17-2008, 10:50 PM   #27
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,935
bump
Joe
bump!!!! any answers?????????
Simpson Trip 2008
Old 06-18-2008, 05:23 AM   #28
K2m OP
....58....
K2m's Avatar
Oddometer: 2,239
Worth every cent........ Master from an SE $180AU
Disk and caliper from Motostrano $550USD on special.
http://www.motostrano.com/enbrakclut1.html
$I50USD freight 4 days UPS.
I will never change back to twin disk so I will cut of the redundant caliper carrier. Just wish I had have known so as to get a SE front hub with out disk carrier for my spare wheels. I will do this with my motard front wheel.
It's worth considering what your long term relationship with the bike is, and keep an eye open for special discounted prices.
The more weight you can get of this bike the more it behaves like a dirt bike. When traveling, correct weight distribution and a minimalist (Bush walker-cross country skier) approach to loading will allow you to tackle anything.
[IMG][/IMG][IMG][/IMG]
K2m screwed with this post 06-18-2008 at 05:32 AM
Old 06-18-2008, 05:49 PM   #29
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,935
thanks
Thanks for taking the time to respond... I wonder if there are any cheaper kits in Oz now - galfer or someone like that. Just a shame to pay the $150 in freight...
Great work, thanks for leading the way!
Joe
Simpson Trip 2008
Old 09-04-2008, 03:44 PM   #30
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,935
well I bit the bullet
Thanks for the support from some others here - but a special thanks to Rory who lead the way and gave me advice on my conversion. Haven't ridden the bike yet but who cares it looks hot!!!! ha ha ha.. nah - can't wait to ride it!!
I first went to a single disc, with the SE master cylinder - was good on the dirt and I certainly noticed a difference in the unsprung weight (I must admit when people first spoke of the difference 3kgs off the front would make a big difference I thought - nah couldn't) It really is noticable. There just wasn't enough braking power on the tar or in emergency braking situations.
I followed Rory's lead and later Flanny's and fitted the motomaster 320mm disc and 4 pot caliper.
I fitted it up last night using Rory's tips and it all went together well. I just need to get some nice little button head bolts 5mm longer for the disc. I put a few dodgy bolts in last night just to fit it up. Using the little button head bolts the speedo sensor can be mounted in the original position, I just hope that it picks up the bolts..... will know tonight.
[IMG][/IMG]
looks hot hey!!!
[IMG][/IMG]
bleed up nicley last night and disc is running nice and free, with a tight fit but hopefully enough clearance.... I will installt he disc again tonight with the new bolts and go for a test ride over the weekend. I will post another picture and my thoughts after the ride... however this set up has already been tried and tested...
Nice!!!!!!!!!
Simpson Trip 2008
MymoJoe screwed with this post 09-04-2008 at 03:59 PM
Times are GMT -7.   It's 11:24 PM.
