Old 03-16-2009, 06:13 PM   #46
Balsta
Oddometer: 400
320 mm for my SE?
Does it make sense to put the 320 mm brake disc on my Superenduro?
Balsta is offline   Reply With Quote
Old 03-16-2009, 08:12 PM   #47
Qwik
Adrenaline Addict
Oddometer: 6,868
If you go offroad you run a higher risk of hitting the larger diameter rotor.
Snarley Stay out of this forum mate!
http://www.advrider.com/forums/forumdisplay.php?f=49
Cheers!
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 08-08-2009, 04:41 AM   #48
mookymoo
Mookish Mook
Oddometer: 4,396
Has anyone done this with a different 320mm rotor?
I can pick up a used motomaster caliper & adapter quite cheaply - but would still need a disc/rotor...
mookymoo is offline   Reply With Quote
Old 08-15-2009, 05:29 AM   #49
mookymoo
Mookish Mook
Oddometer: 4,396
Any reason why a Braking rotor (320mm) wouldnt work with the motomaster caliper?
I can get one very cheaply
motomaster disc
http://www.supermotodaz.co.uk/images...toracedisc.jpg
Old 08-15-2009, 07:20 AM   #50
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
motomaster disc
Only thing I've noticed is some discs have wider rivets than others. Could change your clearances a very small amount. Price is right, get it!
tahoeacr is offline   Reply With Quote
Old 09-12-2009, 08:57 AM   #51
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 567
So at the end......
I've a SE and I'm not happy of the front brake because I've to apply too much power to the brake to stop the big boy.
Is this Motomaster kit a good idea to mount on my bike or not?
Do you suggest to buy only a bigger radial pump or (ie 19 mm instead of 16 mm) or what?
Please give me a good advice.....I want to brake applying less power to the lever.
BYE raf
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca screwed with this post 09-13-2009 at 10:11 AM
Patacca is offline   Reply With Quote
Old 09-12-2009, 09:16 AM   #52
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Originally Posted by Patacca
So at the end......
BYE raf
There is a 310mm kit in the flea market. Get it, buy it, make it work. The caliper alone is worth twice what he is asking. The disc is $150+. You will need to spacer it out just like all the rest. I am making some spacers so I could make you a set. If I didn't already have two of these kits in my garage I would buy this one.
http://www.advrider.com/forums/showt...ighlight=brake
Keep your stock master cylinder.
Old 09-13-2009, 05:45 AM   #53
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
motomaster disc
The depth of the recesses for the mounting bolts is important. On my motomaster disk, the flange thickness at the bolts was 2mm. I replaced this disk with a KTM 320MM disk, and the flange thickness was 3.8 mm - enough to make even my shallow-head allen bolts rub on the speedo sensor.
I wound up machining them back down to 2mm....so - buyer bewar - you need to know your clearances cold. That braking disk looks like it doesn't recess the mounting bolts, so that could be a problem..
Flanny is offline   Reply With Quote
Old 09-13-2009, 01:21 PM   #54
mookymoo
Mookish Mook
Oddometer: 4,396
Hm. Thats a point. Thanks for the heads-up.
BTW, Flanny, did you end up moving your speedo sensor - or did you leave it in the stock position?
Old 09-13-2009, 01:37 PM   #55
Patacca
Patacca's Avatar
Oddometer: 567
Sorry for my bad english, but if I understood well this braking rotor could be a problem.
So you said it's better to buy a motomaster disk and calliper...right?
I'm not a very good mechanic, so I need the most simple kit to install, that works well.
I want the fewer problems possible, cause can't have pieces machinated...
Old 09-13-2009, 02:07 PM   #56
mookymoo
Mookish Mook
Oddometer: 4,396
Actually, that pic looks like the disc is upside down.
The bolt holes for the Braking rotor are recessed. 3mm thickness at the mount point (5mm disc, recessed 2mm).
Hmm
Old 09-13-2009, 02:13 PM   #57
mookymoo
Mookish Mook
Oddometer: 4,396
Thats correct.
Old 09-14-2009, 12:12 PM   #58
Flanny
Flanny-it-up!
Flanny's Avatar
Oddometer: 2,738
I moved it down and forward and tucked it in as tight as possible. It's being held in place by a thin peice of AL sheet-stock and a wad of JB-weld.
Old 09-17-2009, 02:52 AM   #59
Patacca
Patacca's Avatar
Oddometer: 567
Any suggestion where to buy this kit...?
http://www.motostrano.com/moflrakit.html
900$ for rotor and calliper....any cheaper?
Old 09-17-2009, 03:49 AM   #60
LukasM
Oddometer: 5,426
Don't forget to consider shipping, VAT and import duties if you are in the EU, which will add at least 30% to the US price.
A local dealer here in Austria has the caliper for 400 and the disc for 230, so I think you should be able to get the package for 600 or so (including VAT).
Times are GMT -7.   It's 08:47 PM.
