Old 08-01-2011, 09:35 AM   #106
LukasM
Oddometer: 5,427
Glad to hear that you are happy Leland!
Let's see some pics (you can email them to me if you don't know how to post them)! I still haven't gotten around to put my Motomaster setup on the bike, finally managed to get the BMW ABS working with the stock KTM dual caliper brake system so I am a bit reluctant to mess with it.
Originally Posted by Flanny View Post
You have to cut it off. Nothing a hacksaw and a file can't fix. Then just fab up a small tab from the calliper bolt to bolt your fend to.
Thanks for the advice Flanny.
Old 08-01-2011, 11:57 PM   #107
max2
max2's Avatar
Oddometer: 219
I have a 950SE and need to upgrade the front brake. Does anyone know what caliper / adapter and rotor to buy? Motostrano told me they diddnt have anything. What application are you guys using ?
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 08-02-2011, 03:57 AM   #108
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
any ktm supermoto rotor, the 320 adaptor from the lc4's or exc's will fit. With some modification! One pin nerds to be ofset and pass need some grinding. Or take an exc clipper with it.
For better performance a 4 pot for ktm, like the braking one, but you will have issue's clearing a 21 inch with just about any 4 pot.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD screwed with this post 04-01-2013 at 02:40 PM
StevenD is offline   Reply With Quote
Old 08-03-2011, 11:00 PM   #109
mousitsas
mousitsas's Avatar
Oddometer: 2,993
Just fitted a 320 Braking rotor with the lc4 caliper AND the 950 adventure master cylinder. The larger piston master alone is a big improvement. Initial bite is reduced slightly but sponginess is gone as well as fluid boil. Overall braking is excellent and very powerful once you apply some force. Only downside is that the surface of the braking pad of the lc4 caliper I used is smaller than oem and does not cover the inner portion of the disc area. Will go back to the oem caliper at some point with some sort of 300-to-320 spacer.
I strongly recommend the larger master as an initial mod, you might not need anything else once you've done that.
Old 01-02-2014, 04:08 AM   #110
Adventcha UnCut
Wannabe
Adventcha UnCut's Avatar
Oddometer: 339
Single Front Disk for the ADV 9X0RR
Bumping this one to see if anyone has added to the WISDOM that has already been evident here. AND where is K2M, nothing since Sept '13?
Adventcha UnCut is offline   Reply With Quote
Old 03-20-2014, 03:08 PM   #111
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 568
Could you please put some photo? THANX
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 03-23-2014, 03:13 AM   #112
Patacca
Patacca's Avatar
Oddometer: 568
So best solution for SE is to go for a Motomaster 320?
Old 04-22-2014, 04:44 PM   #113
renogeorge
Oddometer: 1,489
Great thread! I am working on single disc conversion for my 2007 Adventure, removing ABS too. I'd love to find a deal on the Moto Master 4 piston caliper. But, has anyone tried a 320mm rotor with stock Adventure caliper relocated and SE master?
Anyone have parts to sell for the conversion?
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 04-26-2014, 09:45 PM   #114
renogeorge
Oddometer: 1,489
No one???
KTMs--300, 518, 990
Times are GMT -7.   It's 12:59 AM.
