Old 10-03-2007, 03:16 PM   #1
McCormack OP
eltiT resU motsuC
McCormack's Avatar
Oddometer: 7,796
1001 uses for JB Weld
Has anyone tried fixing a stripped spark plug hole with it? I'm thinking it would be possible to add some to the threading in the head (if it isn't too far gone), let set, then chace it with a die. The idea is to do it cheap, with the head on the engine. Just wondering if anyone tried it.
And no, I don't ride a KLR .
McCormack is offline   Reply With Quote
Old 10-03-2007, 03:59 PM   #2
Scrubs
erm
Scrubs's Avatar
Oddometer: 1,120
Worth a go... I tried making a screw head with it once, without success.
It claims to do threads but I've never tried it so wouldent know how effective it would be, I reckon it would be ok as a temp measure as not too much stress is placed on it, but how long it will hold out for before it begin s to scrape off into your barrel when taking your plugs in and out, I don't know.
What the fuck is WTF??
Scrubs is offline   Reply With Quote
Old 10-03-2007, 05:10 PM   #3
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,109
It won't handle the compression of the motor. A Helicoil insert is not hard to install. It is best to remove the head though.
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 10-03-2007, 05:27 PM   #4
usgser
Oddometer: 2,201
As JB Weld is duct tape in a tube...it's not a magic cure all. Use a helicoil in your application.
usgser is offline   Reply With Quote
Old 10-03-2007, 06:34 PM   #5
showkey
Oddometer: 1,936
Timesert
Time-sert beats helicoil for spark plug and all other thread restoration.
showkey is offline   Reply With Quote
Old 10-03-2007, 06:37 PM   #6
G-Force Junkie
G-Force Junkie's Avatar
Oddometer: 1,328
They make spark plug repair inserts, every auto parts store will have them. Drill it out, run the tap in, thread in the insert, then hit it a few time with the set and a hammer to lock it in place.
G-Force Junkie is offline   Reply With Quote
Old 10-03-2007, 07:14 PM   #7
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,615
Your bike deserves better than JB weld
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 10-03-2007, 10:43 PM   #8
Scottysix9
Shhh...
Scottysix9's Avatar
Oddometer: 919
+1
BMW 650 KDX 220 TS 400
If they can't hear you, they won't know you're there.
Scottysix9 is offline   Reply With Quote
Old 10-03-2007, 11:14 PM   #9
vanishingpoint
CYAwouldn'twannaBYA
vanishingpoint's Avatar
Oddometer: 151
JB weld ...way over-rated...In my humble opinion
“No man is so foolish but he may sometimes give another good counsel, and no man so wise that he may not easily err if he takes no other counsel than his own. He that is taught only by himself has a fool for a master.”
Hunter S Thompson
vanishingpoint is offline   Reply With Quote
Old 10-04-2007, 06:34 AM   #10
mike54
You don't get me
mike54's Avatar
Oddometer: 13,222
Hunter S Thompson
Not really. I used it to fix the zipper on my Aerostich. It's still holding up after 3 years.
Use a thread repair kit for your spark plug though. It's best done with the head off but you can get by if you put some grease around the hole, and on the tool before you start makeing any metal shavings. I did it that way on a VW one time and it worked out. That bug is probably still running.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 10-04-2007, 07:20 AM   #11
2wheelsrbest
Oddometer: 274
Yeah, I had 2 stripped plugs on a POS KZ400 once. NAPA sold me correct repair insert and friend suggested I pack the tap with grease to catch the shavings. I went slow, removed tap often and mopped shavings out inside of cylinder best I could before fired it up. Worked fine, considering the project. On anything I have now, I'd pull the head, however. Unless it is my lawnmower...
2wheelsrbest is offline   Reply With Quote
Old 10-04-2007, 08:31 AM   #12
McCormack OP
eltiT resU motsuC
McCormack's Avatar
Oddometer: 7,796
Note to self: JB Weld has 1000 uses, not 1001
Just an idea I had for a "quick" fix. I've used the helicoil insert before.
Old 10-06-2007, 04:53 PM   #13
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,049
Follow the directions and you should be fine.
Old 10-08-2007, 03:08 PM   #14
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
If I were on the road and needed to get home, yeah I would use it. And I would buy the insert kit at NAPA on my way home...
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 10-09-2007, 07:03 PM   #15
Fixitguy74
Oddometer: 2
I tried this once and only once. When I was younger and itching to ride I fixed and old Kawi dirt bike that had the dual plugs in the head. I figured it only used one of them so it wouldn't hurt to glue the stripped one in with JB Weld. Well it worked.........for about a mile or so. Then spit out the glued in plug dinging the tank then smacking my leg. I normaly don't mind a good walk but that one sucked for some reason. I ended up biting the bullet and getting the heli coil kit at the auto parts store and did it right.
Fixitguy74 is offline   Reply With Quote
Times are GMT -7.   It's 11:17 PM.
