Old 10-08-2007, 08:37 PM   #1
DirtMerchant OP
DirtMerchant's Avatar
Oddometer: 1,460
KTM LC4 625 SXC Brake Issue
Hey fellows,
I have reviewed and searched LC4 thread(s) but can't find an answer to my problem.
I have recently bought an 03 SXC, it is in great condition with about 1,300 miles on it. The front brake has been pretty soft but will stop the bike. I bought a fresh container of Mutol 5.1 brake fluid and proceeded to bleed the front brake.
I tried using a syringe to push the fluid backwards into the resivor but there was too much pressure and was leaking out around bleeder. I then went about the ole' timey way and pumped about 5 resivors full until I was sure that I had all the old fluid out. I pumped and pumped and pumped and pumped; all to no avail. I could not get it to build pressure.
I turned the bars to the left and then pushed the caliper against the rotor to push fluid back up; no go. I then removed the master cylinder, held it up so there is no bend in the brake line and pumped it about a hundred times whilst thumping it with may palm. This got me back to some pressure but will not build up pressure like it should. Any suggestions??????
I did notice there is a small about of fluid weeping out around the dust cover of the piston on master cylinder; but I did pump the hell out of it.
How long will brake fluid last in the container? I squeezed all the air out of the container and put it in a Ziplock bag.
Thanks,
Rodney
DirtMerchant is offline   Reply With Quote
Old 10-08-2007, 10:28 PM   #2
soloyosh
Dad and husband
soloyosh's Avatar
Oddometer: 5,465
I bought a second resavoir cap and made an attachment for my pressure bleeder.
Before that I would remove the caliper and hang it from a shelf, above the m/c. Tap the lines a few times to knock the bubble loose and bleed like you would anything else. Just make sure you lower the caliper back down before opening the m/c to top off.
2007 Aprilia RXV 5.5
soloyosh is offline   Reply With Quote
Old 10-09-2007, 04:59 AM   #3
Hipster
Hipster's Avatar
Oddometer: 1,433
Dirtmerchant,
Check the index, there is a special technique for removing air from the front brake. If I remember correctly, it involves pressing against the caliper with your knee while bleeding the brake.
Hipster is offline   Reply With Quote
Old 10-09-2007, 09:18 AM   #4
BobCWNC
Orange lithotripter
BobCWNC's Avatar
Oddometer: 13,041
A careful application of a heat gun to strategic places will thin the fluid so that bubbles will float to the high spots easier.
__________
"It is a great art to saunter". Thoreau
“Life’s most persistent and urgent question is– what are you doing for others?” –Martin Luther King, Jr.
Alan Greenspan said out loud, “I have found a flaw.” Waxman pushed him, responding, “In other words, you found that your view of the world, your ideology, was not right; it was not working.” “Absolutely, precisely,” Greenspan said
BobCWNC is offline   Reply With Quote
Old 10-09-2007, 09:40 AM   #5
redveloce
redveloce's Avatar
Oddometer: 164
Send a message via ICQ to redveloce Send a message via AIM to redveloce Send a message via MSN to redveloce Send a message via Yahoo to redveloce
Originally Posted by Hipster
Dirtmerchant,
Check the index
I searched the index and wasn’t able to find anything on this. The brakes are very spongy on my ’03 SXC as well. I thought it was just the nature of the braking system for some reason. I’ve tried to bleed the brakes several times with no effect.
redveloce is offline   Reply With Quote
Old 10-09-2007, 12:12 PM   #6
DirtMerchant OP
Oddometer: 1,460
Dirtmerchant,
Been there, tried that. I pushed against it, thumped it with my palm but no workey.......
The rear brake was a breeze so I know I'm not doing it wrong.
Old 10-09-2007, 12:15 PM   #7
DirtMerchant OP
Oddometer: 1,460
CLICK HERE:
http://www.advrider.com/forums/showthread.php?t=102248
Old 10-09-2007, 01:37 PM   #8
Beez
Given to fly
Beez's Avatar
Oddometer: 5,498
Does it use the same master cylinder as the RFS KTMs? There is a lot of discussion on KTMtalk on this issue. There are lots of ideas on how to fix it but the most difinitive one is to replace the entire master cylinder assembly with a Nissin MC from a Honda.
One thing you can try is to drill another hole in the MC banjo bolt. So instead of 2 holes at 180˚ you have 4 holes at 90˚. Less chance of a bubble getting trapped there.
Another trick is to tighten a zip-ty around the grip and brake lever and leave it overnight. Turn the bars to the left so the MC is as high as can be. The next day the brakes should feel better. I did this on a 450 EXC once and it worked, I don't know why.
Beez is offline   Reply With Quote
Old 10-09-2007, 04:48 PM   #9
DirtMerchant OP
Oddometer: 1,460
One thing you can try is to drill another hole in the MC banjo bolt. So instead of 2 holes at 180? you have 4 holes at 90?. Less chance of a bubble getting trapped there.
Beez,
Thanks for the input; I am not sure if the MC is the same as RFS or not. I also have been wanting to put a pressure switch for brake light so if I need to swap out for a Nissin then now is the time before dumping more cash into the a switch..........
I will be heading to the shop to try the zip tie trick. I have a centerstand instead of side stand so I am not sure how much turing left will help but I'll try.
Rodney
Old 10-09-2007, 05:37 PM   #10
Gumbydave
motorcycle doofus
Gumbydave's Avatar
Oddometer: 884
regarding backbleeding the magura
When it happens that the fluid will not backbleed I have found it to be because fluid will not pass between the line and the reserviour through the tiny hole seen in the bottom of the res.
this can happen because the lever is not adjusted all the way back,or dirt holding it open which is not allowing the fluid to pass
or
the green piston cup seal on the master cyl is distorted blocking the hole. It can be confirmed by poking a needle in while backbleeding. It can be cured with a replacement MC piston from ktm
"wise proverb witheld pending further review"
04 950 rat bike
06 KTM 576 XC/E-adv
06 KTM 250 XCW
TrailTricks Suspension
Gumbydave is offline   Reply With Quote
Old 10-09-2007, 05:48 PM   #11
DirtMerchant OP
Oddometer: 1,460
or
The MC is a Brembo on this bike, clutch is Magura though.
Bike is sitting for 24 hrs with tiewire around brake lever, bars turned left and block under right side of centerstand.....
Rodney
Old 10-10-2007, 03:26 AM   #12
halfcab
Oddometer: 645
Did you check to see if your some one had changed from the stock brake pads on your 03 SXC to after market pads?
A lot of people change out the stock pads to after market because some owners think the stock pads are to touché. Are they don't want to pay almost twice the price for stock pads when they replace.
halfcab is offline   Reply With Quote
Old 10-10-2007, 06:31 AM   #13
DirtMerchant OP
Oddometer: 1,460
The problem I am experiancing is the front brake lever is way to soft; as if there is a bunch of air in the lines but can't get it to purge. Maybe I need to put a Viagra in the MC reservoir.
The guy I bought it from said he had not serviced the brakes so I am assuming they are stock. I didn't remove the pads but they don't look too worn.
Rodney
Old 10-10-2007, 06:10 PM   #14
DirtMerchant OP
Oddometer: 1,460
Thumb
You sir, are a frigging genius but now I need to start a new thread to address my new problem. Front Brake Overly Sensitive; will nearly throw me over the bars with one fingers pressure.
I ordered a front brakelight pressure switch/banjo bolt so I guess I will be trying my luck again in a week or two.
THANKS TO EVERYONE FOR YOUR INPUT
Rodney
Old 10-11-2007, 07:32 AM   #15
Beez
Given to fly
Beez's Avatar
Oddometer: 5,498
Times are GMT -7.   It's 10:19 AM.
