Old 10-23-2007, 03:46 PM   #61
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Ok
A denser air has more oxygen in it and thus requires more fuel to bring the AFR's up....... so you are right. But it is good to clear that up for me as we do not get to ride much in altitude here so I do not get the chance to read the wideband and compare.
Good to see you are on the ball
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 10-23-2007, 03:49 PM   #62
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,098
Talking Makes more sense ... or NOT
Originally Posted by K2m
Ok
Sometimes it helps to just think of the internal combustion engine as a big air compressor.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 10-23-2007, 04:28 PM   #63
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,744
Send a message via Skype™ to Flanny
This weekend I should be able to go riding around with only the left tank on...
What I plan to do is very small adjustments, one at a time.
1) Lean out the air side with 40/90/100...If that isn't enough...
2) Bring the fuel screws in by a 1/4 turn...If that isn't enough...
3) Bring the fuel screws in by another 1/4 turn...If that isn't enough...
4) Go to a 2 1/2 half clip on the needle
5) Check mains with throttle chop and rear spark plug to confirm. If they are good, leave them alone and go back down to the smaller carb circuits. If they are rich, drop one on the mains and go with 138, 140 (Although that seems VERY lean to me).
It's just gonna take some time!
Flanny is online now   Reply With Quote
Old 10-23-2007, 06:36 PM   #64
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I looked further into air density and its effect on mixture. In one way I was right on less pressure leaning AFR's, but another factor which is the decrease in oxygen has a stronger effect on AFR's. There is a ratio to use where AFR's are critical such as in racing........ with an decrease in density of 12% you automatically have a decrease of pressure on your fuel so you only lean off by 5%.
So Flanny with this in mine you will not have to make large changes
Old 10-23-2007, 06:38 PM   #65
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,098
Bring the Flannycam this time
Don't make us come up there ...
-cp
Old 10-30-2007, 08:31 AM   #66
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,159
Hey everyone,
I have been doing a little cleaning up and additions to the spreadsheet.
If there was no data entered then I made the assumption that it was as stock and entered that data. I also removed any non numerics as this messes up the graphing functions.
The only thing that I can not baseline is the elevations of bikes listed. If you can take the time to check to see if you elevation is entered and if not make one an entry, that would be great. It does not have to be perfect. I have used my garage elevation as my listing.
Cheers,
Ken
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is online now   Reply With Quote
Old 10-30-2007, 11:33 AM   #67
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,250
Where is there a good source for the 45 pilots? 3 dealers and KTM have told me they are not available.
Michael
mgorman is offline   Reply With Quote
Old 10-30-2007, 01:44 PM   #68
EnduroAddict
Oddometer: 4
http://www.sudco.com/
These guys are all about carbs and parts.
EnduroAddict is offline   Reply With Quote
Old 10-30-2007, 05:03 PM   #69
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,159
supplier
you can get them from me
http://www.advrider.com/forums/showthread.php?t=247378
I also will do non package sales also
not sure if I am breaking the rules by cross linking, if so please nuke, or I will nuke if found to be rule breaking.
Ken
Old 11-10-2007, 03:10 PM   #70
Flanny
Flanny-it-up!
Flanny's Avatar
Oddometer: 2,744
So...
Here is where I wound up.
40/90/100 on the Air side of the Pilot Cicuit, 45 on the fuel side. Screws 2 1/4 out front and back.
Stock needle on the 3rd clip.
145 and 150 Mains front and rear (is getting mighty cold up here - 34 F or so, two steps up on the mains for temp correction).
The whole shebang runs quite nicely at these temps, but I'm sure it will be too rich for warmer days next spring.
Old 05-10-2008, 07:05 AM   #71
jaydee1445
Footpeg Crash Tester
jaydee1445's Avatar
Oddometer: 3,653
Why the h2w over factory pro?
I've looked at his kit, but it looked like a one size fits all and must use the pre filter. His is $85 and the factory pro ti kit is $99. Is the factory pro just mains? I ordered one for Coltgovt's 06 S.
I just set finished setting the Floats to 3mm needles to 3and mixture screws to 1.5 f 1.75 rear with 160f and 165r mains the rest of jets and airbox stock. I'm @ 0 feet here in Flatistian.
Same settings as flame rider.Seems to be much smoother and stronger especially in the mid range.
jaydee1445 is offline   Reply With Quote
Old 05-10-2008, 08:04 AM   #72
wsmc99
wsmc99's Avatar
Oddometer: 336
One small tweak
FYI
The setup on my bike was good, but just a bit lean.
I was prepping to sell it and put the stock pipes on it and it seems just right!
My buddy bought my pipes and wanted to do the whole jetting setup, so I had him get 142/145 vs. 140/142. Voila! Perfect! Idle was dead stable all other settings are the same.
wsmc99 is offline   Reply With Quote
Old 05-10-2008, 08:23 PM   #73
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,159
The appearance of one size fits all is not completely true. I select jets and make recommendations based upon the elevation of the garage of the bike. Typically 0-2000, 2000-4000 then 4000 and beyond all get different jets. There are a couple of other tweaks that I do also. The value in the solution is detailed installation instructions, specific jet and settings for each bike and personal install support if necessary.
The Factory Pro kit comes with a bunch of main jets (you get to figure out which ones to use, but they do offer some suggestions), a pair of pilot jets, Ti needles and a few other things. The problem is that without a couple tweaks that do not come in the kit it will work "OK". Typically most report poor fuel economy. The FP kit will still run with a Prefilter but it will be WAY rich in the middle (function of the needle and a couple other things, but mostly needle related) The install instructions are sparse so if you have never done this kind of work before then you better take it to someone who has. If you want to do a non prefitler solution then the FP needle will work, but there are other things that need to be done to solve some of the other issues that are not detailed much of anywhere.
My opinion:
The FP kit can be made to work and there are a bunch of them installed out there. It requires specific development for each installation.
The package of jets combined with the prefilter that I have put together works very well as a install and run solution. Most anyone with the ability to follow instructions and spin wrenches can do it.
Old 05-10-2008, 10:23 PM   #74
jaydee1445
jaydee1445's Avatar
Oddometer: 3,653
Sounds cool! A custom kit sounds like just the ticket for most. Support is worth the entry fee.
Saying your kit works with only the pre filter is where I get the one size fits all. What if I want to keep the stock air box set up. If I'm not restricting the air flow do I really to open up the IAJ? The matrix shows only Uni users upping the IAJ.
Old 05-11-2008, 09:59 PM   #75
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,159
W/O a prefilter it is true that with the stock needle and the stock pilot jet that increasing the idle air would be a bad thing for sea level to 4k.
Times are GMT -7.   It's 09:45 AM.
