Old 06-21-2013, 09:29 AM   #571
WayneC1
Oddometer: 2,741
Re the caliper hanger built in post 568 on the previous page, the caliper hangers are normally a stock Brembo part, the caliper looks like the same as the 650GS/KTM950 and the caliper hanger from a KTM 950 would be the part to get rather than making one up
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 06-21-2013, 03:50 PM   #572
MJS
MJS's Avatar
Oddometer: 1,928
Originally Posted by Viv View Post
I have some Shivers from a Husky 610 and they have the 58mm lowers. I could have them machined to 57mm or have the bottom yokes opened by machining to 58mm.
Alternatively is it possible to use the original Xchallenge upper part (the outer slider) and fit the Shivers parts to that?
Viv
You can machine the outer down to 57mm or use the stock X-C upper. There is not enough material to open the bottom tripple.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 08-08-2013, 10:23 AM   #573
cobrakai
Oddometer: 83
To those of you who swapped over to a 45mm shiver by switching lugs only.
Was it worth it? Does the fork actually have high speed bump compliance now?
What should I expect to pay for a 45mm shiver fork? Not counting having to swap/machine the lugs, respring, preload spacers, etc. Just the price of a base fork.
cobrakai is offline   Reply With Quote
Old 08-08-2013, 11:51 AM   #574
Viv
Oddometer: 53
In the UK I paid 100 for Shivers off a 610TE Husky and that included the yokes.
Not fitted them yet so can't comment against your other questions.
Viv
Viv is offline   Reply With Quote
Old 08-08-2013, 12:27 PM   #575
cobrakai
Oddometer: 83
Viv
bloody cheap!
Old 08-08-2013, 02:09 PM   #576
cobrakai
Oddometer: 83
Another question...
Found a set with 58.4mm lower clamp and 53mm upper clamp. This is the wrong size for both. I really don't want to machine the lower clamp or shim the upper clamp area. Can anyone confirm that I can simply use my stock upper tube, and swap all the other parts over? Can the seals and bushings also swap over?
Old 08-09-2013, 12:21 AM   #577
Viv
Oddometer: 53
Another question...
Post 572 above?
Viv
Old 08-09-2013, 12:30 AM   #578
Viv
Oddometer: 53
bloody cheap!
Exactly what I thought, hence the buying of them without a proper plan to fit them.
Some more still for sale. Not sure about the postage charge to the US...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=181190802933
Viv
Old 08-09-2013, 12:32 PM   #579
cobrakai
Oddometer: 83
Viv
Looks good. That's about $250 shipped to me in the US. Since I'm just going to simply swap dampers and lugs it doesn't matter if they're a bit beat up and the seals are all leaky.
Old 08-12-2013, 08:32 PM   #580
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,359
I just picked up an XC and am a wee disappointed in the forks. I haven't made my way through the entire thread yet, but has anyone explored replacing them with g450x forks? They would appear to be very similar.
Thoughts?
Edit, just looked them up, $1175 per leg? Did I read that right?
HowlingMad is offline   Reply With Quote
Old 08-12-2013, 09:23 PM   #581
SchillerM
Oddometer: 210
Thoughts?
Or $250 (something like that) on eBay right now...
No affiliation.
Matt
2009 BMW G477X - Akrapovic, WP Trax, PCV, Speedbrain tank, Speedbrain Graphics
2007 BMW G650 XCountry - ABS, Lowered, Hepco Becker Goodies, Remus Freeride - Wifes ride
2003 BMW R1100S BCR - #57/200, Laser, Ohlins, Other goddies - RIP Jeff; 1999 BMW R1100S - Remus (For Sale soon); 1989 BMW K100RS - Remus, Fox Rear; 2000 BMW M5 - Few Dinan Goodies..
SchillerM is offline   Reply With Quote
Old 08-12-2013, 09:32 PM   #582
cobrakai
Oddometer: 83
The G450X has a bit more travel than the G650 so you will probably want to shorten it like most other options..
Old 08-13-2013, 02:31 AM   #583
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,285
Howling mad
Only about $100 more than Xch fork legs then.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 08-13-2013, 10:35 AM   #584
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,359
No affiliation.
Matt
I took the wheels off both today and there are some complications including slightly different fork sizes. Bummer.
But still, the eBay find got me all stirred up, but I have a question: Does anyone know if the bottom part of the fork can be swapped from one fork to another assuming the diameter is correct? Both are made by Marzocchi, right?
Thanks for you help.
Old 08-13-2013, 11:57 AM   #585
cobrakai
Oddometer: 83
I can confirm this for you in a few weeks, but yes it seems that is the case. Looks like Marzocchi made multiple types of this fork in different configurations for different bikes all based on the same platform.
Times are GMT -7.   It's 02:31 AM.
