Old 10-05-2013, 01:44 PM   #586
alpi
alpi's Avatar
Oddometer: 76
Hi Mike,
I have a pair of WP 4860 and the lower Emig clamp waiting in my garage to get adapted to my '07 XCh. I contemplated buying the axel from them, too, but I somehow balked at the price... in comparison to the much elaborate clamp, I didn't think it was worth it. I plan to get the suspension shop fabricate it, but now seeing your ingenious solution I would much appreciate if you can provide some size details for the 3 components... I guess you are reusing the original XCh axel and made 2 pieces: a "shim" and an extension. It would be awesome if you can maybe share with us the fabrication details
Thanks,
Al
Originally Posted by mbfj40 View Post
Emig Racing already has such a product for the X-bikes. I have one on my '08 XCountry with the WP 4860's and it works and fits great. I made up my own axel spacers and brake adapter and am using the stock front wheel. But they offer everything in a complete package if you want. And a replacement top clamp that mounts their steering damper as well. The top clamp/damper assembly can be used with or without the fork conversion kit if you still have money to spend.
mike
http://www.emigracing.com/BMWXConversion.htm
'07 G650 XCh (and '04 recumbent bike)
alpi is offline   Reply With Quote
Old 10-06-2013, 06:52 AM   #587
Rider of the North
Oddometer: 18
Hi alpi.
You can buy an axel reduction kit for KTM,takes the axel diameter from 26mm to 20mm and use the original BWM axel,spacer and front wheel.
You also have to get the caliper hanger from a KTM 690 E or 950 super enduro.
They both have a 300mm front rotor.
Only thing is you have to machine down the thicker part of the OEM axel from 25mm to 24mm.
Takes a few minutes on the lathe.i
Then just install and go ride and enjoy.
Rider of the North is offline   Reply With Quote
Old 11-01-2013, 05:24 PM   #588
mtncrawler
mtncrawler's Avatar
Oddometer: 1,130
Buyers guide..
Hey y'all,
I've read quite a few threads on X front suspension upgrades and I want to make it my winter project. I haven't decided on which way to go yet - simple upgrade in the fork legs to fit my triples to a complete KTM front end job as some have done, or something in between (like to accommodate low fender). In addition, I'm not sure if WP 4860's or Shivers are the way to go. My real question is - and I may have missed this somewhere - how can I know or be sure that the forks that I buy are close in fork length/travel/triple clamp spacing to my OEM legs in order keep things close (even triple clamp diameters for that matter)? I've read folks buying forks from KTM this or Aprilla that - but is there a WP or Marzocchi spec sheet that tells you exactly which bike model, came with what fork, and what the overall specs were so I know what to look for when it comes buying? Kind of a guide/spreadsheet, instead of having to look at individual bike/fork spec sheets?
As I understand things there are a series of 4860's and Shivers out there that differ based on the bike, correct?
Any help would be appreciated!
BTW - if you have a set that I may be interested in (or have a lead on some) let me know!
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is online now   Reply With Quote
Old 11-01-2013, 06:55 PM   #589
WayneC1
Oddometer: 2,624
I have a spreadsheet with a lot of info on the WP forks, which fork type came from which model etc and part No's and other info. The Airhead guys are using it to help with their conversions even though I put it together for 650GS perhaps it might help you
http://www.f650gs.crossroadz.com.au/ForkUpgrades.html
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is online now   Reply With Quote
Old 11-02-2013, 09:04 AM   #590
mtncrawler
mtncrawler's Avatar
Oddometer: 1,130
Thanks - looks like some useful stuff there - I'll be sure to dig into a bit more!
Appreciate you posting this..
Old 11-12-2013, 05:23 PM   #591
gsstampeder
gsstampeder's Avatar
Oddometer: 1,082
Anyone know if the g450x front forks can be fitted easily on the x-c?
Sorry if this has been asked already...nothing came up on my search
5 weeks in Baja
gsstampeder is offline   Reply With Quote
Old 11-17-2013, 07:46 AM   #592
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,984
Why would you? They arent much better.
But they probably drop right in at the top - not sure about the bottom end of the forks - if they match up
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 11-21-2013, 06:32 PM   #593
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 470
Anyone found preload adjusters for the OEM fork caps? Perhaps a swap from another bike?
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Old 11-25-2013, 04:51 AM   #594
casperghst42
casperghst42's Avatar
Oddometer: 215
Would Husqvarna SMR 450 Marzocchi Shivers work on the xChallange - either rebuild, or as a transplant ?
Casper
photos.exilepixel.com
casperghst42 is offline   Reply With Quote
Old 11-28-2013, 10:46 PM   #595
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,984
Casper
What year?
I know the 2008 -09 model has almost the same forks I have in mine now - 50mm marzocchi twin chamber forks. http://www.motorcyclespecs.co.za/mod...m450r%2009.htm (SMR had shorter 250mm travel). Thats a pretty extensive transplant - involving triple clamps and front wheel as well.
But Husky were changing forks almost on a yearly basis. Each year has different size forks. Not like KTM which runs the same size forks and triples in almost all their bikes for a decade.
Old 11-29-2013, 02:35 AM   #596
casperghst42
Oddometer: 215
Originally Posted by Colebatch View Post
What year?
They are from a 2003, which is using 45mm. I asked "The Guy from Hyperpro who should not be mentioned", who said that they should work (also he is also going to do the work).
I got them for 150, and I suspect that they will be used for a transplant, if not, I can always donate them to an xMoto owner
Casper
Old 12-02-2013, 12:21 AM   #597
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,984
Oh him?? If he says it, then it will be true :)
Old 12-24-2013, 09:52 AM   #598
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,853
Has anyone gone the route of just adding the hyperpro progressive springs to the stock forks? I know there is only so much performance to be had from the OEM set up but I don't have the time/energy to devote to a complete fork swap at this time and was just wondering if anyone else had gone this route and if it was worthwhile? FWIW I am 150lbs.
Thanks.
swimmer is offline   Reply With Quote
Old 12-24-2013, 02:23 PM   #599
MJS
MJS's Avatar
Oddometer: 1,912
Thanks.
If you are 150 lbs the stock springs are probably about right. You might try changing your fork oil to 15wt and keeping the stock springs. When you buy the HP springs you will get the heavier oil as part of the package. At least I did.
IMO the real issue with the forks is the lack of dampening control. It's not just the separate rebound and compression but the poor performance of the stock valving (or lack thereof). That's why people convert to the Shiver internals or do the WP fork swap.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 12-25-2013, 06:15 AM   #600
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,853
Thanks. I need to read more about the shiver internals.
Times are GMT -7.   It's 06:55 PM.
