Old 01-21-2008, 04:04 PM   #136
R3B
Lazy Motorcyclist
R3B's Avatar
Oddometer: 1,279
Originally Posted by yusuf
Let me ask please a further question:
how / where do you suggest to fix the headlight?
This is an important issue I think.
I already ordered a 20 cm diameter headlight from a Dutch store.
Please, could you give me some suggestions how to build a proper bracket?
You'll need the bracket of an yamaha SR500, which can be modified so it hangs under the top bracket, and is supported by a "ski" on the headstock, in future i will make somemore pictures to explain the modification, so watch R3B in the future, although it will take this lazy motorbiker some weeks to percolate it into a understanable story.
I hope to build my own R3B2, if you agree with the name
PS:
Are the TCK 80 so dangereuse in wet road? I thought to use them also for each day..
They look so great and wilde on the GS!
Nooow, they're not dangerous, it's more like the grip of tourances now, while the german made TKC's had more grip in the cold Anakees, and the same dependable incoming slide behaviour.
The Korean TKC is more like the Tourance, "now you have grip, and then you don't have anything anymore"
P.S. this actually was deu to an oilspill btw.
Every Adventure big or small
................*is* an Adventure all in all.
.........................So every day: Give in to the call
Riding tips: . -----www.LazyMotorbike.eu-----
R3B is offline   Reply With Quote
Old 01-21-2008, 06:35 PM   #137
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 637
Originally Posted by Boojum
I actually taped off the area at the bottom, and lids, and sprayed them in 3M Rubberized Undercoating, and then clear coated them with rattle can. I do a touch up every now and then.
Very nice. I REALLY like the look and doing this would also cover up some deep scratches on my Jesse's. Does the undercoating require the clear coat to be durable or would it rub off without it?
Or...I'm guessing a coat of spray can bedliner would suffice, based on the number of tanks coated with it I've seen here in other postings
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline   Reply With Quote
Old 01-23-2008, 08:30 PM   #138
BARB
Oddometer: 2,879
First photo is last month, second one is yesterday (mock-up) Trying to decide on paint now. Barb
www.alaskaleather.com
BARB is offline   Reply With Quote
Old 01-24-2008, 07:52 AM   #139
Cycletroll
Catastrophe Specialist
Cycletroll's Avatar
Oddometer: 1,082
Looks cool BARB! Keep us posted.
"The problem with the Common Man is, he's so damn common!"
R1200 GSA
Cycletroll is offline   Reply With Quote
Old 01-24-2008, 08:27 AM   #140
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,214
Wow - what a change in the looks! Tre' cool! Is that the Touratech kit?
LoneStar is offline   Reply With Quote
Old 01-24-2008, 01:07 PM   #141
BARB
Oddometer: 2,879
Yes, I am a dealer so that's my excuse. The last time I rode mine I decided I am not getting any younger, stronger or taller. So I put Hyper Pro shorter shocks on it and shaved a bit of weight. Kept the ABS because I like it. Put on Conti road attacks. Now it looks like a giant supermoto. Barb
Old 01-24-2008, 03:14 PM   #142
yelostn78
Have GS will Travel
yelostn78's Avatar
Oddometer: 598
[QUOTE=R3B]Yeah, we should eventually switch out to Old School :-)
The R12GS and new kid on the block F8GS taking the masses...
Here's my RatBikeBumbleBee in action...
And of course in its more natural Habitat:
Dude,
your gs looks freaking great, I have always thought of retro fitting the R1100R instrument cluster and headlight to mine to make it look more like a tougher version of the R, And now I have finally found someone else with the genius idea.
Fact- black bears like Beets
yelostn78 is offline   Reply With Quote
Old 01-24-2008, 04:19 PM   #143
MooseKiller
Tripod
MooseKiller's Avatar
Oddometer: 4,604
Damn nice lookin' bike, Barb! My beastie is way jealous!
I used to be an adventurer like you, until I took a Hyundai to the knee...
MooseKiller is offline   Reply With Quote
Old 01-24-2008, 04:56 PM   #144
sojahseh
sojahseh's Avatar
Oddometer: 153
Originally Posted by TexBiker
Which pieces are you referring to? The metal tanks for the 1100 and 1150 are the same (excluding the Adv tank, of course.)
I was looking a the silver pieces in between the beak and the tank. But you're right, I'm trying to fit a ADV tank up.
Doesn't it stand to reason that the profile of the tank right there would be the same on either bike or either tank?
sojahseh is offline   Reply With Quote
Old 01-24-2008, 05:23 PM   #145
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,214
No excuses needed Looks awesome and hard to believe there's an 1100 sittin there
Old 01-24-2008, 07:51 PM   #146
TexBiker
TexBiker's Avatar
Oddometer: 815
The silver part is just a cover panel. It's the same regardless of which tank you use.
The plastic tanks and metal tanks have slightly different profiles at the front. However, the ADV tank should use the same rubber supports as the regular metal tanks. These supports fill the gap between the tank and the cover panel / lateral trim panels up front. The part numbers for the rubber supports are:
46632324873 - Left side
46632324874 - Right side
Suppose you were an idiot...And suppose you were a member of Congress...But I repeat myself.
-Mark Twain
TexBiker is offline   Reply With Quote
Old 01-25-2008, 12:47 PM   #147
LongWays
Skiing up a hill...
LongWays's Avatar
Location: City of Subdued Excitement.... no really it is!
Oddometer: 5,212
If you don't like my sig line - don't read it.
LongWays is offline   Reply With Quote
Old 01-25-2008, 11:29 PM   #148
BARB
Oddometer: 2,879
I have two used rubbers (I know, that sounds bad, but they are in good shape) PM me if you want them. Barb
Old 01-27-2008, 03:37 AM   #149
S2W
I said wax ON you idiot!
S2W's Avatar
Oddometer: 3,351
Travelling light for day ride.
Steve
_______________________
S2W screwed with this post 01-29-2008 at 01:50 PM
S2W is offline   Reply With Quote
Old 01-27-2008, 08:29 AM   #150
Advaita Eyes
Oddometer: 113
Originally Posted by cueball
my '95
Hi, Frank. Wjhere did you get that back pad for the passenger? I haven't found one yet, that looks at meaty as that one, for the 1100gs.
TIA
AE
Advaita Eyes is offline   Reply With Quote
Times are GMT -7.   It's 08:31 PM.
