Old 11-05-2007, 09:11 AM   #76
R3B
Lazy Motorcyclist
R3B's Avatar
Oddometer: 1,279
Originally Posted by KSBEERHUNTER
It seems with each new model that comes out they just get more unreliable and with a higher price tag. Didn't hear much about major problems with the 1100s. I read about the number or rearend failures. Again, beautiful bike and looks very light.
The 1100 has one major gripe and thats the tranny, first years the 3rd tends to wear out quick, and the subframe tears itself out of the gearbox, but thats easily fixed with touratech hardparts (if you have a 11 without *get* them !)
Every Adventure big or small
................*is* an Adventure all in all.
.........................So every day: Give in to the call
Riding tips: . -----www.LazyMotorbike.eu-----
R3B is offline   Reply With Quote
Old 11-05-2007, 11:06 AM   #77
GollyGwiz
GollyGwiz's Avatar
Oddometer: 336
My 99 R1100GS
Big Bend
Needed a set of TKC's for this day ...
North of Copper Canyon
GollyGwiz
Grapevine Texas
1999 R1100GS & 2014 R1200RTW
IBA# 7309
wan-der-lust A very strong or irresistible impulse to travel.
GollyGwiz is offline   Reply With Quote
Old 11-05-2007, 12:39 PM   #78
TexBiker
TexBiker's Avatar
Oddometer: 815
My '95 "FrankenGS" 113k and still going strong...
With original plastic tank refinished with bedliner:
With 1150GS tank after neighbor's kid decided to play with my nailgun:
Suppose you were an idiot...And suppose you were a member of Congress...But I repeat myself.
-Mark Twain
TexBiker is offline   Reply With Quote
Old 11-05-2007, 02:49 PM   #79
Kongo
Dog's best friend
Kongo's Avatar
Oddometer: 537
This is mine just after I painted the tank, beak, and tailfeather -- and just before the paint started bubbling and peeling back off the tank. This look lasted about two weeks. Maybe I will get in line at BeemerBoneyard for a metal tank when one shows up -- next winter's project.
It just went through 60K miles. The seats are from Rick Mayer. Came with that Staintune exhaust, so now I am illegal in Denver. I mostly use this for looking around the beautiful contryside here in northern Colorado. Having a GS makes it all that much better, no need to stay on pavement. Better tires would help for that, but these Tourances are OK for now. Next problem to solve: air over that stock windscreen hits me about eye level -- wind noise driving me to tinnitus even with ear plugs under a helmet.
Always starts & runs fine. Everything works: ABS brakes, tranny, and no surging. The right TB rattles a bit, needs a new shaft but OK for now. Amazing how small problems seem as long as I can ride it.
'95 R1100GS A
Kongo screwed with this post 11-10-2007 at 10:44 PM Reason: The attached pic is no longer there. (?)
Kongo is offline   Reply With Quote
Old 11-05-2007, 02:52 PM   #80
Kongo
Dog's best friend
Kongo's Avatar
Oddometer: 537
Here is that same tank now. Don'cha just love plastic tanks?
'95 R1100GS A
Old 11-11-2007, 07:59 PM   #81
Jim Rowley OP
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Attachment 142527
It's nice patina. May I suggest coating the interior of the tank before repainting? It will seal the gas off.
Jim.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 11-11-2007, 08:07 PM   #82
joe a
awryder
joe a's Avatar
Oddometer: 620
joe a is offline   Reply With Quote
Old 11-12-2007, 06:03 AM   #83
whiteknucklemc
whiteknucklemc's Avatar
Oddometer: 644
90,000 miles and still loving the ride.
whiteknucklemc is offline   Reply With Quote
Old 11-12-2007, 06:46 AM   #84
Kongo
Dog's best friend
Kongo's Avatar
Oddometer: 537
Jim.
Thanks for the thought Jim, but I did that. Used a phenol novolac 2-part epoxy tank sealer from Caswell. I wish that were the answer. The only thing I could figure is that some of the gas was trapped in the plastic by the sealer on the inside and the new paint on the outside. Between the two, the paint was the weaker. Tank works fine as a tank -- doesn't leak. I put a lot of hours into scraping/sanding that thing to bare plastic, plus several layers of "adhesion enhancer" primer for plastic auto bumpers followed by more layers of high-fill primer. The paint was $70/quart automotive urethane applied by a pro. The experience killed my ambition for doing it again. This winter I may get in line at the Boneyard for the next decent metal 1150 tank that shows up. Or . . . maybe I will get into stickers, or a wider version of the tank panniers like whitenuckle has on his. I just like to ride the thing. And I have to admit it gets a lot of looks. I like to imagine they are looks of envy because I have obvously been around the world on it. (not true!)
'95 R1100GS A
Kongo screwed with this post 11-12-2007 at 06:58 AM
Old 11-12-2007, 06:54 AM   #85
FXRocket
Phoneticide Squad
FXRocket's Avatar
Oddometer: 5,315
Kongo, strip it & take it to the "Rhino lining" place and get it done in a color of your choice. At least it will look good and have a bit of protection for a low investment in T&M.
If you say "Gullible" slowly it sounds like "Oranges".
FXRocket is offline   Reply With Quote
Old 11-12-2007, 10:04 AM   #86
ADK
____
Oddometer: 8,235
Get a vinyl cover.
ADK is offline   Reply With Quote
Old 11-12-2007, 09:26 PM   #87
Kongo
Dog's best friend
Kongo's Avatar
Oddometer: 537
Originally Posted by ADK
Get a vinyl cover.
I've been thinking the same thing, but not finding it. Any suggestions?
Thx
'95 R1100GS A
Old 11-13-2007, 05:45 AM   #88
Jim Rowley OP
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Thx
Bagster. Tank cover with clips so you can snap on a tank bag too.
Jim.
Jim Rowley
Black Forest, CO
Old 11-13-2007, 07:35 AM   #89
R3B
Lazy Motorcyclist
R3B's Avatar
Oddometer: 1,279
My suggestion would be, do it again, but now in a Thin spread so the fumes can just evaporate through a thin skin, instead of being trapped under a thick unbreathable layer...
Old 11-13-2007, 08:42 AM   #90
CopperGreen
CopperGreen's Avatar
Location: Los Angeles, Ca. Currently in New Orleans, LA
Oddometer: 199
I know a place in LA that will spray on a conductive paint then chrome it....
CopperGreen is offline   Reply With Quote
Times are GMT -7.   It's 12:50 PM.
