Old 10-25-2007, 03:46 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,534
Question Nav II direct cable?
I have a BMW Navigator II with th cradle and I want to hook up on my R100GS.
It has a load of cables.
I''ve got the BMW accessory plug cable, and another for plugging into a newer bike's harness (I assume).
My older Nav I is wired right to the battery.
Is there a direct to battery cable made for the Nav II?
Suggestions?
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog screwed with this post 12-03-2010 at 10:39 AM
Rapid Dog is offline   Reply With Quote
Old 10-25-2007, 11:24 PM   #2
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
This will work..
https://buy.garmin.com/shop/shop.do?pID=1055
Burnszilla is offline   Reply With Quote
Old 10-26-2007, 08:16 AM   #3
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,534
hard to see, does it have the correct plug for the Nav II cradle?
Old 10-26-2007, 08:31 AM   #4
Rick G
Ranger Rick
Rick G's Avatar
Oddometer: 2,032
The Nav II is basically a Garmin 2720 and I beleive the connection at back of the unit is same for both. Should plug right in.
Rick G
Any Road Any Time!
2011 BMW R1200R - The Redhead with Big Jugs I have always wanted!
2009 Vespa GTS Super 250ie - Just for Kicks & Giggles
Rick G is offline   Reply With Quote
Old 10-26-2007, 09:26 AM   #5
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,534
The NavII has the cradle which has the flat connector to the GPS plus a Y that has a round connector to the cradle.
Old 10-26-2007, 01:22 PM   #6
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
The part I posted is flat GPS power & audio connector. It does not have the round connector.. What's the round connector for? Antenna? or does it power the cradle buttons? If you need the round connector for it to work you will just have to buy the expensive BMW branded connector, cut it and connect it to the battery. Or just cut the one you have and wire it to the battery.
Old 10-26-2007, 01:44 PM   #7
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,534
yes, I believe the roundie powers the cradle.
I suppose I can cut the accessory plug off the end and hardwire it .
I wonder how many and what wires there are in there...
Here's a pic of what it looks like, thanks to MikeO..
Old 10-26-2007, 07:08 PM   #8
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
There's a red and white wire.. red is positive, white is negative.
Old 10-27-2007, 12:10 PM   #9
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,575
Hey Randy,
I went through all this when I was hooking up my Nav II to my S, now it's on the GS. It was very hard to get info on the BMW units and what wires were for what purpose. I called dealers, BMWNA and BMW Canada and finally got some vague info. I bit the bullet and cut the plug off the cable and wired it up and it didn't fry! You can cut the cable to the length you need and inside you'll find a red, a black and a purple. The purple is for audio hookup on bikes like the LT that have audio in the harness so you can disregard it and used red for power. I put a BMW plug on the end and installed a female plug near the handle bars and it works fine. Make sure to check polarity as I burned out a Sirius radio by not paying attention.
HTH
Dan
Dan Alexander is offline   Reply With Quote
Old 10-29-2007, 08:16 AM   #10
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,534
Thanks Dan'l, yoou de man!...and ;fanks to da rest of yas too!
Times are GMT -7.   It's 03:09 AM.
