11-01-2003, 12:03 PM
#1 |
Call me "thread killer!"
Oddometer: 1,805
Airhead pushrod seals
Anyone ever replace these on their airhead? I've got all the tools and the parts but am looking for any tips / hints / suggestions about this repair?
11-01-2003, 12:18 PM
#2 |
GS Dork
Oddometer: 5,299
Been there done that
I've done this a few times.
You'll need: -New valve cover seals and cylinder O-rings. -New tube of Dirko or Yamabond -New o-ring seals, 2 per side on the top-most engine stud oil gallies. The big thing to remember is to TAKE YOUR TIME! Remove the valve assemblies by bringing to torque down sequentially and slowly. Keep the towers assembled but remeber to inspect the rocker arm shaft wear surfaces and the rocker arm needle bearings. Remember to locate the dot on the rocker arm shafts in the correct orientation for oil flow when you reassemble them. You can disconnect the wrist pin and leave the piston in the cylinder. This wil save you a lot of grief and time. Clean all of the seal mating surfaces with a good solvent and try not to get any crap in motor. Get rid of any traces of oil in the motor recesses for the pushrod tube seal with a good solvent and a clean rag. I like to smear a little Dirko or Yamabond onto the face of the pushrod seal where it meets the motor. Most mechanics I know don't think that it does any harm. Check you valve rocker end float (vertical movement) before you go to the trouble of adjusting valves. Shim if necessary. Buy a few different-sized shims beforehand and keep them around. Hope this helps. Let us know if you get stuck or need any more tips/help. Cheers, Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"." HST-RIP "Woof, woof woof woof ...woof woof!!!!!!!!!" Cricket the Dog-RIP |
06-03-2008, 09:19 PM
#3 | |
the thread-killer
Oddometer: 4,297
Not all bikes use the orings on the studs, not all bikes have end pay shims and if it's a typical /5 he will drive himself nuts trying to get the end-play out of the rockers EVEN if he replaces the original wavy sims with the later non wavy ones. SO MANY different ways to do this job, SO MANY different bikes, although I agree that you can do the job without pulling the piston out of the jug, ( I do it that way cuz I'm lazy) I DON"T agree with you on sealing the PR seals with goop. Never done it never will. Robert |
06-03-2008, 09:25 PM
#4 |
Oddometer: 1,151
An old airhead guru taught me this trick and it has worked twice for me. If your pushrod seals have an alloy ring around the outside you can take a block of wood and tap them in all the way around using a mallet. Just work them in with a decent lick all the way around striking the alloy ring in about four or five places. It drives the seals back in. Both times it worked like a champ for me.
Barry
2012 Kymco GT300i 2006 Honda ST1300 (for sale) 2009 Kymco Agility 125 2007 Piaggio BV 250 |
06-03-2008, 09:29 PM
#5 | |
last of the Dum Dum Daze
Oddometer: 1,650
Not to be a dick, but are you seriously going to drag out a thread that has been dead for 4 and a half years and critique the advice? unless that dude is even lazier than I am, he has long since changed out the damn pushrod seals. edit: fill out your profile, let us know who you are |
06-03-2008, 10:19 PM
#6 | |
GS Dork
Oddometer: 5,299
Yeah it's an old thread. If you've got something constuctive to add then add it. If not, STFU. Or should I translate that for you? Cheers, Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"." HST-RIP "Woof, woof woof woof ...woof woof!!!!!!!!!" Cricket the Dog-RIP Rubber Cow screwed with this post 06-03-2008 at 10:27 PM |
06-03-2008, 10:43 PM
#7 | |
Heavyweight Boxer
Oddometer: 4,758
maybe the bike in question is already long gone... |
06-04-2008, 06:10 AM
#8 | |
Old Enough To Know Better
Oddometer: 5,527
Mine are weeping on one side, but nothing wiping with a rag once or twice a week won't fix, so I'm not in a hurry to go into the motor yet. But if that works in situ, I'll probably give it a shot.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
06-04-2008, 06:15 AM
#9 | |
GS Dork
Oddometer: 5,299
I believe the post '78 twins have a brazed collar that can't be tapped in as you described. Cheers, Jorge
06-04-2008, 06:18 AM
#10 |
Oddometer: 1,805
The OP speaks...
That was my old ADVRider screen name and it's nice to see old threads never die.
FWIW, I did replace the seals and Jorge, your input was very valuable. Since that initial effort I have worked with a few BMW wrenches who used a little silicon sealant on the surface where the seal meets the block. Not a lot, just a skim coat. Works like a charm.
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole." 1981 R80G/S 1991 R100 GSPD FIRST TIME RIFF RAFF - Go Jonah! |
06-04-2008, 07:17 AM
#11 | |
Oddometer: 1,151
Barry
06-04-2008, 01:56 PM
#12 |
Oddometer: 5,527
Sounds worth a closer look. My seals appear to have a metal ring that fits close around, but not attached to the pushrod tubes. As soon as it cools down on the driveway this evening, I plan to give it a try.
Worst that can happen is that I'll increase the weepage and have to change the seals - and that may be getting closer anyway. I noticed on the right side, which doesn't leak a bit, the seals are getting dry cracks in the rubber. So I know the day is coming.
06-04-2008, 02:17 PM
#13 | |
Oddometer: 1,151
Barry
06-04-2008, 02:39 PM
#14 | |
Red Clay Halo
Oddometer: 11,360
Wow, a '72 huh? And here I though they didn't start the /6 series until '74.. Why the big fuss about leaving the piston in the cylinder? It takes a little finger pressure and all of about 10-15 seconds to get the pistons back in the cylinders.. At least on my '74 R90/6.. Duane does them pretty quick too... BMW Piston Ring Compressor..
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
06-04-2008, 02:41 PM
#15 | |
the thread-killer
Oddometer: 4,297
A little hostile are we? Dude, grow up. Robert |
