10-27-2007, 08:05 AM
#1 |
Flying Old Fart
Oddometer: 66
What Is The Best Procedure For Changing Coolant In Ktm 640 Adv?
Got a new 07 640 Adventure, and checked the coolant and found it to be good to only -10F, and it gets way colder up here. Unlike my KLR which has a drain screw at the lowest point under the water pump, I can find no such drain on this bike. I figured on pulling the lowest hose connetion on the front of the jug, but decided to throw this out in case there is a better way. Any help will be greatly appreciated. DBG
10-27-2007, 03:24 PM
#2 | |
Stoic Philosopher
Oddometer: 4,154
Keep faith with our American heros: Wounded Warrior Project www.woundedwarriorproject.org Special Operations Warrior Foundation www.specialops.org/ |
10-27-2007, 06:24 PM
#3 |
Oddometer: 265
I don't know about the 640 but my 450 KTM has a air bleed screw on the head near the sparkplug to drain the air out after you start filling it, plus there is an air bleed screw on the right radiator right up on top.
10-29-2007, 10:25 AM
#4 | ||
Ignostic
Oddometer: 13,839
![]() When you refill it the manual says on page 36 for the 2003 model year to run the bike with the cap off for a bit to top off but you will have to check the coolant level spec (10mm above the radiator internals inside the cap) when engine is COLD. Here is a copy and paste: Quote:
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
10-29-2007, 01:46 PM
#5 | |
Stoic Philosopher
Oddometer: 4,154
Thanks for adding your knowledge to this here thread. Also thanks alot for pissing off gaspipe and chasing him away. Jeez, all the LC4 gurus are dropping like flies, creeper doesn't even have one anymore, gaspipe is gone, loaded barely hangs out here anymore. Maybe when the new 690 Baja and Rally (or whatever they are going to call them) come out we'll have a big old LC4 revival.
10-29-2007, 03:13 PM
#6 | |
Ignostic
Oddometer: 13,839
![]() I pissed off gassy? What, where, when, why, how? Link?Well, it is the end of the model line so we should have this ole'LC4 business buttoned up soon. The new ones have silly pipes; I don't know...
10-29-2007, 03:36 PM
#7 | |
Stoic Philosopher
Oddometer: 4,154
http://www.advrider.com/forums/showthread.php?t=279201 As far as the new 690 hotness goes, me thinks I will hang on to the 640. Of course if they do start selling that bike they raced in the Baja 500, I will buy one immediately.
10-29-2007, 03:44 PM
#8 |
resident alien !!!!
Oddometer: 792
coolant
just wait for the water pump to fail and then refill
( after fixing the pump )
10-29-2007, 04:38 PM
#9 | |
Ignostic
Oddometer: 13,839
Ah, the Baja KTM is sexy, but it wears its upswept pipes much better than these production 690 IMhO.
10-29-2007, 08:05 PM
#10 | |
Molon Labe
Oddometer: 6,286
Chris '03 KTM Adventure 640 '43 BSA M20WD |
10-30-2007, 04:06 PM
#11 | |
Still alive...
Oddometer: 10,718
Mmmmmmm... Sherco.
10-30-2007, 05:47 PM
#12 | |
Molon Labe
Oddometer: 6,286
Had the Sherco "across the bridge" yet?
10-30-2007, 07:47 PM
#13 | |
Still alive...
Oddometer: 10,718
My arms are so screw'd up that I haven't ridden the Sherco much. Boo fuckin' hoo huh? I've got less than 10 hours on it... but hey, I did write a Sherco valve lash guide. ![]() Hi ho, hi ho... |
10-30-2007, 08:33 PM
#14 | |
Ignostic
Oddometer: 13,839
07-23-2009, 11:04 AM
#15 |
four-stroke earth-saw
Oddometer: 655
I drained the coolant on my 625 the other day.
![]() I must say, for a company famous for making not only fantastic bikes, but well-thought-out fantastic bikes, they really screwed the pooch on this one. I made a god-awful mess all over the bike, and had to tip it at ridiculous angles to try and get it all out. Even then, I'm not sure I did. What a crappy design. Compared to the RFS motors, its a big step backwards!
Buy it, use it, break it, fix it. |
