Old 10-29-2007, 09:49 PM   #1
Mulga OP
Mulga's Avatar
Oddometer: 112
Question My clock has vanished!!! (640adv)
Howdy,
I have a 05 640adv. Recently i had my battery out and have now only realised the clock mode in the "multi-fuctional digital spedometer" isn't there anymore. There isn't even the 0:00 that is there when you first connect the power.
Does anyone know how to remedy this?
Cheers
Dan
2005 KTM 640 Adventure
Mulga is offline   Reply With Quote
Old 10-29-2007, 10:34 PM   #2
KTMax m AL
Fagarwe tribal member AL
KTMax m AL's Avatar
Oddometer: 303
Eek
Check the fuses next to the battery. I think it is a 10 amp one that powers the clock and the Power Let accessory plug in the dispaly.
If there is no power to the clock it will only display 0:00. If not a fuse then there may be a problem within the display unit.
good luck
KTMax m AL screwed with this post 10-29-2007 at 11:49 PM
KTMax m AL is offline   Reply With Quote
Old 10-30-2007, 05:33 AM   #3
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
I'm not sure on your 05 Adv but my 04 SXC required the little battery to be mounted in the display in order to get the clock to work. Since you removed the battery, is it installed correctly or are you sure it has a charge?
Techieguy
Reality does not always develop in a way we expect it to.
techieguy is offline   Reply With Quote
Old 10-30-2007, 03:05 PM   #4
Mulga OP
Mulga's Avatar
Oddometer: 112
My batttery is installed properly and all my fuses are ok. I know my battery is a bit old now it still fires up the LC4 without a problem.
techieguy; so you think the lithium battery in the unit itself may be stuffed? If this was the case wouldn't the Odometer reading also be out? or are they seperate batteries?
Cheers
Dan
Old 10-31-2007, 05:35 AM   #5
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
The speedo display is controled by the bike battery. The clock by the little lithium battery inside the unit.
Old 10-31-2007, 06:00 AM   #6
silver04rs
Stupid N0OB!!111
silver04rs's Avatar
Oddometer: 107
if its the same as my EXC you can turn on/off all the features in the speedo/clock unit..... I just forget how
something about when its off hold down a button... should be in the manual
silver04rs is offline   Reply With Quote
Old 11-01-2007, 03:22 PM   #7
Mulga OP
Mulga's Avatar
Oddometer: 112
Thumb
silver04rs
You were right
I held the mode and set buttons down, with the ignition off. Then i turned the ignition on and there was my clock!
I now know my son was climbing over the bike playing with everything.
Thanks mate
Old 11-28-2008, 12:35 AM   #8
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,779
Bluhduh I want a clock too...
So the clock is there and then its gone. Done the push the 2 buttons thing - reset the time - ride - turn bike off. Turn bike back on - no clock Its hard to keep looking at my watch on the go....
So there is a battery in the display????? I cant find any info on it in the elec diagrams. How do you get 2 it 2 change it ????
Fanks
Pete640 is offline   Reply With Quote
Old 11-28-2008, 07:50 AM   #9
thumperdump
thumperdump's Avatar
Oddometer: 44
I recently bought a '04 DRZ400S and something similiar happened to me, only it's the mph indicater, it registered in mph's when I first got the bike, than for no reasen, it now registers in km's instead, I held down the "SELECT" button for 3 seconds as the manual says to do to change from one to the other, but it won't change. I have the battery out for the winter right now, will stick it back in come Spring, hopefully I will know what the problem is by that time.
thumperdump is offline   Reply With Quote
Old 11-28-2008, 07:52 AM   #10
bakkie
Wilddog
bakkie's Avatar
Oddometer: 146
Fanks
I had the same problem with my 05 640A... check the fuses again!!!
There are no short cuts to anywhere worth going!
bakkie is offline   Reply With Quote
Old 11-28-2008, 09:13 AM   #11
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,838
the speeo/ico has a function switch .. Its the middle button and you can set trip1, trip 2, top speed, clock and a couple of others you can turn on or off. If you dont have the manual get one and you can turn on or off any of the functions. The battery is underneath the unit and is a watch battery and quarter is all you need to pull the cap.
wrk2surf is offline   Reply With Quote
Old 11-29-2008, 12:59 AM   #12
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,779
Thumb The clock lives.
Nice work Bakkie - checked the fuses again and sure enough blown. New fuse and the world is at peace again. So easy its almost funny.
Old 11-29-2008, 03:34 AM   #13
bakkie
Wilddog
bakkie's Avatar
Oddometer: 146
I went throught the whole process just like you and finally out of frustration checked the fuses and there it was. Glad I could help
Old 11-29-2008, 07:38 AM   #14
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Thanks mate
Put'n the blame on your kid! That is low
Rad is offline   Reply With Quote
Old 09-22-2012, 08:18 AM   #15
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,237
Tying up loose ends:
http://www.advrider.com/forums/showt...=216376&page=8
discussion and tips don't always happen in the proper thread.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 07:11 PM.
