Old 05-03-2012, 09:12 AM   #436
Ohio_Danimal
Midlife Crisis Man
Ohio_Danimal's Avatar
Oddometer: 556
Originally Posted by Ohio_Danimal View Post
Hey Bandito's
I'm looking for a pair of bandit 1250 mirrors.
They are identical to the mirrors on my SV650, except about aninch longer stalks.
I thought that this would be a good place to ask.
Top dollar paid!
sorry to interrupt the thread
self-promoting bumpola
Wisdom is age well spent.
Anger is age, hell bent.
Ohio_Danimal is offline   Reply With Quote
Old 05-04-2012, 10:07 AM   #437
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 2,989
Originally Posted by gashog View Post
The Versys had decent power, but this engine feels like a jet turbine when you open it up.
If you really want to feel a rush, install a Dale Walker Holeshot slip-on, high-flow air filter and a TPI box from Holeshot performance.
WOW!
Simple, and that's only like a "stage 1" change. I heard there's more fun to be found.
2013 Triumph Tiger 800 - 2007 Harley XL1200R Roadster - 2002 BMW R1100S
You can lead a politician to water, but you can't make him think. - Kinky Friedman
Improve your cosmic karma here!
ag_streak is offline   Reply With Quote
Old 05-04-2012, 11:36 AM   #438
Tango59
Oddometer: 37
Originally Posted by RoyQ View Post
I am the guy who first had COX make the radiator guard. Andrew was very supportive and took the time to take the initial measurements at a local dealer way back in '07. Mine never caused any over heating and stopped 3 large rocks from busting the radiator.
The frame on my Cox radiator guard broke (only bug hits) after about 10k mile on the frame of the guard. Soldering didn't work but the superglue seems to be working.
Tango59 is offline   Reply With Quote
Old 05-04-2012, 12:17 PM   #439
treybrad
treybrad's Avatar
Oddometer: 165
Just as a counterpoint, I've got somewhere around 45k miles on my guard it it's help up admirably. Quite a few dents and dings, but better on the guard than on my radiator. I wouldn't be surprised if you contacted Cox and they fix it or replace it for you...
trey
'07 Suzuki Bandit 1250SA
'08 Yamaha WR250R
treybrad is offline   Reply With Quote
Old 05-11-2012, 03:18 PM   #440
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,425
as most of you know the stock Bandit bars (600/1200/1250) are less than ideal in many ways.
the are too narrow for most and have way too much pullback, which causes your wrist to bend at an angle and cause pain after a short bit.
i contacted Dale http://www.holeshot.com/ about his strom touring bars and asked about some specs. specifically pullback as far as wrist comfort. we decided he would send me an un-coated bar to try and measure.
i'm here to report they are amazing.
they create a position similar to modern sport touring bikes. up right, comfortable with a slight forward lean.
the old bars measure (per someone measuring)
Width = 27 (to end of bar, not bar end)
Rise = 3"
Pull back = 6"
holeshot bars
width 30"
rise 6+"
pullback 3.5" (ideal IMO)
you get less pullback (which is ideal for wrist comfort) and a wider bar (subjective per rider but much better than narrow stock), thus the position (using numbers only) puts the bar farther away from you...BUT you make that up, plus some some, with the additional rise. these bars put you in that comfortable sitting up sport tour position. if you need more you can still add riser or even up and back riser as usual. compared to stock it's night and day better. dale also uses the highest grade thickwall steel for these bars not cheap chinese steel. these are taller, more comfortable and ALOT stronger than the bikemaster daytona bars.
i'm testing this set only and will exchange for powdercoated ones. as Dale does everything top shelf i suspect the powder coat will be dialed in too. to get these working i used a spare oem 1200 long brake line and swapped out (16.5 ftlbs onn the banjo bolts) my too short top run line, that runs from the brake to the lower tripple clamp T block (600S setup). dale said a 1200 needed 3" more line but this worked for me in a pinch and 1 wrapped the line around the fork (between the 2 tripple clamps) to take up the excess line i had to work with.
i unclipped the electrical connectors (found underneath the right side fairing) from both the left and right controls and reconnected/mounted (using the frame hold wires) them after the bars where on. i loosened each upper fork leg (upper and lower pinch bolts - 16.5 ftlbs) 1 at a time, pulled then down from below (easier to do then trying to push down from the top. get a helper if need be) on the leg and passed the clutch cable & choke over top the fork leg so it rests outside of the forks.
i then did the same for the throttle cables on the right side. after reassy the control cables move just fine with zero issues sitting outside the upper fork legs vrs wrapping around the front and back through like from the factory. dale said he used 3" extended throttle cables on the bike he did, but i have found no issues with the way i have it.
i then re-glued the left grip back on and used 150 grip sand paper to make the oem ends fit back on. since Dale's bars use thicker steel tube the ID of the end tube is smaller thus you need to remove some rubber from the circumference of the inner rubber hold. stock will not fit in. i keep sanding it down till it fit a medium snug into the bar and put it together and snugged it tight. make sure the bolt closet to the end is bottomed against the bar end, bring the rubber piece down on it then put the outer gripper bolt down snug (but not expanding) on it. put it in, hold tight against the bar and snug it down.
don't forget when you take this bar end out, it only lossens up some then pulls out as a whole. don't unscrew the whole bolt and be left with the rubber piece stuck in the oem bar.
i went out for a ride and played with how far back i rotated the bars. i found my sweet spot after bringing them back and down a small bit. you can have them higher and farther or lower and closer depending on your likes. my wrists and lower back approve with 3 thumbs up. :-)
here are some pics.
thnx bill
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Old 05-11-2012, 10:42 PM   #441
ag_streak
ag_streak's Avatar
Oddometer: 2,989
Originally Posted by eakins View Post
Great write-up Bill! I appreciate function over form and all that, but MAN they look, uh... strange, to put it kindly!
Old 05-12-2012, 10:16 AM   #442
Oldbutslow
Oldbutslow's Avatar
Oddometer: 97
Very strange looking bars. The comfort quotient is per taste, but all the modding would shoot them down for me. For me, you need all the leverage you can get on a B1250. ,BK
'08 CRF230L
'07 SV650
Oldbutslow is offline   Reply With Quote
Old 05-15-2012, 01:17 PM   #443
bross
Where we riding to?
bross's Avatar
Oddometer: 3,500
Don't those bars give you MORE leverage? They're 1 1/2" wider on each side.
bross is online now   Reply With Quote
Old 06-06-2012, 09:27 PM   #444
OldManSandman
Oddometer: 23
Originally Posted by achesley View Post
My latest mods to my Bandit.
2" rox risers
And, New front brake lines that had to be different than installation called for due to the 2" addition. If I had to do it again, I'd just order the needed lines separate rather than a Bandit 1250S kit.
Achesley or anyone else in the know: I've got an '01 1200, and am assuming the brake lines, cables etc wouldn't be too far off that of the 1250. I'd like to go with the 3.5" Rox Risers and possibly a CR Hi Fatbar (local shop has a Wirtz one on sale for $39. - if anyone has any info on Wirtz I'd like to hear your yay or nay on their bars). You think that the electricals would handle the extra 1.5" Rox? Rox seems to jump from 2" to 3.5" without anything inbetween. I don't mind changing the brake or clutch lines, I'm not sure how much $ a new, longer throttle cable would be but changing the electrical bits put me off.
There's a thread here about a Holeshot bar prototype that seems to be getting up as high as I might like. I think though, that the risers & fatbar will be more adjustable.
Thanks for the input!
OldManSandman is offline   Reply With Quote
Old 06-26-2012, 03:22 AM   #445
Haroon
RIDE for PASSION
Haroon's Avatar
Oddometer: 471
The Bandit 1250 has been on my radar for a long while for potential use as a 2-up touring bike. Recently while discussing with a good friend who loves his Bandit 1250 and has used it extensively for touring, here were his comments on the very few shortcomings on this otherwise wonderful value-for-money bike:
  • The front fork, a simple conventional telescopic set-up, is soft and adds to the woes of a less than rigid frame.
  • The brakes are inadequate for the kind of engine power available and speeds possible. The rear brakes tend to fade rather quickly during repeated usage say during a long hill descent.
  • The stock headlight is weak and precludes high-speed cruising after dark. The stock bulb needs some changes.
So specific to the Bandit 1250 owners, I would like to know what remedies or aftermarket stuff have you owners used for solving the above shortcomings and also any other recommendations of ‘tried & tested’ additions to make the bike more touring friendly.
Growing old is compulsory - growing up is optional
So many roads, So little time
- RIDE for PASSION
www.rideforpassion.com
Haroon is offline   Reply With Quote
Old 06-26-2012, 01:13 PM   #446
ag_streak
ag_streak's Avatar
Oddometer: 2,989
For what it's worth, my ex wife, about 5" 5" and 130 pounds, said my 2009 Bandit 1250 was the least comfortable of all my bikes she rode, tied for last with the first-gen Yamaha FZ1.
Her favorite was the V-Strom 1000.
Just sayin'...
That being said, I regret selling the Big Bandito, and now that she's out of the picture, I'm considering another!
Old 06-26-2012, 01:23 PM   #447
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,870
Just sayin'...
What are you.. stoopid?
Oh! I get it! The bike!
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125
My Flickr gallery
Cortez is offline   Reply With Quote
Old 06-26-2012, 05:20 PM   #448
andmoon
andmoon's Avatar
Oddometer: 3,181
2" rox risers
Crossover line correct? Looks long enough to be a direct 2 line from mc to individual caliper.
POVERTY SUCKS
andmoon is offline   Reply With Quote
Old 06-29-2012, 09:29 AM   #449
Shady Rider
Oddometer: 2
Here she is
Just back from a 35 day, 11,000 mile trip.
Shady Rider is offline   Reply With Quote
Old 06-29-2012, 10:18 AM   #450
Rider
Moderator Emeritus
Rider's Avatar
Oddometer: 2,099
Great stuff!!
2012 FJR1300 - In Search Of Fast Sweepers
My Voice
Times are GMT -7.   It's 03:53 PM.
