Old 11-04-2007, 08:28 PM   #1
Escapegoat OP
Sidetracked again
Escapegoat's Avatar
Oddometer: 158
KLR Temperature Sender/Sensor problems
HI All, Any one had any problems with the Temperature Gauge not reading. I had a 40 plus (C) here yesterday, and the gauge did not move. Is there a fuse in there and where should I look? Is that sender on the bottom of the Radiator the culprit?
Wheredafukami
Escapegoat screwed with this post 11-04-2007 at 10:57 PM
Escapegoat is offline   Reply With Quote
Old 11-04-2007, 08:43 PM   #2
eaglemike
Oddometer: 904
The temp sender is next to the spark plug. The thing on the radiator is a thermo-switch for the fan. If it's a 2008, the wire is melted against the air injection plumbing. If not, maybe the wire got damaged somewhere in the harness.
all the best,
Mike
eaglemike is offline   Reply With Quote
Old 11-04-2007, 11:03 PM   #3
Escapegoat OP
Sidetracked again
Escapegoat's Avatar
Oddometer: 158
05
all the best,
Mike
Thanks Mike, didn't even think of mentioning the year, It's an 05. I'll check out those others out though.
The thermo's running, so I'll have a look at it now.
Update
I couldn't have asked at a better time, I had all the plastics seat and tank off anyway to put in a stebel. The little connector was just resting on the sender, and was a bit loose too, so I squeezed it up a bit and it's all good. It had been playing up for a while, but I just noticed that it had stopped working yesterday. You learn something every day!
Thanks Mike,
Wheredafukami
Escapegoat screwed with this post 11-04-2007 at 11:20 PM
Old 11-06-2007, 01:15 AM   #4
SgtMarty
Retired, baby!
SgtMarty's Avatar
Oddometer: 1,422
Check the wires at the back of the temp gauge in the instrument panel. Had a KLR at one of the recent tech days that had a wire that had come loose and that explained his weird readings. We salvaged one of the long brass screws from another (trashed) instrument panel that I had on hand.
Did Prudhoe Bay to Ushuaia in 2008-2009!
http://www.errant-ronin.com/PrudhoeBayUshuaia.htm
COHVCO #6391 AMA #2800236
SgtMarty is offline   Reply With Quote
Times are GMT -7.   It's 04:53 AM.
