Old 11-15-2007, 09:11 PM   #1
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
Talking KTM 640a Voltmeter
I installed a voltmeter from DigitalMeter to monitor my KTM's [sucky] power output. So far it works well.
Tempo is offline   Reply With Quote
Old 11-15-2007, 09:43 PM   #2
R.Markus
Damage Addict
R.Markus's Avatar
Oddometer: 1,145
That's a good clean install. I like it. I may have to get one of those myself so I don't let my Gerbing jacket kill the battery.
The beatings will continue until morale improves.
R.Markus is offline   Reply With Quote
Old 11-16-2007, 06:48 AM   #3
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Looks nice... just wondering how weatherproof it is?
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 11-16-2007, 07:01 AM   #4
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
Me thinks I'll find out today. I am riding 90-min south (to get a custom seat!) and the forecast is:
Today: Periods of rain. High near 55. South southwest wind 17 to 20 mph decreasing to between 5 and 8 mph. Winds could gust as high as 26 mph. Chance of precipitation is 100%.
It's still pretty dark here but I can tell that it's quite stormy right now. This could be a rough ride!
Old 11-16-2007, 07:46 AM   #5
disconnected
rider
disconnected's Avatar
Oddometer: 7,399
dangola... its 32 here with snow flurries...
very good looking install.. keep us posted..
thanks for the link..
greg
IBA # 47004
disconnected is offline   Reply With Quote
Old 11-16-2007, 11:51 AM   #6
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
Well I rode 90 min in pissing rain this morning to Mr Eds Moto, where I am now, and the meter still works.
Wish I could say the same about the KTM... riding down the Interstate it started acting like it was gas starved. WTF? After coasting to the shoulder it sputtered along for a mile or two then went away. Not feeling real good about the ride home.
Back to working on my new seat...
Old 11-16-2007, 08:37 PM   #7
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
Yup
I rode +/- 4.5 hours in more or less steady rain today. Yeah the voltmeter seems OK to use in the wet stuff.
/end of thread
Old 11-16-2007, 09:55 PM   #8
bmwktmbill
Traveler
Oddometer: 5,218
Tempo,
Nice job.
What circuit did you wire into?
Were the readings more or less steady underway or were the numbers rolling up and down?
BTW nice seat too.
bill.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-16-2007, 10:31 PM   #9
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
There are two switched 12v circuits under the fairing, right? Just use one of them. You can find male Molex connectors for about $0.25 or less at a good electronics store (not Radio Shack). Crimp some wires and plug right in.
So far I've noted that readings are pretty steady given a constant RPM. Here's some very UN-scientific data after all of 5 hours in the saddle with the voltmeter going:
  • I see 14.0v - 14.1v on avg. with no accessories running at 4k+ RPM
  • When idling it drops under 14.0v but is still is more than 13.0v
  • Sometimes idling it goes below 13v (yet above 12.0v)
  • Heated grips on low take 0.3v - 0.4v off the top
  • Heated grips on high take 0.7v
  • GPS doesn't seem to draw much, if any, maybe 0.1v (?)
  • Sorry I can't remember what the high beam draws (0.3v?)
  • Haven't tried it with the heated vest yet
It's a worthy accessory. Tonight while I was idling in traffic (!!!) in the rain (!!!) I saw it dip below 12.0v so I shut off my grips.
Old 11-17-2007, 04:20 AM   #10
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,736
The voltmeter is easy to wire in. You will get your most reliable results if you connect it directly across the battery...as in one lead to battery + and one lead to battery -. it wouldnt hurt to throw in a small amperage fuse as well...something like a 5 amp or less would suffice. The voltmeter is not a load but if one of your wires wears through and grounds out you will have a fuse to blow before the wiring burns up.
Seth S
Seth S is offline   Reply With Quote
Old 11-17-2007, 05:18 AM   #11
on2wheels52
Oddometer: 2,481
Wouldn't a voltmeter be a (constant) load if wired direct to the battery? Or does the one pictured have a third wire to power the display?
Minuscule power draw, no doubt.
Jim
R1200GS Ural Patrol KLR650 DRz400 XL185
Austria '08 http://www.advrider.com/forums/showthread.php?t=352082
Back to the Alps in '11 http://advrider.com/forums/showthread.php?t=744205
on2wheels52 is offline   Reply With Quote
Old 11-17-2007, 07:08 AM   #12
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
If it was wired directly to the battery it would never turn off.
Times are GMT -7.   It's 10:32 AM.
