Old 02-01-2010, 04:44 AM   #3661
mcgiggle
Oddometer: 272
Had the stand before the Ohlins, yeah too short, had a mate weld a new crossbar in to give extra clearance and now the whole stand twists around. I'll only use it in an emergency to change tyres, when I get back for this trip i'll probably junk it and make do with lumps of wood or rocks, worse case i'll just lay it on it's side. Complete waste of money IMO.Weighs an absolute ton as well.
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 02-01-2010, 04:58 AM   #3662
jimmy2020
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 983
Ohlins and Hepco Becker rack
I also found that the Ohlins and the Hepco Becker rack are not compatible.
The stock bracket for the reservoir canister needs to be altered.
Here is a pic of the altered hanger.
I have many pics if anyone runs into this and needs some advice. It is probably one of several solutions, but the best I could come up with.
I'm sure many of you have realized, there is not a lot of room to alter or add changes to the XChallenge. Takes some creativity!
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is offline   Reply With Quote
Old 02-01-2010, 07:45 AM   #3663
pecos
BAM!!
pecos's Avatar
Oddometer: 545
That looks really good for spray on. I used some of that in aluminum panniers. I may give that a shot.
The previous picture with the two f650s was line-x. Cost was $185. Cheap, the business who did it, did not make any money on it. Its very thick compared to the spray on. Kinda over kill.
I am just wanting something that will last when i drop the bike or hit a tree.
What technique did you use when spraying? Spray it like spray paint? How many layers?
You sanded the plastic prior to spray right? Just a light grit for sand paper?
Originally Posted by jimmy2020
I sprayed a fender on my old 950 and it never wore off, even after a few years.
I just recently replaced the stock front fender of my XC with an acerbis. The front part was YAMAHA blue. I painted over the blue with the black and looks great.
In summary, it works great on plastic and inexpensive.
pecos screwed with this post 02-01-2010 at 07:51 AM
pecos is offline   Reply With Quote
Old 02-01-2010, 07:24 PM   #3664
pecos
BAM!!
pecos's Avatar
Oddometer: 545
Decided to give it a try. I used "Rust-Oleum truck bed coating" on the outside. Got it at Lowes for $8 a can. Its a lot finer than the "Dupli-Color Truck Bed coating". I am so far at 3-4 light coats. I used Dupli for the inside. The dupli was left over from a previous project. Its a lot thicker. Looks more like line-x or rino liner.
I did use a little sand paper both gritty and smooth.
I am no spray paint expert but I practiced on the bottom of a drink cooler first. Then attempted the bike parts. I am surprised at how well it looks. It looks better than my old f650 that was line-x.
I will get the bike pics up in a few days.
Old 02-01-2010, 07:32 PM   #3665
pecos
BAM!!
pecos's Avatar
Oddometer: 545
two different coatings....
Old 02-01-2010, 07:51 PM   #3666
jimmy2020
jimmy2020's Avatar
Oddometer: 983
new WOLFMAN EXPEDITION SADDLEBAGS
I just posted this on another XChallenge thread on THUMPERS.
Thought I would post it here as well.
http://www.advrider.com/forums/showt...335086&page=66
jim
Old 02-02-2010, 01:20 AM   #3667
SmitheySA
SmitheySA's Avatar
Oddometer: 21
Pete
Thanks for the reply. Ill be taking it to an engineering shop this week for alterations. It cost me too much money just to junk it. Ill post pics tomorrow of the current problem.
Ill be taking the matter up with the suppliers as well. They should have a warning that the stand does not fit with aftermarket rear suspensions.
BMW 650 X-Challenge
SmitheySA is offline   Reply With Quote
Old 02-02-2010, 01:41 AM   #3668
mcgiggle
Oddometer: 272
If you move the crossbrace closer towards the pivot you lose torsional rigidity and the bike is unstable when on the stand. I tried using a semi elliptical brace, brace made out of angle iron but the only thing that worked (sort of) was the OE brace that rubs on the chain and doesn't give enough clearance. Keep us posted if you find a solution.
Pete (wobbly stand)
Old 02-02-2010, 02:11 AM   #3669
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,993
Hepco Becker Vs Touratech
Can someone tell me if Hepco Becker pannier racks will fit on the Xchallenge with a touratech large rack. If so anyone got a picture of the fitting. Thanks
dirtsurfer is online now   Reply With Quote
Old 02-02-2010, 02:33 AM   #3670
ONYERBIKE
LE Rosbeeeeef!
ONYERBIKE's Avatar
Oddometer: 356
Yes someone has done it on the other X Challenge thread, have a look on there, 4 pictures with wolfman bags, TT rack and Hepco Becker racks.
ONYERBIKE is offline   Reply With Quote
Old 02-02-2010, 06:06 AM   #3671
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,323
Look at Jimmy2020's link a few posts above yours.
looks like he has the setup you are talking about.
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 02-02-2010, 06:26 AM   #3672
jimmy2020
jimmy2020's Avatar
Oddometer: 983
i'm pretty sure mine is the small TT rack...
but it should give you a good reference to see if the large rack would fit.
jim
Old 02-02-2010, 12:16 PM   #3673
dirtsurfer
dirtsurfer's Avatar
Oddometer: 1,993
Thanks. So the rack and the pannier share the same mounts behind the seat?
Old 02-02-2010, 04:24 PM   #3674
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,015
Yes. You pull out the bolts for the TT rack then insert the bolts through the HB mounting plate then back into the TT rack then into the frame and tighten. You lose about 1/8" of thread grab this way. To be safe, I bought longer bolts.
The HB racks then attach to the mounting plates. The mounting plates (very unobtrusive) remain in place even when the HB rack is not on the bike.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 02-04-2010, 04:08 PM   #3675
MZcountryboy
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
Hell Yeah!!,,,stay tuned.....
MZcountryboy is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
