Old 06-19-2011, 07:13 PM   #4576
Koof
Koof's Avatar
Oddometer: 127
Not really a farkle... more like a pant saver...
Koof is offline   Reply With Quote
Old 06-20-2011, 11:08 AM   #4577
frostyuk
frostyuk's Avatar
Oddometer: 272
Originally Posted by pampaX View Post
nice vid ... what bars do u use? I'm looking to get a higher with less sweep ...
i use renthal twin walls --- ktm high bend i think model 994, slightly higher, wider and with less sweep if that helps, recommended to me by a dakar rider
frostyuk is offline   Reply With Quote
Old 06-20-2011, 08:52 PM   #4578
pampaX
pampaX's Avatar
Oddometer: 422
Nice ... yes it does
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 06-22-2011, 08:59 PM   #4579
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,580
Originally Posted by tbarstow View Post
Test ride confirms that it all works well:
Nice vid. I would think a Rekluse would help on that section - mine helps a lot but haven't had it on very difficult rocky hills yet. Ever considered it Tim? Certainly has its downsides as well.
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 06-23-2011, 04:02 AM   #4580
MizzouRider
MizzouRider's Avatar
Oddometer: 1,775
Koof,
I know very little about that exhaust wrap. Do you have to get it somewhere special? Or would any auto parts store carry it? Did you start it the same way you ended it? (looks like a radiator clamp.)
Mine's got melted pants, and all kinds of other crap stuck to it..
Be nice to just have it looking clean again..
Jeff
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 06-23-2011, 04:05 AM   #4581
mcgiggle
Oddometer: 272
Originally Posted by DiscoDino View Post
Thanks tbarstow!
Here's what i'm thinking in terms of fittings so that I can take the tank off easily for air filter maintaining and still have the ability to drain fuel from the tank if I need to spare some for a fellow rider...
1. Petcocks on both side...nothing new there...
2. Coming out of each petcocks, install a free flowing quick disconnect, so that I can use the on/off switch at the petcocks to manipulate the flow
3. This will connect to a shut off quick disconnect leading to a Y split, a filter, and then to the breather...so that fuel won't leak back from the lines as we disconnect...
Makes sense? Thinking of going with MotionPro for all these items..
Thanks for any feedback...I'm terrible at fuel stuff and electrical stuff...
I've installed cut off QR's and also have a female end with a short piece of rubber pipe attached to it so I can fill my stove bottle, if you don't want to carry the female/pipe set up you can just use the end of a screwdriver or similar to release the ball bearing in the QR to allow fuel to pass.
HTH
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 06-23-2011, 04:22 AM   #4582
keep it simple!
Oddometer: 147
Koof,
Jeff
http://www.classicbike-raisch.de/html/auspuff.html)
keep it simple! is offline   Reply With Quote
Old 06-23-2011, 07:10 AM   #4583
Koof
Koof's Avatar
Oddometer: 127
Originally Posted by WildwoodMOCruiser View Post
Koof,
Jeff
Hey Jeff, I ended up getting a roll from a buddy at my local dealership but you can buy it from most auto parts places / exhaust shops. If you're on a budget though; ebay.
I did use SS hose clamps but SS zip ties or SS straps used for cinching the rubber boots on CV shafts would work as well.
I started it at the can and worked my way towards the header to overlap the leading edges (so it doesn't collect s#*t while you ride). I also soaked the wrap in water prior to installing it; allows you to wrap it tighter and when it dries (first time you fire up the bike) it snugs up nicely.
Hope that helps!
Koof
Old 06-23-2011, 08:15 PM   #4584
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
center stand
Anyone running a center stand on their Xchallenge? I am thinking one may come in handy on the road, not sure if I should buy one, build one, or just prop a cut off broom handle under the skid plate.
If anyone has one on their bike, what does it mount to?
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 06-23-2011, 09:38 PM   #4585
mcgiggle
Oddometer: 272
I had an SW Motech but took it off as soon as I got home from the trip I brought it for!
It mounted from the foot rest mounts and when in use the whole bike wobbled and twisted and made me very nervous about it falling over so I never used it really, I only got one puncture so just proped the bike against a tree.
It weighs and absolute ton as well.
My 10 cents worth save ya $
Cheers
Pete
Old 06-24-2011, 08:06 AM   #4586
SCflyer
SCflyer's Avatar
Oddometer: 1,633
I tried one... (SW Motech)
I had to do a little hammer modification to the bracketry
Wouldn't work too well once on - not high enough - with my Ohlins
If your'e considering weight - leave it off.
Granted I never actually tried it in "real world" as I was in the trial and error phase of my build up. Others I've seen seem to work for them, (one looks as though he cut and rewelded the brace bar) as it is close to the rear wheel when up. Don't recall who. Here's a another thread from the 650X specific -looks to work okay. http://www.advrider.com/forums/showp...postcount=2073
I decided for less weight and simplicity and got two http://www.advrider.com/forums/showthread.php?t=538235
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 06-24-2011, 09:21 AM   #4587
Bork Bork
Bork Bork's Avatar
Oddometer: 18
Anyone know if the headlight assembly and bracketry from a X Country swaps right on to the Challenge? In looking at the parts fiche it seems the gauge cluster cover is different as well.
________________________________
'07 BMW G650X Challenge
Bork Bork is offline   Reply With Quote
Old 06-24-2011, 10:49 AM   #4588
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,785
The XCountry headlight assembly mounts to the upper and lower fork brace. The part numbers for those braces are the same for the two bikes, but I don't know if other XChallenge parts will get in the way. And if you don't know, that headlight bracket is plastic painted to look like aluminum.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 06-24-2011, 10:54 AM   #4589
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,785
Rob--in addition to the beefs the other guys expressed, it will also reduce your ground clearance. Like SCFlyer, I carry a Trailstand. Works fine for chain maintenance or rear wheel removal. Can also be used for front wheel removal though it's a little trickier to find a good place to deploy it.
WUMPA
Sidecardogs.com
Old 06-24-2011, 01:46 PM   #4590
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Thanks guys, you all convinced me the center stand is a bad Idea. I will snatch a broom out of the store room and start working on a prop, as long as the house dragon does not catch me that is.
Times are GMT -7.   It's 06:02 AM.
