Old 07-03-2011, 01:23 AM   #4636
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,033
Would you use a metal bush and washers either side with the Delrin?
Never seen it used before by itself where 2 objects are tightened hard up against it.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 07-03-2011, 02:25 AM   #4637
mcgiggle
Oddometer: 272
Going on what I've found out so far there's no need, some types of Delrin are impregnated with PTFE and used as bearing bushes!
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 07-03-2011, 02:43 AM   #4638
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Originally Posted by Scheffelmeier View Post
I think so too, because if the rider is broken after a chrash, the health insurance will pay for it
I think the nickel coatet 7075 T6 aluminium wheel spacer will cost the same like the stailless steel spacers!
So you think it will be lighter and harder than the stainless steel ones Stephan, and the same price? Sounds worth trying
How thick would the hard nickel layer be?
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 07-03-2011, 05:45 AM   #4639
Niedz
Niedz's Avatar
Oddometer: 624
I've got a chunk of 2" round stock delrin that I was messing around with. Its really fun to turn on the lathe. Deep cuts and fast feeds are possible. Maybe I should make some spacers?
I made axle nubbins out of it.
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Old 07-03-2011, 10:53 AM   #4640
mcgiggle
Oddometer: 272
If you are going to make spacers you'll need to know what grade it is as there are over 10 very different types!
Old 07-03-2011, 11:27 AM   #4641
Scheffelmeier
Scheffelmeier's Avatar
Oddometer: 63
Maybe 0,1mm. The hard nickel layer have ~ 56 HRC (Rockwell) hardness.
(diamond have 70 HRC and I think bearing steel have ~ 60 HRC or maybe a little bit less!)
Scheffelmeier is offline   Reply With Quote
Old 07-03-2011, 02:21 PM   #4642
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,513
Iīve been wondering whether I should make aluminium wheel spacers, coated with a layer of hard nickel!
Stephan.
Go for it, Stephan. I`m holding off getting some of youur spacers (as well as some other stuff) due to a medical issue, then a long distance trip. Hopefully when I return, towards the end of August, you will have already have some idea whether aluminium spacers are better than stainless ones.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 07-03-2011, 05:25 PM   #4643
satur9
angry black guy
satur9's Avatar
Oddometer: 525
Originally Posted by The Jester View Post
I'm assuming these batteries are smaller than standard as they have a higher charge density. Would it be possible to mount them in front of the fuel tank in the space occupied by the ABS pump on the ABS bikes. That would be good for mass centralisation and give a useful storage space for a spare tube where the battery currently sits.
yes i also have one there. i order the abs tray from bmw . and mounted a six cell one there. i doubt the nine would fit. mabey without tray. but i barely got the six cell in with only moving. regulator and brake fluid out the way. mines a second battery though. i have an oddessy in stock location.
I drank the koolaid again.
Well, it took a lot of work to be the ass that I am
And I'm real damn sure that anyone can, equally easily f*ck you over ...(modest mouse).
satur9 is offline   Reply With Quote
Old 07-03-2011, 05:53 PM   #4644
leafman60
Oddometer: 1,807
Now Stephan ! Here you are working on a better version of your spacers and I just ordered a pair of the stainless!!!
leafman60 is offline   Reply With Quote
Old 07-03-2011, 10:46 PM   #4645
Scheffelmeier
Oddometer: 63
I donīt know if there are better because there are not tested and it takes several weeks until they are ready!
Old 07-04-2011, 07:52 AM   #4646
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Stephan, would you please create a signature for you posts that has a link to your awesome site? I'm lazy doing searches... Bitte
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 07-04-2011, 08:29 AM   #4647
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,369
Originally Posted by tbarstow View Post
Yes, this battery takes up significantly less space. You could probably put a tube in with the battery in the normal location.
I know that Jim took some pictures of the installation. I'll see if he can put them up here.
Thanks, Tim. I only have one..
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet screwed with this post 07-04-2011 at 10:19 AM
herrhelmet is offline   Reply With Quote
Old 07-04-2011, 11:40 AM   #4648
Scheffelmeier
Oddometer: 63
Itīs done!
Old 07-12-2011, 03:11 AM   #4649
magno
Oddometer: 38
Adventurised X Challenge
Link to my X Challenge which is for sale: http://www.ukgser.com/forums/showthread.php?t=273109
magno is offline   Reply With Quote
Old 07-12-2011, 05:01 AM   #4650
Tomdog
Mapaholic
Tomdog's Avatar
Oddometer: 364
Thats one well set up XC you've got there.
Any chance of more info on the low fender. Looked at your pictures but not enough detail to figure out how you attached to forks.
Is the fender itself off a X-Moto?
1190 Adventure R
Tomdog is offline   Reply With Quote
Times are GMT -7.   It's 09:31 AM.
