Old 10-12-2011, 03:01 AM   #4801
mcgiggle
Oddometer: 272
Cheers F, just ordered 2
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 10-12-2011, 07:30 AM   #4802
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 375
Originally Posted by FinnDuro View Post
What the heck - I took my laptop, some wire and a basic on/off switch, went ahead and experimented this already, as it really seemed like a simple fix. And it is!
On the Power Commander software, you can activate a configuration setting for a map switch.
Once you activate that setting, you can select a map file, and send it to the PCV unit. Once you hit "Send Map", the software always asks you whether you want to send the map to Map 1 or Map 2 position. Sweet.
The actual PCV unit in the bike has wire slots, one for Map 1 and one for Map 2. You hook up a thin wire on both of them. OK, these two wires then should go to opposite ends of a simple On/Off switch, which basically just connects or disconnetcs these two wires. That's it, it's that simple. When the two wires are disconnected (Off), you have a Map 1 active. When you connect the two wires (On), Map 2 becomes active. The maps change On The Fly, while bike is running.
I'll try and permanently hook this switch up during the weekend: I now just had some wires hanging off the PCV, and laptop connected so I could see the map changing with on-off-on selections.
If anybody's further interested in that PCV fuel map switch thing, I finally wrote a brief installation guide with a couple of pics in the dedicated G650X PowerCommander thread. It's easy And cheap And it works.
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 10-15-2011, 03:57 PM   #4803
HP2
Oddometer: 249
"Now the screwing is over."
That was my last sentence.
Well I was with the xch 2500km Offroad in Romania.
I had so much dirt on the throttle that I have the original air filter
have thrown out.
I think with the new system, I'll have even more power less dirt.
Next week I'll work on the dyno.
HP2 is offline   Reply With Quote
Old 10-17-2011, 02:32 AM   #4804
Mtrain
free range
Mtrain's Avatar
Oddometer: 439
Ill be very interested to hear your results. I have wondered how that type of setup would go.Is that a KN filter? Ive heard they are not all that good for the fine dust. Good luck with the dyno.
Mtrain is offline   Reply With Quote
Old 10-17-2011, 01:39 PM   #4805
The Jester
The Jester's Avatar
Oddometer: 827
+1
I used to have a CCM 604 which had a filter with a very similar shape, except it was a foam filter. Knowing CCM, I'm sure it was a generic filter that was available from the parts bin.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 10-17-2011, 01:56 PM   #4806
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,298
Originally Posted by markwoodlief View Post
dont use a shorai battery if you plan on ever riding your bike in below 35 degree weather.. been there done that... 2 day old battery left me stranded... when they freeze or get damn close they have no power... they need to be heat cycled... you're welcome to experience it yourself, but I'm not a fan here in WA where I ride about 11.5 months out of the year..
I started mine before LA-Barstow-Vegas last year when it was 29F outside. It takes a little bit of time, but it does crank. Turn the lights on for a couple of minutes, then try starting it.
G650X side panel tank build
tbarstow is online now   Reply With Quote
Old 10-21-2011, 05:40 AM   #4807
frostyuk
frostyuk's Avatar
Oddometer: 271
Originally Posted by kito View Post
hi thanks for some feed back. i have just put my order in for a hyperpro at a cost of 593 they said about 3 weeks .they have a cheeper option at 371 but less adjustment .
where did you order your shock from ? was it in uk or from bas at hyperpro?
cheers
frostyuk is offline   Reply With Quote
Old 10-21-2011, 12:07 PM   #4808
kito
Oddometer: 274
Motercycle road and race ..in the uk .01784229666.
they phoned me the next day after i placed the order to say the was going to be a longer wait and asked if that was ok and if i wanted to keep my order .
had a phone call yesterday to say my shock had been make and the next batch was getting shiped out on wednesday and i will get it the next day after they get it .
cant wait . stephan also emailed me to say my goodys from him are getting shipped today so next weekend the will be a few change to my bike
kito is offline   Reply With Quote
Old 10-22-2011, 02:57 AM   #4809
frostyuk
frostyuk's Avatar
Oddometer: 271
Many thanks
Old 10-24-2011, 05:05 AM   #4810
Maggie Zantstorm
Dutch Biker Chick
Maggie Zantstorm's Avatar
Oddometer: 108
X-Challenge help for Maggie please!!!
Hi guys, its Maggie from Holland (http://www.advrider.com/forums/showthread.php?t=715670) ... and I am building up an X-bike for my next adventures (part x-country, part X-challenge). I guess a few of you guys have the Touratech fuel tank? Which means maybe a few of you guys will have spare side panels and airbox covers etc that you don't need anymore?
I am looking for those parts for my bike build so if anyone has any they want to get rid of, can you please PM me and tell me what you want for them.
Its great to join the ranks of the X-C riders
Bye Bye Maggie
www.margreetzant.nl
* Follow your dreams *
* Live life on the edge & enjoy *
Maggie Zantstorm is offline   Reply With Quote
Old 10-24-2011, 02:53 PM   #4811
mixmasa
what it is?
mixmasa's Avatar
Oddometer: 31
Inexpensive Windscreen for the XChallenge
I've been wanting to get a windscreen for my XChallenge for a while now, but really don't want to fork out the money for new lights and windscreen. So the other day I went into the shop, mad a template, transferred it to some black ABS plastic, cleaned it up and velcroed it to the backside of the small headlamp bezel. I bent the top because it blocks part of the speedometer and I have to say....IT WORKS! I went on a drive on the highway yesterday for 20 miles or so and it really blocks the wind off my chest. It make a big difference so i thought i should share it with everyone. Here's the pics.
2005 KTM 950 Adventure...awesome!
2007 BMW XChallenge(gone)
2002 Aprilia Caponord(gone)
2002 Honda RC-51(gone)
1996 Ducati 900ss sp(gone)
mixmasa is offline   Reply With Quote
Old 10-24-2011, 02:58 PM   #4812
mixmasa
what it is?
mixmasa's Avatar
Oddometer: 31
more pics of the windscreen.
Old 10-24-2011, 02:58 PM   #4813
jack splash
Two Sheds
jack splash's Avatar
Oddometer: 2,302
K&N Filters
have thrown out.
Hey: From my expericence with K & N filters, it's a bad idea, they let more dirt into the motor then anything else.
I think they are best on street bikes or drag racers, but have no place on a dirt bike. IMHO
Jack
Stay dirty my friends!
Bigfoot has a picture of me!
www.pinebarrens500.org
www.pinebarrensadventures.com
jack splash is offline   Reply With Quote
Old 10-24-2011, 02:59 PM   #4814
mixmasa
what it is?
mixmasa's Avatar
Oddometer: 31
and one more.
Old 10-25-2011, 10:55 PM   #4815
mcgiggle
Oddometer: 272
Had my Ironman sprocket delivered today, looks to good to install onto the bike!
A heads up for anybody outside the USA, the invoice/value on the packaging was for $40 but I still had to pay an additional $13 in customs etc. It was approx 2 weeks door to door.
Times are GMT -7.   It's 12:31 AM.
