Old 07-19-2013, 04:09 PM   #5371
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,442
Using Google to search ADV will tell you the following:
There is a filter, but that BMW only sells the whole fuel flange assembly.
There is a list of non-BMW parts on ADV that lists the fuel filter.
posting from the phone, so I try to keep my answers short, not trying to be an ass.
tbarstow is offline   Reply With Quote
Old 07-21-2013, 01:19 PM   #5372
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,587
Added link in above line. I just found this recently so had recorded it on my Links page (see my sig).
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 07-23-2013, 06:57 AM   #5373
jabroka
jabroka's Avatar
Oddometer: 338
New graphics to TT tank
I just received this pics from the guy at the graphic shop (I'm working 2k km away at the moment), cant wait to get home and put it on..
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka screwed with this post 07-23-2013 at 07:05 AM
jabroka is offline   Reply With Quote
Old 07-23-2013, 08:11 AM   #5374
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,442
Now don't throw a fit when your graphics bubble and peel off from the gas vapors that will permeate through the walls of the tank. This permeability of the tank is normal.
Old 07-23-2013, 08:12 AM   #5375
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,392
Yes, they look great, but I imagine they will last a very short time.
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 07-23-2013, 08:24 AM   #5376
jabroka
jabroka's Avatar
Oddometer: 338
yes.. I've read about graphics peeling off on plastic tanks..
the guy told me that they use some kind of sealer in the areas that they put the vinyl on..
I noticed that both Pavey's, Faber's and the TT bike had graphics on the tank.. maybe they replaced them quite often??
anyway, I guessed I'll give it a try, lets see how long it lasts..
1993 suzuki GSXR-R
Old 07-23-2013, 08:13 PM   #5377
chokozip
Oddometer: 194
Did you have any issues with the new lever not making contact with the clutch switch?
What did you go with for a bushing in the hole?
Sean
Originally Posted by Pine Sol View Post
the only reason i tried the adjustable levers was because, i (and the shop) just couldnt get more pressure for the brake lever. and now with the new adjustable brake lever, the feel is much better
as for the clutch, the mounting hole, was longer then what was needed, so i had to trim it down, it also needed a shim (sleeve for the screw to go through) of something to stop the wearing on the mounting screw, same as the brass shim on the stock lever. and then it needed some re-shaping to fit into the housing.
it wasnt difficult, just some patients, but the end result is well worth it....
I will meet you on the long road to the middle.
Colorado/Utah 2014 ride report here:
http://advrider.com/forums/showthread.php?t=1019732
chokozip is offline   Reply With Quote
Old 07-24-2013, 10:31 AM   #5378
Pine Sol
Pine Sol's Avatar
Oddometer: 499
Sean
i have had zero problems from the levers. they have been absolutely brilliant, best 30 bucks i have ever spent.
originally, i picked up a scrap brass pipe to use, but ended up making a nylon sleeve (will report back if it wasnt the best material to use)
the brake lever was (as i remember) darn near exact, in that i required no modifications.
the clutch, needed sculpting, shaping, and patients to make it fit, but it wasnt that hard, (seemed obvious to me) just use the original lever to find the shape, and also remove the housing that it will seat into, to ensure that it fits the way that you want it to...
Pine Sol is offline   Reply With Quote
Old 07-26-2013, 12:52 PM   #5379
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,020
Thumb Nice fit on the brake lever!
Sean
I ordered a set as well and the brake lever was a perfect match! I will spend some time on the clutch lever later as I don't have time to modify it right now. However it doesn't have the right shape to push the switch I have a few thoughts on getting that to work.
jonnyc21 is offline   Reply With Quote
Old 07-26-2013, 02:09 PM   #5380
jabroka
jabroka's Avatar
Oddometer: 338
couple of pics with the new graphics on the tt tank, 4 days with the vinyl on the plastic tank.. so far no bubbles.
1993 suzuki GSXR-R
Old 07-26-2013, 03:04 PM   #5381
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,392
Wow, That is the best looking XCH I have ever seen.
Stunning!
This is SPARTA!
Old 07-26-2013, 03:21 PM   #5382
chokozip
Oddometer: 194
Here is what I did to the clutch lever.
Sean
Sent from my iPhone using Tapatalk 2
Old 07-26-2013, 04:10 PM   #5383
Pine Sol
Pine Sol's Avatar
Oddometer: 499
did you order from the link that i provided?
to be honest, when i got mine, i didnt know what that thing (screwed into the clutch housing) was for, i just shaped up the clutch lever, looking at the original, fit it in, and it worked.
Old 07-26-2013, 10:36 PM   #5384
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,020
Price was good on the link so ya ordered right from there, took a bit longer to get than I thought but I wasn't in a hurry. It looks like chokozip's modification is just about the same as I was planing on doing, for mine.
even as it stands right now I am giving the brake lever an A+.
Old 07-27-2013, 08:58 AM   #5385
kubiak
Oddometer: 4,829
that looks great!
Times are GMT -7.   It's 11:49 AM.
