Old 11-20-2007, 09:18 AM   #1
durandal OP
durandal's Avatar
Oddometer: 197
Yamaha XT 225 Serow Valve Adjustment
Hi all. This will probably only be useful to newcomers, but the more help they get, the better, right? :-P
d.
Originally posted to El Cantar de la Lluvia on Thursday, April 19, 2007 and to The Flight of the Platypus on Tuesday, November 19, 2007
"But Paul, you have an XR, what is this XT 225 doing in one of your articles?"
Well, it's a guest, of course! This is Jano's bike, a 2001 Yamaha XT 225 Serow, a faithful and excellent bike that was ready for a valve adjustment.
Jano had noticed some valve noise that occurred during the first few seconds after the bike was started. This is normal, but he wanted to check his valve gap anyway.
He came to my house, and armed with the shop or service manual of the Yamaha XT 225 Serow (alternative link), we got to work.
First, remove the seat.
The fan is there to cool the engine, since valve adjustments should be done with the bike stone cold, and he'd ridden it to my house.
Remove the gas tank fairing, then the tank itself. Since everything is dirty down there, we must clean it.
That's what we did: toothbrushes and de-greasing spray.
With everything completely dry, and the engine at ambient temperature, we removed the spark plug. I think the mix might be a bit poor.
Then, remove the two covers on the left side of the engine. Using a socket and an extension bar, just as you do with the XR, rotate the engine in the anti-clockwise direction, until the "T" mark is aligned with the mark visible through the top hole.
The pistom must be on its compression stroke as you align the T mark. To make sure that this is the case, both valve rockers should have some play. If they do, you're on the compression stroke. If they don't, you're on the exhaust stroke, and you should turn the engine one more time.
Remove the valve rocker covers. Here's the exhaust one.
And the intake one.
Loosen the lock nut with a 10 mm wrench. It will be necessary to turn the adjustment screw. For some strange reason this piece has a square head. Yes, you read that right. I had to make a simple tool to give it the right position. You can do it with needle-nosed pliers, but you'll go insane trying.
I made the tool out of copper tube, the type you use in refrigerators, and needle-nosed pliers. I inserted one of the pliers' jaws into the tube, and thus flattened one quarter of the tube's circumference. Pull it out, rotate 90, squeeze. You can thus make a round tube into a square profile. The ridges on the pliers help file away any irregularities. Not bad!
To learn how to correctly use feelers to set the valve separation, read the article on the same procedure on the XR. We found that the exhaust valve gap was too large, so I adjusted it. The intake one was within the range specified by the shop manual.
And thus concludes the valve adjustment of this pretty bike.
Rides - Spanish: El Cantar de la Lluvia | English: Flight of the Platypus | And, of course: Carretera Austral '07
ADV Riding on an XR250R/XR650L, yeah baby!
durandal is offline   Reply With Quote
Times are GMT -7.   It's 09:36 PM.
