Old 05-12-2012, 05:03 AM   #1
tourdivide OP
Oddometer: 10
KLR Clicking
http://www.youtube.com/watch?v=-kKva...ature=youtu.be
best guess on what this clicking is?
tourdivide is offline   Reply With Quote
Old 05-12-2012, 05:07 AM   #2
eddie bolted
Oddometer: 1,762
Don't know,but i wouldn't run it much till ya find out.good luck,how many miles on it?
If it stops raining now, i,ll be pissed!(BEANTOP)
eddie bolted is offline   Reply With Quote
Old 05-12-2012, 05:09 AM   #3
tourdivide OP
Oddometer: 10
just under 20,000. Thinking of buying, but wanted to have an idea of the cause and severity before doing so....
Old 05-12-2012, 06:18 AM   #4
Kawidad
Kawidad's Avatar
Oddometer: 3,809
Sounds really bad. Unless it's almost free, don't buy it. It's more than likely to cost a lot more money than it's worth in the end to fix it. There are plenty of well loved used KLRs out there.
"Deeply flawed people make deeply flawed decisions."
Kawidad is offline   Reply With Quote
Old 05-12-2012, 06:24 AM   #5
beemerjim
beemerjim's Avatar
Oddometer: 303
Can you tell where it's coming from? If it's coming from the head area, it's probably due to oil starvation causing the cam and journals to burn/wear out and is an expensive repair.
Jim
The older I get, the faster I was.
It's all about attitude & timing.
I'm not sure where we're going, but this road seems to be paved with good intentions.
beemerjim is offline   Reply With Quote
Old 05-12-2012, 06:25 AM   #6
Unstable Rider
World Wide Inmate
Unstable Rider's Avatar
Oddometer: 2,110
I love the early gen. KLR (I have a 2009) but I would try to land at least into the 90's with one, couple years newer, do some Craig's searches, lots to pick from specially if you are willing to fly and ride. You could dump 700$ into that motor if it's not something simple...
´¯`·.¸¸.·´¯`·.¸ ><((((((º>
`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º>
´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º>
Everything happens for a reason. "Still seeking the reason"
Unstable Rider is offline   Reply With Quote
Old 05-12-2012, 08:14 AM   #7
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 930
Yeah.
That sounds bad.
I wouldn't buy that unless you can get it for dirt cheap.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (soon to be named)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 05-12-2012, 11:14 AM   #8
Beezer
Oddometer: 4,425
pull the oil filter & look for aluminum flakes. that sound happens when the engine is run low on oil.... the right exhaust cam journal is last in line for lube, and first to starve. the journal in the head gets galled and it chews the crap out of the aluminum. if there is a bunch of ground up alu (not magnetic) in the filter, that's what it is. I have fixed a couple by flushing the engine and replacing the head. the head can be repaired by welding but it is usually cheaper to get a user off of flebay. easy fix if the price is right
P.S.
you can verify by measuring the clearance of the right ex valve too.... it will be way huge because of the missing metal
Beezer is offline   Reply With Quote
Old 05-12-2012, 11:36 AM   #9
malamut
Oddometer: 3
Sounds like the balancer chain,the doo hickey adjuster is more than likely toast,I just went through the same thing on my 92 KLR.This could also be top end,cams starved for oil,if this bike was run low on oil,I would pass,expense fix.
malamut is offline   Reply With Quote
Old 05-12-2012, 03:34 PM   #10
NHMatt
NHMatt's Avatar
Oddometer: 269
Click link below to see what it sounds like. I had the same sound.
Check out my KLR650 engine rebuild @ http://myklr.wordpress.com/
NHMatt is offline   Reply With Quote
Old 05-12-2012, 04:28 PM   #11
tourdivide OP
Oddometer: 10
Thanks people. I was hoping for simple. The asking price is 975. Bike looks nice, but it sounds like there is a good chance of a money pit under that head. I will cool my jets on this for a couple days, so as not to make a bad decision.
Thanks for all the quick responses.
Old 05-12-2012, 05:08 PM   #12
NHMatt
NHMatt's Avatar
Oddometer: 269
For a used head and a 685 kit I paid 750.
Sent from my BlackBerry 9650 using Tapatalk
Old 05-12-2012, 06:48 PM   #13
Beezer
Oddometer: 4,425
and now it runs great right? it should.
P/S you also need to pull the rt side engine cover to clean the oil pick up screen. they are notoriously full if rubbish even if you don't have the cam problem. on an older bike like the OP's you will want to change the water pump's oil seal & mechanical seal while you are in there. there is a little "O" ring on the impeller too. prolly want a fresh cover gasket. all easy work.... about $50 for that pile of parts.
P.P.S. the 685/688 mod needs a '96 or newer cylinder... which will bolt right on no problem. also, there are no stock rings for the pre '08s unless you luck into some NOS. the current production stock (and OS) rings do not fit the Gen I piston, so if the rings are going to be changed the the piston has to be a new style too.
Beezer screwed with this post 05-12-2012 at 06:54 PM
Times are GMT -7.   It's 12:42 AM.
