Old 11-22-2007, 03:48 PM   #1
sweatychef OP
My boots got soup in em
sweatychef's Avatar
Oddometer: 18
Fudged Fork...
Hi everyone!...I'm new to the thumper side and come seeking 650gs wisdom. My wife owns a 2005 650gs and recently had an accident(she O.K.)...however her bike and I have a very long cold garage date this winter.
Fortunately her bike sustained mostly cosmetic damage..but her lower right fork cylinder broke at the axle bolt hole. This is where my problem is...I'm having trouble separating the fork. My locate BMW dealership was kind enough to send me the fork schematics but they haven't helped much.
I know it's probably something simple like a twist here or a pull there...or I need a special BMW tool to get them apart. So far I have only been able to remove the fork oil via the bottom drain plug, remove the top piston ring pin...and now I'm stuck.
Trying to push the upper piston down far enough to remove the ring seal is beginning to make me feel like I'm in for a long night...
Any help would be appreciated.
sweatychef is offline   Reply With Quote
Old 11-22-2007, 04:25 PM   #2
Tempo
Stumptown Native
Tempo's Avatar
Oddometer: 684
Send a message via AIM to Tempo Send a message via Yahoo to Tempo Send a message via Skype™ to Tempo
Did you read the FAQs? IIRC it should take 30-45 min to totally disassemble the fork.
I miss my '07 KTM 640 Adventure
Tempo is offline   Reply With Quote
Old 11-22-2007, 06:31 PM   #3
sweatychef OP
sweatychef's Avatar
Oddometer: 18
Thanks Tempo...that helped explain the disassembling procedure which is pretty much what I thought. The damping rod & fork spring inside the fork tube seem to be stuck and are not coming out as easily as they should.
At least now I know I'm not a complete idiot!
Old 11-22-2007, 06:36 PM   #4
BuckRider
BuckRider's Avatar
Oddometer: 1,540
There's a hex bolt on bottom of lower fork tube you need to loosen.
Mine was a pain, as it would just spin inside the tube, so I used a 3/4" (or maybe it was 1") piece of PVC water pipe to keep the insides from turning. I cut a length about 36 inches or something like that, take off the cap, remove the spring, and then send the pipe down the upper tube to engage and lock up the lower dampening tube.
I had also taken my forks out of the triple clamps and used the above pipe to hold up the fork - essentially I inverted the fork and used one hand to push down on the lower fork tube (which is now on top) down onto the PVC pipe, while I turned the hex wrench with the other.
I used the same setup to re-tighten the bolt.
I took my forks apart to put in Race-Tech emulators which I highly recommend.
The PVC is soft enough to not scratch the metal parts, and offers enough grab to keep the insides from spinning.
Sorry I don't have any pictures.
Am I really expected to put some bit of wisdom here in my signature space?
Current Rides:
F650GS Dakar
400 EXC
BuckRider is offline   Reply With Quote
Old 11-23-2007, 09:15 PM   #5
Woodsrat
Gone ridin'
Woodsrat's Avatar
Oddometer: 1,273
'Nuther way to break the bolt loose is to use an air or electric impact wrench. I leave the spring and fork cap on and break the bolt loose before I do anything else.
Woodsrat is offline   Reply With Quote
Times are GMT -7.   It's 12:37 PM.
