Old 11-24-2007, 07:45 AM   #16
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,093
The 85 is the way to go. It had a dry sump oil system instead of the wet sump on the 83, 84 models. The 85 runs cooler and had a lot less bottom end problems than the wet sump models. There were many changes to the 85 that made it better than the previous models.
I had a 85 and loved it!
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 11-24-2007, 12:22 PM   #17
LoneStar
WhoopDeDoofus
LoneStar's Avatar
Oddometer: 1,214
I had an 84 XR350 years back - opened the breathing and rejetted it. Started every time on 2nd kick and turned out to be a great deep woods bike. Pulled like a tractor and was stone reliable. Buddy had an 85 350 but the ergos of the 84 fit me better (6'4 240)
Great bike and wish I still had it
LoneStar is offline   Reply With Quote
Old 11-24-2007, 07:30 PM   #18
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,271
This is a picture of one whic was once mine. Sold it this year, as I wanted the mother pig: 650L
http://i218.photobucket.com/albums/c...o/DSCF0005.jpg
AtomicGeo is offline   Reply With Quote
Old 11-26-2007, 05:47 PM   #19
MZcountryboy OP
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
its a 1985 -
Picked it up today -
1985, one carb, dry sump, electric speedo thingy, aluminum swingarm, new IRC knobs, they look pretty good. It's got the regular dirt bike rash, but overall runs pretty good, doesn't idle real well, but we've yet to even look at it yet.
Now to get it torn apart, dual sported, and ready for some spring fun!
I'm sure I'll have questions along the way.......
MZcountryboy is offline   Reply With Quote
Old 11-26-2007, 06:18 PM   #20
yanni23
Oddometer: 655
Thumb Here's Your Parts!
Here's every part available for the XR350R. These are for the '85 but check out the other years if you have another year model.
http://houseofmotorcycles.bikebandit...r-1985/o/m9708
yanni23 is offline   Reply With Quote
Old 11-26-2007, 10:41 PM   #21
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,271
Man that needs some TLC. Good luck. I have a brand new headlight for that bike if you need one. Once I sold mine, I didn't have a need for it. PM me if interested.
Old 11-29-2007, 03:04 PM   #22
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
Also I have a front wheel with rotor if'n you ever need..
WoovsHoovs is offline   Reply With Quote
Old 01-21-2008, 02:55 PM   #23
MZcountryboy OP
Oddometer: 5,466
Got the idle fixed......
Turns out the intake valves were tight. Adjusted them to .008" cold, now it's harder to kick over, and idles like a dream. Now to tune out the bog off idle, and get some parts ordered!
What could tight intake valves indicate in my near future?
Old 01-21-2008, 03:20 PM   #24
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,902
Possibly that the previous owner was careless about maintenance. I'd change oil after each ride the first 2-3 times out and checks things like nuts on the axles, swingarm, engine mounts, etc, routing and condition of the cables. especially the throttle, possibly replace the brake fluid and bleed it out, make sure you don't have any loose spokes.
But you've probably done all that already.
montesa_vr is offline   Reply With Quote
Old 01-25-2008, 03:08 PM   #25
MZcountryboy OP
Oddometer: 5,466
Tore it down to the frame today
Was re-doing just the wheel bearings today. That's all I was going to do.
Well, that turned into shitty feeling steering head bearings, I need to change fork boots, gotta pull the forks, well, 3 hours later, the frame is sitting in my partswasher. (yes, the whole frame, fits nicely!)
Checking out the rear suspension linkage, all the pivots look/feel great, even the swingarm pivot. Full of grease, all looks well there.
I have a leaky shock. Can the factory showa unit be rebuilt? It's a nice one, rebound + compression + preload adjustable.
Gotta get some steering bearings ordered up, some new grips, and a list of crap about a mile long.
I'm gonna change the color I think.......
Old 02-07-2008, 10:33 AM   #26
letank
Oddometer: 47
Originally Posted by Eurobiker
These were only made 83-85, when Honda inexpictedly decided to discontinue production. The 83,4 had dual carbs, while the 85 went to a single. The 85 had a slight bump in displacement at 353 cc. These, especially the 85, are great little trail bikes. You'll find more info over at thumper talk.
Reviving the thread.
i have a mongrel.... 83XR350 w front disk, and XR600 swing arm... but here is the kicker, cylinder jug is labelled 353.... I bought it a year ago.
I just blew a valve (broken, while chasing an idle problem), and looking for good hints at which valves to get... seal and other goodies. Luckily no marks on the cylinder wall.
83 list the main jets at 112 and 105, but 84 is 115 and 112. Of course 85 is the lucky year one carb and dry sump.
Cheers
Michel
letank is offline   Reply With Quote
Old 02-09-2008, 07:52 AM   #27
MZcountryboy OP
Oddometer: 5,466
Updates
Well, lots of things going on now.
I'm gonna be riding a sweet XR350 this spring.
Frame painted.
New wheel bearings. New rear brake shoes.
New steering head bearings.
New fork boots/fork oil.
New paint on all the bits that came off the frame. (footpegs/brake + shift levers, etc.......)
New bars, grips, some cables.
New rear fender, new front fender...........
New sprockets, chain, sliders etc.....
Here's the best news of all - I sent the showa rear shock off to be rebuilt, as it was leaking a bit. The forks on this bike had a "factory connection" sticker on one of the fork legs, so I did a search, and turns out they are a moto-x suspension tuning shop out of southern NH.
I called these bubs up, and asked them if they would look at my shock, seeing as how the bike had their sticker on the forks. They said yes. Shock sent out in the mail!
They called me thursday, seems as though the shock is OK. Needs seals, a new bumpstop, dust seal, a bushing, and they want to re-chrome the shaft, due to some pitting. All stuff they can do! They said the shock will be good as new when they're done! Both the shock and the shaft are NLA, so this is great news! It will be less than $400 for the shock rebuild.
Got some more bits + pieces coming, I'll get some pics up soon.
C'mon spring!
Old 02-09-2008, 10:59 AM   #28
STFU
Found
STFU's Avatar
Oddometer: 397
sounds great, how about some pics of the progress? Factory Conection is right down the road from me, they seem to do great work.
STFU is online now   Reply With Quote
Old 03-04-2008, 03:37 AM   #29
MZcountryboy OP
Oddometer: 5,466
pics of progress
a few more bits are arriving soon, and we will have it together for spring.
Old 03-04-2008, 05:02 AM   #30
STFU
Found
STFU's Avatar
Oddometer: 397
Looks great, thanks for the update. Should be fun this spring...if it ever gets here.
Times are GMT -7.   It's 09:54 PM.
