Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 05-08-2014, 06:24 AM   #66076
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,113
Originally Posted by MeefZah View Post
Mark-
General thoughts on the KTM 300 EXC platform, specifically an older one ('98)?
I've done the internet research, which leads me to believe it is the greatest bike ever made... or the worst ...
- Other Mark
I don't know much about that generation. My last 250exc (2-stroke) was a 2004, which was the 1st year of that chassis generation (next update was in 2008, IIRC). That is as old as I'd want to go. For one thing, parts compatibility and availability is better (brake pads, wheel bearings, spare wheels, etc). KTMs got a big upgrade in chassis and suspension specs in '03 and '04, compared to prior years. I think the '98 used the conventional 50mm forks, which are actually great for trail riding, from what I understand. Not sure about the rear suspension though. KTM has continuously evolved it's PDS (linkless) design over the years, so the newer the better.
Mark
'11 KTM 250 XC (dual sported)
'05 KTM 450 EXC (dual sported)
OhioPT is offline   Reply With Quote
Old 05-08-2014, 06:39 AM   #66077
ruppster
ruppster's Avatar
Oddometer: 882
Originally Posted by OhioPT View Post
Skill level is not relevent. A properly jetted bike is easier to ride for a novice too.
What spring rates are you going with, and how much do you weigh? I'm 200lbs and I swapped the springs out after the first ride.
I'm about 225-230 geared up. I went with a 9.2 straight rate for the shock and 0.46 fork springs. I did a lot of research on ktmtalk and those seemed on par with some of the online calculators, a few say a little stiffer. I'd rather err on the soft side. There seems to be some controversy about using a straight rate vs. progessive, figured I'd try straight rate first. I've just started to notice that the suspension is a little soft, guess that means I'm progressing. Need to grab a couple qts of 5wt at the dealership to change fork oil at the same time.
Stock is 8.0 on the shock and 0.42 in the forks. Supposed to be setup for a 160-170-ish rider.
15 KTM 690E, 05 KTM 450EXC
ruppster screwed with this post 05-08-2014 at 06:45 AM
ruppster is online now   Reply With Quote
Old 05-08-2014, 07:18 AM   #66078
indypup
indypup's Avatar
Oddometer: 3,761
I got racetech springs for my KTM which has PDS shock and 4CS forks. The shock spring is progressive and that's what racetech recommend. I erred on the soft side too hoping that I'd lose some weight. ;)
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 05-08-2014, 08:01 AM   #66079
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Racetech also tends to be twards the stiffer side of suspension from my experience.
Danjal is offline   Reply With Quote
Old 05-08-2014, 08:10 AM   #66080
ruppster
ruppster's Avatar
Oddometer: 882
That was what I read. Mine are 1 click softer than their recommended.
Old 05-08-2014, 08:11 AM   #66081
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,113
Ruppster, I have to look, but I'm pretty sure I'm running a 9.2 on the rear also. The stock fork springs are actually .44 (some of the online calcs are wrong). The 2-strokes have .42 stock. I swapped in a .48 spring in one of the fork legs, for an effective .46 rate. My geared up weight is the same as yours, so you should be golden. 8mm of preload on that shock spring should get you very close on the sag numbers.
The progressive vs straight rate debate is like choosing which oil is best. Run what you like. But, having owned 5 PDS bikes now, with progressive shock springs on 2 of them, I have to say the straight rates perform better. The shock is valved to increase damping later in the stroke, hence the term PDS (Progressive Damping System). So unless you change the secondary piston and valving, I think the shock becomes too stiff with progressive springs. I also think you should run more rider sag with the progressive spring, to counteract some of this harshness. However, this will make the bike steer slower, so you have to raise the forks in the triple clamps to lower the front end an equal amount. I think places like Race Tech push their progressive springs because A) they cost more and B) they want you to get your shock revalved with their parts ($$). I also think people who do a lot of jumping (MX and GNCC type racing) might prefer the progressive springs for their increased bottoming resistance, but with the linkage suspension available now, that's not an issue for the newer bikes.
Mark
Old 05-08-2014, 08:30 AM   #66082
indypup
indypup's Avatar
Oddometer: 3,761
Damn, I think I'm starting to like Mark more than Mike...lol
OhioPT vs mgorman
Old 05-08-2014, 10:40 AM   #66083
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
OhioPT vs mgorman
http://www.google.com/url?sa=t&sourc...nSQwLlrC191zVg
It just seems so appropriate right now..
Stop hogging the wall Indy.
Old 05-08-2014, 11:13 AM   #66084
BikerGeek99
Horizon Chaser
BikerGeek99's Avatar
Oddometer: 1,347
Originally Posted by flashover604 View Post
Lucky's Grille has a great Fried Bologna sammich. It's in Hilliard at Roberts and Hilliard-Rome rds.
Good catch! I've been friends with the owners of Lucky's since I was in high school.
If ya wanna get a bologna sammich, though, ya gotta make the trek up to Waldo at least once for a famous bologna sammich at the G&R Tavern.
Did you pick the food places for the Ramble...lol I didn't get to go this year due to going to Renfro Valley DS but I'm sure you guys had fun...
Funny - we ate dinner both nights at the Mexican joint that's within walking distance of Ramble Central.
Thank God for the man who put the white lines on the highway.
- Michael Stanley
- '09 FLHTCU
- '04 FJR1300
BikerGeek99 is offline   Reply With Quote
Old 05-08-2014, 02:00 PM   #66085
B-Mac
Aged Beef
B-Mac's Avatar
Oddometer: 677
Fork Spring compressor
I cant find my *%#%^*( #@*&( cartridge fork spring compressor. I think I loaned it out in AZ.
Anyone have a Fork Spring Compressor I could use? I will have to buy a new one $149.00 race tech.
Brian DL1000K4 & Z1000
B-Mac is offline   Reply With Quote
Old 05-08-2014, 02:24 PM   #66086
motodirtlover
Motodirtlover
motodirtlover's Avatar
Oddometer: 1,050
Mark-
- Other Mark
I've had a few of those. The forks were pretty ok in the woods, motor was generally ok. Get it cheap though, as you'll probably need to put a few bucks in it...
I think I still have a reed cage and kit for one of those...
If not jetted properly, they can be a little fickle to start.
motodirtlover is offline   Reply With Quote
Old 05-08-2014, 03:12 PM   #66087
flashover604
tailgunner
flashover604's Avatar
Oddometer: 548
- Other Mark
The one I had was a 93' and ended up having a bum (and hard to find/replace) ignition. I think the 98 had a better ignition. Mine was like a 3-stroke. I could kinda lug it like a four stroke but it'd absolutely rip on the pipe. I'm throwing around the idea of trying to trade my 640 for another one and some cash. I miss the light weight and simple maintenance.
"That which does not kill You, usually makes you wish it did......."
flashover604 is offline   Reply With Quote
Old 05-08-2014, 03:43 PM   #66088
jules083
jules083's Avatar
Oddometer: 3,895
Had fun today, although 555 didn't really live up to the hype. Took 22 to zanesville, 555 to the end by little hocking, the 339, 78, 800, and back on 22 getting home. About 320 or 350 miles, somewhere in there. The stock seat sucks, my ass hurts already.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 05-08-2014, 03:54 PM   #66089
bikeridermark
Oddometer: 2,319
Did 555 have much crap on it?
bikeridermark is online now   Reply With Quote
Old 05-08-2014, 04:03 PM   #66090
sion
sigh-own
sion's Avatar
Oddometer: 3,589
555 is like US129 (aka the Dragon/tail of the Dragon) in that it's more of a challenge than it is a really fun road. There are some sections that flow nicely, but they are few and far between. There are also some hairy sections that can bite your ass if you aren't paying attention...particularly if there's gravel/cinders/sticks/leaves/amish road apples or other debris in a shadowy, off-camber corner.
I make a point of riding 555 at least once a season, as an exercise in keeping my skills sharp. Another good road for that is 26 between Marietta and Woodsfield.
if you want a road that flows well for lots of miles, try picking up 550 going east from 33. you've already found 78, which has some fun sections...
I say, there's no such thing as a bad day's riding. -metaljockey
whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301
sion is offline   Reply With Quote
Times are GMT -7.   It's 07:52 AM.
