Old 09-10-2008, 03:12 PM   #286
Monroe
Monroe's Avatar
Oddometer: 672
Originally Posted by Minnesota
There seems to be a wealth of experience here about the installation of the VVME kit.
First: I got my kit in the mail yesterday and of course had to open it up right away. Looking through this thread I see a lot of references to plug and play. I may be mistaken (and I hope I am) but it doesn't look like the kit will plug into an 1150 GS without some extra work.
Two: Can the kit be run with only the low beam on? In other words, will my stock high beam switch be functional?
Last: I made (perhaps) a mistake and got the telescopic dual beam bulbs. Is this an issue? Will they work fine? Do I need to send this kit back and get another one?
Thanks.
First: I won't bet, but I gotta think the bulb connections are the same on the 1150 and the 1200. I have a 1200 and the only electrical connection is plug the 2 spade connectors from the HID wiring loom into the female plug from the old halogen bulb. At least on the 1200, that is all you had to do
Two: I blelieve your switch will still work as the 1150 is a dual bulb system like the 1200.
Last: I'm not sure I know what the telescoping bulbs are. I'm wondering if they are used in a single bulb system for both high and low beams. Will they work in your bike, I'm sorry I can't answer, but I bet JVB could.
Hope this helps a wee bit
Steve
Monroe is offline   Reply With Quote
Old 09-11-2008, 06:51 AM   #287
Minnesota
Conform or be cast out
Minnesota's Avatar
Oddometer: 3,970
Steve
More than a wee bit. Thanks.
I'm figuring that I'll install what I have, and if it doesn't work its probably close in price to order the kit JVB used rather than send what I have back. And I'll have some spares too.
To learn who rules over you, simply find out who you are not allowed to criticize. -Voltaire
Minnesota is offline   Reply With Quote
Old 09-11-2008, 09:30 PM   #288
bodybomber
bodybomber's Avatar
Oddometer: 216
Question
Has anyone here had a problem with the VVME kits setting off the LAMPF!! warning on start up??
VF1100S sold to friend then left turner killed the rider
2008 1200GSA
06 DR650
89 ZX10
bodybomber is offline   Reply With Quote
Old 09-11-2008, 09:39 PM   #289
Opus
Oddometer: 494
The bulb with the solenoid is usually an H4 and is designed for both low and high beam in a single bulb replaces a stock H4. On a bike with two bulbs you do not want to use this kit, On the 1200 it is an H7 setup up, not sure on the 1150. You should be able to wire in one kit and have the other beam work normally, I did my low beam first but then converted the high beam as well.
opus
Opus is offline   Reply With Quote
Old 09-11-2008, 10:00 PM   #290
azgsa
Apathetic
azgsa's Avatar
Oddometer: 1,368
If you read through the thread you'll see that the consensus is that you need to let the bike go through the self check and then the LAMPF light wont activate and the actual HID startup will happen OK.
Arizona Adventure Riding Group
azgsa screwed with this post 09-11-2008 at 10:16 PM
azgsa is offline   Reply With Quote
Old 09-12-2008, 06:31 AM   #291
Minnesota
Minnesota's Avatar
Oddometer: 3,970
opus
Yeah, I wanted to believe that I had missed something when I went through the kit right after I got it. Unfortunately, after looking at the enclosed wiring diagrams it is obvious that I bought the wrong kit. The Dual Beam kit is designed to plug into your wiring harness in one spot, with some kind of plug that I'm not sure what it is supposed to fit. Definitely not a BMW motorcycle. The single beam kit wiring diagram reiterates what has been said in this thread numerous times: just plug the hot wire into your bike hot connector and the ground wire into the ground connector. Make some minor modification to the bulb bracket and find somewhere to put the ballasts. The rest is just wire ties and electrical tape.
I am now off to VVME.com to order the right kit.
Old 09-12-2008, 06:59 AM   #292
GB
Mod Squad
GB's Avatar
Oddometer: 56,580
and in case you missed it, when you order the single bult kit from VVME, you will get two as pictured in post 1 of this thread, so you can do the low and high beam or share it with someone else.
Old 09-12-2008, 07:01 AM   #293
Minnesota
Minnesota's Avatar
Oddometer: 3,970
I had a better idea:
Mr. Han Fei,
Thank you very much for the prompt shipment of your product. I received the kit and everything looked fine in the package. Unfortunately I seem to have ordered the wrong kit. I ordered the Dual Beam kit and it looks like I should have ordered the Single Beam kit with the H1 bulbs. I have a BMW motorcycle and the Dual Beam kit will not install easily into this motorcycle. I am emailing you to see what we can do to get the Dual Beam kit returned and a Single beam kit sent out instead.
Just for clarity, this is the link to the kit that I need. http://www.vvme.com/product/detail-20023.html
Please reply soon so that I can get this excellent product installed on my motorcycle as soon as possible.
Thank you for your time.
-Nick Schaff; Boyceville, WI
We'll see where this goes.
Old 09-13-2008, 01:23 PM   #294
Monroe
Monroe's Avatar
Oddometer: 672
resistor?
my new xennon kit, slim ballast, (that I know is good) flickers at start up, then shuts off and I get the lampf. So, I pull the unit from the bike, again, and stick the leads directly to the battery and BINGO!, I got light. So I'm thinking the canbus is not seeing enough resistance with the HID system.
My next try will be a in-line resistor. My electronics background is minimal so,
(1) if the old bulb draws 55 watts, and the HID draws 35, do I need a 20 watt (ohm?) resistor?
(2) and is my brand new efficient 35w system now drawing 55w because of the added resistance in-line?
Thanks for any input
Steve
Old 09-13-2008, 01:28 PM   #295
azgsa
Apathetic
azgsa's Avatar
Oddometer: 1,368
Are you waiting for the bike to complete the self-check when the key is turned on, before starting?
Old 09-13-2008, 01:35 PM   #296
Monroe
Monroe's Avatar
Oddometer: 672
Oh yes, I've been at this for a while
thanks for the reply
Steve
Old 09-13-2008, 01:42 PM   #297
Monroe
Monroe's Avatar
Oddometer: 672
just went out and tried again. I usually let the RID finish it's job and then start the bike. This time I waited longer, say another 10 seconds?? fired the bike, light comes on and stays on..........I dunno, guess I'll try it again in a few and see what happens.
S
Old 09-13-2008, 01:56 PM   #298
Monroe
Monroe's Avatar
Oddometer: 672
??????????? works now, go figure. it'll krap out once I get all the wires hidden and tucked away..........
Steve
Old 09-13-2008, 02:55 PM   #299
Monroe
Monroe's Avatar
Oddometer: 672
doesn't work now............I'm done with it unless xenon can come up with some ideas
Old 09-14-2008, 12:21 PM   #300
Minnesota
Minnesota's Avatar
Oddometer: 3,970
Dear customer,
Thank you for choosing us.
If you ship the bulbs back we can send you a pair of bulbs you need you will cover both sides of shipping.We suggest you just buy a pair of single bulbs and you can use the same ballasts you have received. We can offer $30 for the a pair of single bulbs.
If you want to take this deal, please make your payment at http://www.vvme.com/payment.jsp by Paypal or credit card (also thru PayPal which is the safest and most reliable online payment method). Leave the order details and other instructions in the payment notes for us. Once we have received your payment, we will ship the products to you immediately.
Regards.
I took the deal. Hopefully the $30.00 number includes shipping.
Times are GMT -7.   It's 05:00 AM.
