Old 01-27-2010, 11:17 AM   #631
Dakarider
INBMWR & WSBMWR Member
Dakarider's Avatar
Oddometer: 116
response..
Originally Posted by GSguy
Any response from these guys? A buddy I work with has used them two times and says they have great service and was pointing me in there direction till I hit your post, let us know.
Cheers
I never received a response per se....I sent them an aggressive email detailing my displeasure with their unresponsiveness via their site and they shipped later that day. I don't think that was a coincidence. I threatened them with a paypal dispute and a poor review here. I went through with the review because I felt that this service level was unacceptable and that they should be aware that they were not meeting expectations. I have still never received communication from them in regards to this purchase other than a UPS shipping notification.
I hope I don't have to take advantage of their "lifetime" warranty. I am definitely not impressed with the level of customer service and responsiveness from these folks. I hope I am an anomaly.
uh... why is the rubber side up? and why am I looking at my taillight?
Dakarider is offline   Reply With Quote
Old 01-28-2010, 05:35 AM   #632
Will DaBeast
Go United
Will DaBeast's Avatar
Oddometer: 1,377
I might just have to finally do this. My 05 GS has 47K and I just replaced the low beam for the 7th time.
'05 R1200GS
BMWMOA #127619
Will DaBeast is offline   Reply With Quote
Old 01-28-2010, 06:59 AM   #633
laukkanen
laukkanen's Avatar
Oddometer: 103
I ordered the 55w slim ballast kit from DDM last friday from their website and it was delivered yesterday. I went with the 6000K bulb in an attempt to match the color of my Micro DE xenon auxiliary light.
Installation is just as easy as Jim says! Just did the low beam last night.. Before drilling out the caps I hooked up the wires to see if I would get a LAMPF, happily there was none.
Drilling out the cap proved to be a bit of a challenge with a 7/8'' spade bit, a dremel definitely would have been easier. I also had the problem where, even with the clip removed, the plug that goes direct to the ballast wouldn't fit through that size hole and made notches to fit it through. I did use a little silicone sealant, probably not necessary but rather safe than sorry for it! One ghetto zip-tie bracket mount later and I was up and running.
My first impression:
My second impression:
I am still running a halogen flood fog lamp on the right side of the beak and i think I like the combination of the yellow and white light. High beam conversion happens today after work. By far the best return per $ of any upgrade I've done.
laukkanen is offline   Reply With Quote
Old 01-31-2010, 01:55 PM   #634
kjclark7
kjclark7's Avatar
Oddometer: 1,416
23mm hole
for those of you who drilled a 23mm hole in the caps, how did you get everything through the hole? i drilled my caps out and i started out making a 7/8" hole but the bulb or the other connecting end (end that goes to ballast) would not go though. i went up to a 1" hole and still could not get it through. finally i drilled a 1 1/8" hole and the end that connects to the ballast just made it through.
i just don't know how you guys did it with only making a 23-25mm (29/32"-1") hole??
now i just have to wait for my bike to come back to install everything
2009 BMW R1200GS Adventure
2008 Yamaha FZ-6
1983 BMW R100RS
2013 KTM 350 XCF-W
kjclark7 is offline   Reply With Quote
Old 01-31-2010, 05:34 PM   #635
LTCOliverNorth
Peeping Tom
LTCOliverNorth's Avatar
Oddometer: 786
I started with a 1" hole, but then I had to dremel out little cutouts so that the connector could fit through. So my hole turned out to be 1" in diameter, with 2 opposing bulges.
LTCOliverNorth is offline   Reply With Quote
Old 02-07-2010, 11:39 AM   #636
GAP
GAP's Avatar
Oddometer: 168
The little bit too big DDM connector comes apart and you reassemble it on the other side.
2008 GSA, 1976 Sherpa T
IBA 38114
GAP is offline   Reply With Quote
Old 02-07-2010, 01:09 PM   #637
Gambit
Gambit's Avatar
Oddometer: 140
For the VVME kit, I needed a 1" hole and just the slightest relief notch (1 - 2 mm deep) on one side to slip the connector through. There's a strain relief part on the connector that I removed first.
2013 Moto Guzzi V7 Racer
2012 Ducati Hypermotard EVO SP
2009 BMW R1200 GS Adventure
Gambit is offline   Reply With Quote
Old 02-12-2010, 11:26 PM   #638
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,348
Thumb New Mount on Adventure
After getting dogged out on my cheesy install of the VVME HID 35w, I really did up a sweet mount. ( 1 ballast velcroed about the headlight and the other zip tied to the crash bar) As stated before I am anal about a clean factory look. Since I cant upload pics try to envision this. I started with some scrap black powder coated ( or wrinkle paint ) metal that I got from our radio shop. This is used to make mounts for radios in our patrol cars. The radio shop has all kinds of this stuff in the scrap bin.
I started with a about a 10 inch by 8 inch flat piece. I used u bolts at each edge to go around the small crash bar where the fog lights are mounted. I drilled a center hold at the front edge to mount to the center screw on the large crash bar the sits behind the small one.
I mounted the ballasts side by side facing down. in their brackets. The front edge of the piece of metal is flush with the larger crash bar and just under the oil cooler.
I then took a second piece of flat metal that was slightly smaller and drilled 3 holes to match up with the other piece. This now sandwichs the ballasts between the two pieces of metal. The second one just happend to be slotted so this allows some cooling airflow.
The HID wires come out the front of the sandwich and go to each side to their respective headlight housing.
After it was all fabbed up and mounted it has to be the most secure, neatest HID Ballast mounting I have seen and not one Zip tie was used to secure the ballasts, only the wiring to the HID bulbs.
Here is Mississippi, on the pot-holed, dirt, gravel and mud-strewn back roads I just felt like I needed a really secure mount. And no jack-leg looking zip-tied crap. Also, if i want to upgrade to the 55w, or slim ballasts or whatever, this mount will be right there and easily modified. VERY VERY STOUT.One other thing. On top of the sandwich there is a small piece of flat alumin. that runs between the ubolts and under the small bar. This makes the sandwich tilt slightly down toward the front to clear the underside of the beak. A good quarter inch clearance this there. Also this HID sandwich completely protects the ballasts.
I will take a pic and make it available to anyone wants to PM me.
And of course, just like everyone else says, the change to HID was quite impressive. I tossed the TT mesh grill because the grid pattern projected was just to distracting.
John Hart McComb MS
2003 Ducati 999s "Christine"
2008 BMW R1200GSA Mary Jane
2005 Chaparral 210ssi " Native Sun II "
onesaintsfan screwed with this post 02-12-2010 at 11:34 PM
onesaintsfan is offline   Reply With Quote
Old 02-17-2010, 10:24 AM   #639
cula
cula's Avatar
Oddometer: 57
Originally Posted by JimVonBaden
Originally Posted by rsimpson
Hi guys,
a couple questions regarding the install::
1. From the battery, I have yellow and red wires and from the HID kit I have blue and black. Can you tell me what connects to what?
Nothing from the battery goes to the HID wiring, or anywhere else. Unplug the wires from the original light and plug them into the HID wiring, brown to black, and then the other ones. Plug the other wires from the HID ballast to the HID bulb. No additional wiring to fit.
2. The 23mm whole I cut around the plastic base doesnt look large enough to fit some of the connectors through. How did you do this?
Thank you!
The 23mm hole is fine, remove the wire clip on the big plug, push it through, you will have to work it, and then reinstall the wire clip in the big plug that goes to the ballast.
Basically you make a loop fromn the original wires to the ballast, and back to the HID bulb.
Jim
Do you know how to remove the other two connectors? I'm refitting some Hella Micro DE and I'm having problems with the small rubber boot.
cula is offline   Reply With Quote
Old 02-17-2010, 10:36 AM   #640
cula
cula's Avatar
Oddometer: 57
Originally Posted by johnlt
I run HID H7s on both high and low beam in addition to two Hella Mico HID aux lights triggered on high beam. I can start the bike with the high beam (and Hella aux lights) on and get no faults. The system really adds a lot of light. When all are on inside my garage with the white garage door down, it swamps my V1 laser detector which alarms. That's a lot of light!!
Sorry, but I don't understand. How do you run your hella lights? Do you have to have your high beam on?
Old 02-17-2010, 10:49 AM   #641
cula
cula's Avatar
Oddometer: 57
Originally Posted by aclark79
Surprised you need to pay anything when its the product thats bad. From what I'd heard before they have no problem sending a replacement unit....
"Vide" sau vede?
Old 02-17-2010, 03:05 PM   #642
onesaintsfan
BigJohnHart
Oddometer: 1,348
My HID Mount.
Why did it vanish?
John Hart McComb MS
onesaintsfan screwed with this post 02-17-2010 at 11:42 PM
Old 02-18-2010, 10:31 AM   #643
splat matt
splat matt's Avatar
Oddometer: 219
I have received some requests regarding my ballast mounts - apparently the pictures were no longer linked and that is now fixed.
The link below takes you directly to my original post in this thread.
http://www.advrider.com/forums/showp...&postcount=554
.::.: 08 XR650L (Thanks Dad!) ::..:
splat matt is offline   Reply With Quote
Old 02-18-2010, 09:00 PM   #644
cula
cula's Avatar
Oddometer: 57
Does anybody knows what he's talking about? Does it mean he can run his Hella lights only when the high beam is on? Does anybody knows the answer?
Old 02-18-2010, 10:43 PM   #645
Gambit
Gambit's Avatar
Oddometer: 140
Sounds to me like he used the high beams as the trigger to a relay that powers the Hella's so they automatically come on when he turns on the high beams - no separate switch.
Times are GMT -7.   It's 10:47 AM.
