Old 12-28-2011, 05:02 PM   #901
DrLax
Go Big
DrLax's Avatar
Oddometer: 214
After going through two filament bulbs on my 09 GSA, I went with DDM HID Kit, 35W, H7, 4500K back in April to replace the low beam. No LAMPF. Works great.
DrLax is offline   Reply With Quote
Old 12-28-2011, 08:28 PM   #902
PanhandleChuck
3rdRockAdvRider
PanhandleChuck's Avatar
Oddometer: 276
Mike and Chris....thanks for the feedback.....apparently I was being too proactive and should wait the 1offmotorsports HID's to arrive!
r//Chuck
PanhandleChuck is offline   Reply With Quote
Old 12-29-2011, 03:32 AM   #903
mikegc
mikegc's Avatar
Oddometer: 1,622
r//Chuck
No sweat, Chuck. I'm waiting for my 1-Off unit to arrive, too. I'm converting the high beam. I did the low beam some time ago and noticed my high dollar bright white bulb did absolutely nothing to enhance visability. I think you'll like the 1-Off unit.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 12-29-2011, 01:39 PM   #904
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I cannot get the 35w HID to work on my low beam. I thought I had a bad bulb so I exchanged it and I get the same thing...it flashes at start up and then goes out. anyone else had this issue? HIgh beam 35W works fine.
EJ_92606 is offline   Reply With Quote
Old 12-29-2011, 01:55 PM   #905
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
That's weird....I bought the same kit and can't get mine to work on the low beam side. I have a 2011 GS...seems something changed in the DDM ballast or BMW made a change.
I tried hooking up a larger sized ballast to it that I had left over from a kit I installed on my old F800 a few years ago and it works! So for some reason the low beam does not like the slim ballast. So had a tough time shoe-horning the larger ballast into the GS, but I finally got it installed, so looking forward to the dual HID beams!
EJ_92606 screwed with this post 12-30-2011 at 02:11 AM
Old 12-29-2011, 02:58 PM   #906
mikegc
mikegc's Avatar
Oddometer: 1,622
My first HID unit finally did that. It was a DDM unit and worked fine, at first. When I got no satisfaction from customer service, I switched to a VVME and had problems with it, too. I settled on a 1-Off 35 unit and have had no problems since.
Mike
IBA 25881
Old 12-31-2011, 01:57 PM   #907
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Mike
Yeap in hindsight, the proven 1-off model backed by customer service is the way to go. When I called DDM they told me to solder a resistor in the stock bike wiring....bah, not going to do that, so I installed my old large sized ballast and that works, just not as elegant as the slim ballasts. So bottom line for others, deal with 1-off that has tested their ballasts on BMW bikes and will back them up.
Old 01-03-2012, 11:36 AM   #908
g_e_young
g_e_young's Avatar
Oddometer: 867
It seems like HID's are a no-brainer in terms of light output, but how badly is the beam pattern distorted? Is it just a matter of adjusting the headlight height, or is the beam pattern too badly distorted. I want more light, but not at the expense of a badly distorted beam pattern.
Thx, g-
IBA# 15974
www.whatsmyco2.com
g_e_young is offline   Reply With Quote
Old 01-03-2012, 11:38 AM   #909
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,349
Thx, g-
It depends on who you talk to. On my 05GS I found the light pattern very similar to stock. Some claim the light is way scattered, while others claim it has too sharp a line.
Jim
Old 01-03-2012, 01:57 PM   #910
g_e_young
g_e_young's Avatar
Oddometer: 867
Jim
It sounds like a $100 experiment is in order!
g-
IBA# 15974
www.whatsmyco2.com
Old 01-03-2012, 03:14 PM   #911
Charleetho
Mr. Zoom Zoom
Charleetho's Avatar
Oddometer: 1,936
Thx, g-
On my 05 the beam pattern is great with my two DDM kits. Best upgrade ever.
Charlie Thompson
Littleton, CO
Learn to ride Mile High Harley-Davidson Riding Academy
2012 FJR1300 (for sale), 2014 R1200GS, 99 ATK490
Charleetho is offline   Reply With Quote
Old 01-05-2012, 11:24 PM   #912
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Wow, took my first ride in an area without street lights after dark tonight and the HIDs are awesome ....they light up the road much better than the stock lights....very happy! I have 35W... I can't imagine how bright the 55W high beam would be. Only small negative is that it does take a few seconds for the high beam to get up to 100%, but not a big deal at all as I think the light is still brighter than stock when first illuminated.
Old 01-06-2012, 06:17 AM   #913
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,349
Installed a low beam HID in a 2011 R1200GSA last nigght, it was a snap, and worked great! I think the owner was happy too.
Jim
Old 01-09-2012, 09:09 PM   #914
PanhandleChuck
3rdRockAdvRider
Oddometer: 276
Installed 1offmotorsports 35W 6K low beam today. Any magic zip tie tricks for placing high beam ballast and igniters on a 2010 GSA.
Oh yea, works as advertised!
PanhandleChuck screwed with this post 01-09-2012 at 09:38 PM
Old 01-10-2012, 10:29 AM   #915
1offmotorsports
1offmotorsports's Avatar
Oddometer: 109
Zip Tie Magic for Install.
Glad you like it! Have you seen the install video for the 1200gs. it's on our youtube channel. Which I'll add to our profile page here on the forum. I've seen the mount done a lot of different ways. based usually on preference and also what other modifications have already been done in that that area. Typically I use the mounting plate and the zip ties to wrap around the frame. Low beam and high beam on opposite sides of each other.
1Off MotorSports
www.1OffMotorSports.com
Youtube Channel: www.youtube.com/1offMoto
Our lights are brighter than your honor student.
Phone: 888-225-6418
1offmotorsports is offline   Reply With Quote
Times are GMT -7.   It's 04:35 AM.
